I just found your build of this lovely model, Paul, and your work is stunning as usual. The AYC looks great too. It's such a wonderful wood to work with. I'll be following along. Good luck!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Paul this is coming along beautifully. I can’t wait to see how the stern works get finished up.
Ian
Hi Everyone, thank you for the very nice comments and Likes. The jig that holds the tombstone in place underwent a revision. A strip of wood was glued on to give the bottom strakes something to rest on. A strip of wood was clamped to each side of the jig to keep the planks from rising up and a Ty-rap was used to pull them together.
The planks in the next strake were cut out of a 5/16” wide strip. The plans/ directions say that a stealer would probably have been used between the two strakes but I took the easy way out and put it on top. It was cut from 1/16” sheet. This is where the clamping derby started.
764DFB23-9D3B-405F-AC45-A61720BA1293.thumb.jpeg.a84c7cdaec17a5ef54448184fb3ee85e.jpeg8C121787-2716-4F33-B623-AD9A957A01E7.thumb.jpeg.16b244448e94eb127773b2d8c68891af.jpeg
The inside of the stern was framed and then I started checking the fit of the seat of ease which will be made later.
A few jigs were made to assist in cutting the stanchions to the proper height.
Then came lots of sanding and a coat of w-o-p.
The cap rails are going to be painted so the kit supplied rails will be used except at the bow where they don’t match. Hope to see you next time.
Best Regards……..Paul
Amazing! Work like yours makes me think we need a third major category for semi-scratch built build logs.
Current build: Armed Virginia Sloop
Previous Builds: , Amati Fifie, Glad Tidings,Bluenose II, Chesapeake Bay Skipjack, Fair American, Danmark, Constitution Cross Section, Bluenose
Hi Dsmith, thank you very much for your kind words. I keep thinking that it would be nice if more kit makers would sell their kits in stages.
She's looking really nice Paul! Love the deck configuration
hamilton
Hi Everyone, thank you so much for for all of your wonderful comments and Likes. The seat of ease was completed. The base was made from seven pieces because I found it difficult to get measurements for the notches around the frames. So many angles in this area. The cover will be closed so there is no hole in the base.
The first set of knees that I made ended up being too short so two more were made from 1/8” x 1/8” strips. Then they were glued and pinned into place.
Turns out that none of the kit supplied cap rails played well with the way I installed the stanchions so new ones were cut  from 1/32” AYC sheet. The two layer method was used to make the cap rails mostly because it’s a lot easier to cut 1/32” thick pieces from the sheet with a knife. The first layer was glued to the stanchions with CA and pinned with copper wire
The second layer was glued to the first layer using white pva
The first layer just butts together at the joints and a scarf joint is cut into the top layer.
Then the outboard edge of the rail was sanded flush with the outer face of the bulwark strakes. A compass  was run down run down the sanded outboard edge of the rail to mark the inboard edge. The rail was then cut and sanded back to this line.
Next comes making a stand for her. Hope to see you all next time.
Wow - so nice! You're making me want to build this model again! Love the look of the natural wood tones
hamilton
Amazing detail,very nice ship. Someday I hope I will be able to plank like you ,very nice job.:10_1_10:
   Bob M.
Edited by Knocklouder
More info
                   WASA
                   USRC Harriet Lane
Ian and hamilton, thank you very much. The other day I was routing around on the Maine Maritime Museum web site. They have a nice set of plans for the Pinky Schooner Maine that they finished building in 1986. I think that for my next model  I would like to try building something like that. A POB model just from a set of plans. So many nice boats out there.
   Bob M.
Thank you Bob. You are doing a great job on your builds. I enjoy looking at your posts because you are always having so much fun!
Thank you very much No Idea and bobandlucy. There’s a little bit of wonk in her but nothing too serious 😀
Hey Everyone, hope you are all well. Thank you for the great comments and Likes. I decided to get going on the metal work for the rigging. There are four turnbuckles attached to the bowsprit. From what I’ve read turnbuckles we’re used when using wire rope and lanyards were used when using rope. The plans say to use black rope for the inner bobstay and the bowsprit shrouds that are attached to three of the turnbuckles. I thought about looking for some light grey rope to maybe simulate wire but I have dark brown and will go with that. These are the kit supplied frames for the turnbuckles.
I tried drilling the holes for the screws but it didn’t go well. Changed over to 1/16” brass tube.
The shackles have gone through a few revisions. Started with 22ga copper wire then changed to 24ga to try and get them slimmed down a bit.
Low temp soldering paste was applied to the whole assembly and when hit with the flame from a micro torch most of the shackle was tinned
This version of turnbuckle was glued together with CA. There was just as much drama with the bobstay brackets attached to the stem. They started out being soldered but then I ended up gluing the brass nails into the brass tube. When I look at the photos they look like they could be smaller but when I go over and look at the boat they look okay. The wire sticking out of the lower bobstay bracket is for attaching the chain.
Surprisingly the kit supplied cat heads fit really well.
Made a jig to hold the bowsprit bitts while gluing. This is when I decided to do something about the slots that were cut into the hawse timbers. They were not shaped very nicely. They were filled in and hawse holes were made instead. Fortunately this is a pinky and there’s lots of leeway 😀.
A hole was drilled under the hawse hole for the eye bolt for the foot ropes but it looked like it would interfere so a bracket was made to be able to utilize the hole while moving the attachment point aft. The bowsprit was attached and then the windlass. The anchor chaffing bars on the cap rails are made from 1/32” AYC that was sanded as thin as possible and then painted with Tamiya Dark Iron.
