John
absolutely fantastic job on the wheels. I would someday like to build a paddle wheel boat but the wheels are a bit scary. You seemed to have tamed the beast!  Great step by step explanation. That will hopefully come in handy for me someday. 😁
Tom
Paddle Wheels…
Ready for assembly…
Posts are lining up pretty good.
Some filing to get paddles a bit better aligned.
Painting…
The Robert E Lee had two paddle wheels, each 38 feet in diameter and 17 feet wide. The second one was definitely built a bit straighter than the first one.  Paddle Wheel 2.0 will be the one left viewable, the other will get a full Wheel Housing built over it. 😆…
Paddle Wheels completed. 👍
Cheers 🍻
Edited by John Ruy
On 1/23/2022 at 10:59 PM, John Ruy said:
just repeat until you go insane.
Pretty much my exact thought as I read through your description of the process. Congratulations on surviving this task!
Ho Ho He He Ha Ha,.. I am not sure weather I survived without becoming a bit Obsessive.
I have now taken up Cutting Twigs into 3/8” pieces and splitting them into firewood. 🤪
They call this “Wooding Up”
on the Mississippi. 😆
Those Steam Boilers consumed a forest to transport goods and passengers.
Several stops to “Wood Up” were made between New Orleans and St. Louis.
Onwards… 👍
Steamboats wooded up multiple times daily. They were pretty clearly an agent of regional deforestation. I discussed this ecological context a bit in a video talk I gave on Missouri River steamboat history last year.
Fantastic job on the wheels!
Hanger Rods and Turn Buckles…
These rods were used to support the Main Deck as it was cantilevered beyond the hull.
Turn Buckles we’re supplied in the kit by Bluejacket. Good quality brass castings. I decided to use fine brass wire vs. the stranded wire I had used on the first two earlier in the build.
The stranded wire will be more more appropriately used as the Hogging Chain and Stack guy wires later.
Attaching the hanger rods…
Setting the rods with CA glue…
Painting the rods flat black…
Starboard side Completed.
Cheers 🍻
Edited by John Ruy
Well done with the paddle wheels, and with everything else.  From your description, those wheels must have been massive in real life.
Engine Room and Superstructure…
Paddel Wheel shaft journals…
Paddle Wheel shaft connection completed…
Boiler Feed Pump… Steam Driven pump to feed river water up into the massive boilers.
N - Scale windows and doors. Board and batten siding.
Superstructure walls… Because I will be viewing the engine room, I had to create the interior walls.  I could not find anything regarding the interior structure, so I assumed it would be “Barn” like. Given that this is the foundation for four story hotel structure it needs to be stout. 😎
Engine Room is coming together.
Note: Not going for accuracy here, very little info is available specific to Robt E Lee. I’m only trying to create the illusion when looking in under the boiler deck from the port side where I will leave the engine room wall open.
The above photo taken from Alan Bates’ Engine Room Cyclopedium will be my inspiration as I attempt to add to the illusion of an Engine Room. 😎
A lot of windows to install…
Engine Room wall for the starboard side. I will leave this wall open on the Port Side.
On to building the Wheel Housing.
Keeping everything plumb on a curved deck. 😆
This will be the view into the engine room from the port side. There will be framing only no walls.
 Curved walls on a curved deck…
Added windows.
More latter…  Cheers 🍻
Edited by John Ruy
Seeing those beautiful paddles and engine room come together make me want to tackle another one!
Grand Stairway continued…
Preparing the staircase for railings.
Used 1/32” sheet cherry wood to cut and build railings.
1/8” Mahogany posts and basswood strips as rail caps.
Fine sanding prep before staining and poly.
Grand Stairway in place…
Cheers! 🍻
5 hours ago, gsdpic said:
That stairway looks like a lot of work but the end result was worth it....very nice!
Yes… Lots of fun to be had for sure. A million opportunities to increase my scratch building skills. 😆 This kit essentially consists of the drawings and a giant wood package. Thanks for the comments. 👍
Progress on the superstructure…
Cutting out Boiler deck for staircase.
Boiler sub deck cut…
Cutting out kitchen deck.
Remaining decks cut out. Massive four story structure. It feels like I am in architecture class. 😆
Board and Batten is going to drive me batty. 😆 That and windows, four more floors to go. 🍻
Framing on the port side will be left open for the sneak peak at the engine room and paddle wheel. 😎
Bubble Bubbles it’s all got to be plumb.
