looks quite busy.........sweet!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you  Denis.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Evening all,   I managed to get a bit more done on this  today,   I got the  airbrush/booth out  and  put a few layers of my Vallejo Primer  down  on the drivers compartment./engine bay/engine and a few other bits,   then after drying  a  attacked  a few over spays  with some wet and dry.
oc.
Current builds
Completed works.
Evening  all,  more progress  to day,    the airbrush  was  out again  - I  mixed up some flat White  and  gave a  few  thin layers  to the  inner parts.
OC.
Current builds
Completed works.
I foregot  to mension  - I am not too fussy about  some overspray  on the drivers  seat  as I have a  driver figure  to go in the seat, I have the same  set of figures as I used on my chally  (modern US  Tankers).
OC.
Edited by Old Collingwood
Current builds
Completed works.
I will be seriously interested in the steps you use to paint these figures Brother, they are the same ones I have for mine...
Edited by Egilman
Quote:
I will paint  him in a similar  way  to  how I painted this guy  for my British  Chally   -
OC.
Current builds
Completed works.
Excellent! It's probably time I learned to paint figures.... and I can't go wrong with your advice...
Quote:
Key to them  is  good magnification/light  and a steady hand.
OC.
Current builds
Completed works.
A bit more done today,   I decided to  make a driver figure  - well  this became more of a mission  than first  thought, same issue as  fighter plane figures  - over scale, so  even after  experimenting with Two  different leg sections, no way  would he sit in his  seat  with the top of the tank  dry fitted.   So  plan number Two  - to fit him on the edge of the drivers compartment  communicating  with another figure who will be  standing near the open engine bay.
OC.
Current builds
Completed works.
Evening all,   more work today  on the  engine  - I stared off  with a few  stages of Flat Alum  in a few areas,   then some Flat Black  vents hose  etc,   I followed this off with my  dark Brown wash  all over  then wet brushed  to  give a more overall  finish, I finished off with some  White dry brushing.
So here we have a well used  engine.....
OC.
Current builds
Completed works.
1 hour ago, king derelict said:
The engine looks fantastic; The shading makes it very real
Alan
Thank you  so much Alan,   it was trial and error  - never knowing  if I had gone over the top,    next  off will be the engine bay that  will get the same treatment.
OC.
Current builds
Completed works.
looking good OC.......weathering looks really nice!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you  Denis.
OC.
Current builds
Completed works.
Evening all,   more progress  today  -  I painted some of the details  in both the drivers compartment  and also the engine bay, then I  gave them a few dirty washes  and highlighted  the same as I did  to the engine,   then the engine was placed  along with another vent hose.
OC.
Current builds
Completed works.
Looking very good and showing a fair amount of use, OC.
Thank you kindly Mark,   yep she is going to be  quite a used  tank  with something  wrong with the engine  - hence why the covers  will be off it.
OC.
Current builds
Completed works.
Well, I hope the repairs are not much more than an oil change and air filter change, OC.
I think its a stuck gear  hence why the driver is  hanging around  his pit  - keep trying the gears.....
Could be that or just an excuse  waiting for the Popcorn man  to  arrive......😁
OC.
Current builds
Completed works.
...or routine maintenance ;)    looks very nice!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you Denis.
OC.
Current builds
Completed works.
Evening all,     I managed a few more hours on this  today  -  I  decided it was time to  offer the lower and upper  hulls  together  and glue in place,  there seems to be a slight  moulding error  as the lower is slightly thinner than the upper,  so  I worked from the front hull first  getting glacier  plate  lined up and glued, then I worked my way towards the rear and the engine bay, again a few slight errors of lining up  so it was trial and error  till I reached a good half way stage.
On the one  side  above were the skirts will be a top hatch side piece was  showing a recess  so this needed to be  filled with putty  and sanded.
All in all  not too bad  - but the lining up miss match under neath is a surprise.
OC.
Current builds
Completed works.
Evening  all,    I got  some good progress  done today  -  I added the Two front guards  and  continued to fit the  different  parts  around the front.
OC.
Current builds
Completed works.
1 hour ago, FriedClams said:
Nice work on this Abrams OC.  Miss reading your posts on the Waterloo diorama - just taking a break from it?
Gary
Thank you  Gary,    yes  just having a short break  with a few other  projects.
OC.
Current builds
Completed works.
Evening all  not a happy bunny this evening can’t get my laptop to power up thing the charger is dead and the batt is dead
OC
Current builds
Completed works.
Using my old phone to post  with tiny keys  so  fidly
OC
Current builds
Completed works.
Evening all i am still not on my lap to waiting on a new charger to arrive so you will have to bare with me  I have got more done the hull is completed and I have started on the turet
OC
Current builds
Completed works.
The tank is looking good, OC.  As for posting on the phone, there's lots of members who do it that way.  I hope the power supply/charger gets to you soon as the laptop is easier on our eyes, not to mention a bigger keyboard.
