With the deck down in the hold done,I can began building the storage rooms,towards midship the beams are two piece which are milled out then fine tuned with files,not very complicated work to be done but  i ⁹really have to pay attention to where parts of the deck beams cut thru the walls in places.20230311_214405.thumb.jpg.d32efaf00dfbeac831f0e717cc61c030.jpg20230312_143824.thumb.jpg.9120fd7dd3fe9bd322a782bafd37f5d7.jpg20230311_215114.thumb.jpg.a8654d06fd3c5e058998513b7bb2b465.jpg20230311_221324.thumb.jpg.84e996d87406e47eb680ff50375e8295.jpg20230313_223407.thumb.jpg.cb516f6b63b9a95d1919b212e2f4df37.jpg20230314_180247.thumb.jpg.ec87b269edbff6bdff4554d76a3f4035.jpg20230314_220225.thumb.jpg.214a2da2179f326bf081318c2be60e6b.jpg20230318_205912.thumb.jpg.a2a9649c2558e8c550aabd4fdb385b7a.jpg20230318_205937.thumb.jpg.401c80dba173cbb043b4857643b45ee8.jpg20230318_210020.thumb.jpg.9939ef09f330bf00e37dec30b78127b1.jpg20230318_210057.thumb.jpg.3ff4214c78f1e49c9bc548d0891def9b.jpg20230318_210115.thumb.jpg.4593f8765b295006c94c56e880df6ada.jpg20230320_215534.thumb.jpg.293892a937c8b729d1bbcdfeb252fd0c.jpg20230320_215544.thumb.jpg.39cdef6b75efc74e1f0c5c6ff17408b2.jpg
Edited by native one
Wrong wording
finished all the storage rooms in the rear of the hold,then milled out all the two piece beams midship, still need to mark out and cut in all the notches in the beams for the carlings, began working on the storage rooms in the forward part of the hold,alot of metal work in this area because of the four doors in this area.20230331_073029.thumb.jpg.8893870fce1c636026282d4e0e682688.jpg20230331_073000.thumb.jpg.3c661045e6f5ce13dac6156ea8292251.jpg20230331_072845.thumb.jpg.d02e50e22658511bdb11b0ac41988231.jpg20230401_201138.thumb.jpg.120059eeebe5b5fb68cba4d6eb1c169a.jpg20230401_211852.thumb.jpg.15ce31f259dc380b9a8e5c1081aa6652.jpg20230401_211939.thumb.jpg.ccc192a70ee96c941af720fabfab9ddf.jpg20230401_212004.thumb.jpg.5ddb19690dfa0e62d918a84ccecd658e.jpg
  • 4 months later...
  • 2 months later...
After a long break due to my job and the days getting shorter I am back in the shipyard able to continue on the Mahonesa's, filled in the planking between the gunports and continuing with the deck beams of the orlop deck,and finished up the storage rooms in the bow of the ship.20231114_200616.thumb.jpg.8ef00e622084d034c13604efa4ed279d.jpg20231114_200644.thumb.jpg.54a2c21c3ea446d2a194d862ab7a978b.jpg20231114_200832.thumb.jpg.86d6c9459160c3cce3f0c22356cc9595.jpg20231114_200944.thumb.jpg.b61608ff55697c49af8d0b79b32ad121.jpg20231114_200954.thumb.jpg.518e69f612fd077d18f6b7e1036f0458.jpg20231114_200552.thumb.jpg.96f3bde55b3553c1d56419b40aa4b112.jpg20231114_200658.thumb.jpg.15b08e7db0d0950515c9c53644583e8b.jpg
  • 5 weeks later...
Before starting on the decking of the orlop I decided to plank between the waterway and spirketing in the stern of the ship,kind of a tricky task on the Mahonesa's because the waterway starts out nearly flat then makes a gradual climb towards the deck clamps,the bend of the planking in the stern area is so much that I had to make templates for every piece then cut each piece out of thicker material then sand in the curve top and bottom before fitting them in place.20231229_232942.thumb.jpg.8e8f72165626ee7e2c3d4aa20058312c.jpg20231229_232758.thumb.jpg.c1d48a961507caa4e31a34358d4dc567.jpg20231229_200210.thumb.jpg.c5b492dc33c4ea3cf8fed037be099619.jpg20231229_200202.thumb.jpg.8cba0fc60a34b148c6f782786fce2270.jpg
Your work is absolutely fantastic, great job you are doing.