Looking forward to more opportunities to improve my craft. 😆
Superstructure to be continued. 🍻
Edited by John Ruy
Amazing piece of work. Those paddle wheels are incredible and your tutorial is very clear.
Ras
Current builds:
USS SAN PABLO-1920-1/64 scale-River Gunboat
Previous builds:
Stern Paddle Wheeler ZULU-1916-1/48 scale
Freccia Celeste-1927 350cc racing motorcycle-1:9 scale- Protar kit
Boeing B17F- 1/72 scale- Hasegawa kit
HMS Mimi-scale 1/24-Fast Motor Launch
Amapá 1907-1/64 scale-Brazilian Customs Cruiser
Scottish Motor Fifie. 1/32 scale. Amati kit
Patricia. Steam powered R/C launch. 1/12 scale. Krick Kit
African Queen. Steam powered  R/C launch. 1/24 scale. Billings kit
Emma C. Berry. Sailing fishing smack. 1/32 scale. Model Shipways kit.
Main Deck Superstructure…
Ready for the paint booth.
Basswood has a tendency to curl when painted with Acrylics.
Painted and ready to be reassembled.
Started framing up the engine room.
more later… 🍻
Nicely done.  This looks like a fun build...like you said, almost like an architectural model.  I always wanted to pretend I was an architect.  :)
Actually, I feel more like a builder trying to understand the architect. Like you said, “pretending to be an architect.”  😆
Main Deck Superstructure construction  continues…
Tiller rigging blocks are being installed prior to the kitchen deck placement.
Stopping the blocks with black thread.
Tiller rigged…
Placement of wheel housings.
Kitchen deck placed…
Creative clamping to pull things together. 😆
Planking the kitchen deck. Note the wheel housing in the background. A bit of a lean on. 🤨
Removed the wheel housing side cover to affect repairs. Had a warped beam under the paddle wheel framing. soaked the exposed beam with ammonia and water. More creative clamping. 😬
Paddle Wheel now appears to be upright. We will let that dry overnight and see how it recovers. 🤪
More tomorrow… 🍻
Wheel Housings…
Framing up the Wheel Housing.
I finally get it all straightened up and it’s time to cover it up. 🤨
That was quite the challenge! 😆 I will be doing a cutaway view of the Paddle Wheel. Can’t let that stand hidden away. 😎
Onwards… 🍻
i had the same reaction several posts back when the housings first appeared - it'd be a shame to hide those wheels.
     Richard
Just discovered your build. Beautiful work so far. It’s great that you are breathing new life into these older kits. The Robert E. Lee is on my to build list some day. I’m definitely going to follow along intently.
-Brian
Current Builds:        Completed Builds:
Planning my next adventure.        HMB Endeavor: Artesania Latina
        USS Constitution - Cross Section: Mamoli
Non-Ship Builds:        HMS Victory - Cross Section: Corel
New Shipyard        King of the Mississippi - Steamboat: Artesania Latina
        Battle Station Section: Panart (Gallery)
In Dry-dock        Chaperon - 1884 Steamer: Model Shipways
USS Constellation: Aretesania Latina                                                       USS Cairo - 1862 Ironclad: Scratch Build
Flying Fish: Model Shipways        Mississippi River Towboat Caroline N.
Finishing up Wheel Housings…
Forming 1/32 x 1/32” basswood by soaking it in Ammonia/water and strapping it to the housings to dry.
CA gluing the molding into place.
Now to finish out that Engine Room.
Cutting steam pipes out of dowel rods.
Engine Room completed. Starting to install lighting.
View into the cut away.
One last look before the Boiler De k goes on.
I didn’t forget the Paddle Wheel cut away.
Thanks to all for your 👍 and comments, they keep me going.
Cheers 🍻
7 hours ago, Glen McGuire said:
Superb work and amazing perseverance - especially on the paddle wheels.  Wow.  But I gotta ask, who is this little dude that keeps photo-bombing your pics?
Thank you for your comments. This little guy came from my search for a crew of scale. I have decided against figures on board, but this guy won’t go away. 😆 I think I need to put a broom in his hands, so he can help clean up around here.
I think the build is going well, although it can be a struggle at times. More of a scratch build than a kit, but then that’s what you get with vintage model kits.
Thanks again for your encouragement.
Cheers 🍻
