I've taken plenty of photos of my models, mostly in-process on the work bench. Sometimes I'll make an effort to take some beauty shots, always with so-so results. But my brother, who is a pro photographer, showed me some tricks using my PILAR model. Am I likely to pick up the same tools he has? Not too likely, but a lot of it actually isn't too much of an add, assuming you already have a decent camera.
My impromptu lesson took place in my garage, with a big piece of black fabric for a back drop, and a coffee table to hold up the model.
The main "tool" was a soft box-  a big umbrella like thing with diffusers and a strobe inside. This was arranged over the model to rain soft parallel light down from above. We played with a reflector panel to get some bounce-fill, and even resorted to an old photo flood to fill in a dark spot. The process had a lot of trial and error: take a shot, examine it, adjust the lighting, it was all magic to me.
It was hardly a complete studio, but we made do with it to get some decent shots. See more in the scratch build gallery under PILAR.
My brother Wil doing his thing in the garage:
Better view of the soft box and reflector:
Using an old flood to fill in:
... to get results like this:
Edited by Patrick Matthews
Pat M.
Matthews Model Marine
Model FUNCTION as well as FORM.
Get your boats wet!
Its all about the lighting and the gear you use   - and how much time effort and money  you want to put into it,   photography is like that anyway.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
This would interest a lot of people, but as Glenn says, you should consider posting on the "Photographing your work" sub-forum.
Stunning model, btw.
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
non of my builds are worthy of this much trouble and expense, i will  have to make do with my EOS 1300 outside lighting and a wheely bin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
I have my own studio and been shooting people for more than 10 years. But for photographing your boat here is my first tip which will basically cost you 4 euros but improve your photos to almost professional level. Buy a large piece of white paper, place it on a table which is very close to a window. Thats it... you can even use your phone to photograph.
If u want to have some variation, buy a black paper as well. A static model doesnt need complicated lighting. But it needs lots of light so all details are visable. So make sure to be very near a large window.
Current builds: HMS Victory (Corel 1:98), HMS Snake (Caldercraft 1:64), HMBV Granado (Caldercraft 1:64), HMS Diana (Caldercraft 1:64), HMS Speedy (Vanguard Models 1:64)
I'll move this to the photo forum since that would probably be the best place.
  • 5 weeks later...
As an ex pro photographer I agree with most of these comments. Lighting is crucial,  but it does not have to be expensive. You really can't have too much light on a subject (though you CAN have it in the wrong place) reflectors are the answer to most lighting issues and the easiest and cheapest way to make one or six is to stick crumpled up baking foil onto cardboard. Works as good as anything. I used this for product shots at my home studio, but on location had to use proper expensive stuff for the sake of credibility, but there is almost no difference between them.