Greetings Tobias
Member of the:  http://www.arbeitskreis-historischer-schiffbau.de/
On the workbench:
Corvette La Palme (L'Amarante) from 1744 POF based on plans by G.Delacroix
https://modelshipworld.com/topic/32046-la-palme-by-tobias-136-pof/
LE ROCHEFORT - Harbor yacht from 1787 1:36 by Tobias (monograph by G.Delacroix)
https://modelshipworld.com/topic/34810-le-rochefort-1787-by-tobias-136-harbor-yacht-from-ancre-monograph/
Le Coureur - Kit from CAF with the plans from Ancre
https://modelshipworld.com/topic/29843-le-coureur-1776-by-tobias-caf-148/
Finally came to an decision on how much deck I was going to leave off,just enough so you can view some of the lower deck structure but I retained enough in the stern area so when I get around to building the bulwarks and quarters there will be enough decking underneath to give them support,now for the tedious job of nailing the deck off.20240218_154838.thumb.jpg.5fdecae3b2a128063f3f2e8d1ce51414.jpg20240218_160051.thumb.jpg.fe5d0d51e115218f69b6756787179f68.jpg20240218_160006.thumb.jpg.c121f28eab02e7eda1241fa96799286f.jpg20240218_160104.thumb.jpg.8a4cb5a9c0372e32980de0d6af66a899.jpg
Finally finished planking the interior of the hull,then proceeded to the stern to began building the bulwark that separates the gunner room from the rest of the officers quarters, then realized I  need the deck beams temporarily in so I can build the  walls of the rooms up to and around the beams.20240312_065603.thumb.jpg.ee3ced1288bb420eeaa365a50c53f4f1.jpg20240312_065539.thumb.jpg.587fc635694c0c0dd668a8e3c90c9195.jpg20240313_203327.thumb.jpg.f12b72da790c409b5368b88d40ae9691.jpg20240313_203747.thumb.jpg.443a6f09975c4b38f937c79146e75189.jpg20240316_213835.thumb.jpg.8a5d6b1a1a3968372c40836ba465fcf8.jpg20240320_212207.thumb.jpg.92f4451d2f7e1b2eae50b9a07ef123da.jpg20240320_214525.thumb.jpg.b851e686b1ed6f49dfe364389867cdcf.jpg20240320_215120.thumb.jpg.54742764cbe7487b9a02d73a0f2785c9.jpg20240320_215421.thumb.jpg.8720dbf8bac8fe2b6452de3bb89317fa.jpg20240323_221956.thumb.jpg.2728625f99a1f2058d4e0b09a962ea0f.jpg20240323_221941.thumb.jpg.4a02df7437a13ca58da0e38239c11e6e.jpg20240323_222032.thumb.jpg.5bbb69fa1555fc5e5730c5039133a6e5.jpg
  • 6 months later...
Cold weather has come around in my part of the world,so time to pull the dust cover off the Mahonesa's and resume working her,not much has been done,still working on the gundeck beams and building the gratings,need to build a different stand so I can mount the rudder and began working on the tiller and sweep.20241103_183954.thumb.jpg.10d824fdde1d6e9d08e660bf16c4948a.jpg20241103_184005.thumb.jpg.86d1201b0133c147630a135f9112a356.jpg20241103_184009.thumb.jpg.4fe881262ffeb27a936b7f8ab85bd212.jpg20241103_184034.thumb.jpg.9105b91377f731ead4234ad87f939368.jpg20241103_184045.thumb.jpg.dab14a71ed2ea61faecffc2dbf4c1761.jpg
Been working on the getting the ships steering put together,made up the pulleys and some scale rope, made the ships steering wheels drum and positioned it where it would be so I can get the rope tension right,everything seems to line up and now I need to make the tension pulleys that run down the side of the tiller ,I deviated on the plans a bit on the first set of pulleys that are right under the orlop deck,they called for them to be set parallel with the center line of the ship but everytime I put pressure on the line the rope jumped off the pulley,so I decided to give them a slight offset, now the lines run alot smoother back to the second set of pulleys. 20241225_193112.thumb.jpg.2311ba5cd0851f7f3d6b6bf7d55f8844.jpg20241229_163124.thumb.jpg.3636eb6b7fe515ecbd1ff22282e33340.jpg20241225_192843.thumb.jpg.2ddfb65cc596fa6af2c00b26ab616bf2.jpg20241225_192832.thumb.jpg.4b618c0299ed4f2d0637c8ba8b04ecbf.jpg20241225_192905.thumb.jpg.678a574a960f2df40133c9eb62e89c9f.jpg20241225_192900.thumb.jpg.3b416e4564c8f0eab41c2530382fda7b.jpg