The tiller was cut from a sheet of 1/8” Cherry. The detent (?) plate attached to the side is a piece of laser board.
Next will be completing the deck furniture. Still need a binnacle, pumps, stove pipe and maybe a barrel. Hope to see you soon.
Happy Boxing Day Everyone, hope you all had a Merry Christmas. As usual I didn’t do what I said I was going to do. Ended up working on both masts. The kit comes with 3/8” basswood dowels. Started by making a tenon to fit into the deck opening.
Used the tapering method where you blacken with pencil the area that you want to remove material from ( so that you know where you have planed) and then plane that area. Starting with a few inches at the top, blacken and plane.
Each time you blacken, add a few more inches down the mast.
When you get down to where the tapering stops, start back at the top and repeat the whole process again until you have the amount of tapering you need.  Eventually you will work your way back up to the top as the lower mast has enough taper and you end up at this point.
 I ran 120 grit sandpaper up and down a few times between planing if needed and finished with 320 grit paper. Probably 90% of the material was removed by the plane so very little saw dust. Then gave the masts a test fit.
Both masts have the same number of cleats laid out the same way. Located the fore most cleat and marked the mast. Ran a piece of tape from  that mark, around the mast and back to the mark. Removed the tape and stuck it to a ruler. In this case the tape was 30mm long and needed to be divided into six sections so it worked out pretty good. Stuck the tape back on the mast and laid out the holes for the rest of the cleats.
The mast coats and the main boom rest were all made the same way. Two pieces of 3/64” plywood were glued together. 3/8 holes were drilled in the plywood and the rest was all sawing , cutting and sanding.
The throat halliard lead blocks were made by sandwiching a 1/32” strip of wood between two 1/16” strips.
‘The cheek block was made using a Technell 3mm x 1mm brass sheave from The Crafty Sailor and 1/16” brass strip.
The main mast gets a test fit.
The fore mast has a gooseneck mounted for the fore boom. It was attached with CA. Brass nails are used to simulate the bolts holding the two parts together. The kit supplied pin that sits in the gooseneck disintegrated when I tried to clean off the flash so a new one was made with 1/16” brass tube. The top of the tube was squashed, shaped and drilled. A ring made with #24 copper wire was glued just under the flattened part to keep the pin in place.
The fore mast gets a test fit.
Finished stepping the masts.
Have a great New Years and I hope to see you in 2023.
Hi Everyone, Happy New Year to all of you. Thank you very much for the Likes and comments. The fore boom and the main boom have been made. I substituted the supplied dowels with AYC square strips. The fore boom was made with 3/16 x 3/16 strip. First turned into an octagon then rounded and tapered.
A new bracket was made ( from brass ) to attach to the pin in the gooseneck because I didn’t trust the supplied one to not disintegrate like the supplied pin  did.
Next the main boom was made using 1/4” x 1/4” AYC. The supplied jaws were glued and pinned with 22 gauge copper wire. As much rigging as possible will be done before it is mounted.
The deadeyes were made using rings cut from 1/4” brass tube.
The rings are sanded down on 320 grit paper using a push block that has 150 grit paper taped to it
Dividers were used to start the shaping process and then switched out with round nose plies and needle nose pliers to complete the shaping. The whole thing was dropped into the blackener. Not sure how they managed to do it but no matter which way the deadeyes are oriented, the holes are skewed.
The plans call for the strops to be bolted to the chainplates but I went for this simplified version. I was just glad to get them all mounted to the boat.
The binnacle has just been started so I want to get that mounted before the booms are attached. Hope to see you next time
Hi Everyone, hope you are all well. Thank you for your Likes. They are very appreciated. I’ve been working on booms, gaffs, deck furnishings and rigging. So a bit of everything. I have been watching an excellent YouTube video made by Outlandish Marine called “ The Schooner Prophet: Camden to Rockland “. It has shots of many interesting details so I’m taking cues from some of them. First up is the binnacle.
Next came the pumps.
Once they were mounted the booms were finished being rigged as much as possible and then mounted. The main boom’s clapper is pinned to the end of the boom with #22 wire. A piece of insulation is between the clapper and the boom let’s the boom flex a bit if needed
Then the fore boom was mounted and rigged.
The supplied water barrels were too big for where they were to be mounted so a new one was made. This is what I was going for.
There was a lot of scrap left over from the mast hoops. Nine of the plywood disks were glued together and covered with 1/16” strips of AYC. The back corners of the strips were relieved to let them fit together more closely.
The hoops are made with art tape. Gave it a test fit on deck. Not sure if there’ll be one made for starboard. The gaffs where mounted in the same manner as the booms.
Getting close to completion. Just have anchors, stove pipe and a bit of rigging to finish. Hope to see you next time.
Hi Everyone, hope you are all well. Thank you very much for dropping by and for the Likes. A bunch of little things were cleaned up this week. The stove pipe was made with 5mm aluminum tubing. A 4mm dowel was pushed into it and glued with CA. A pin was inserted into each end of the dowel for pinning to the deck and for attaching the T-piece at the top of the pipe.
Stocks were made for the cast anchors. The anchor section in Chapelle’s American Fishing Schooners shows an anchor from a large schooner so I used some of those details when attaching the stock to the shank.
The dreaded ( for me ) rope coils were next. Cotton thread was used to tie the top of the coil through the loop and the free ends at the bottom of the coil
Drill bits were used to weigh them down while they had diluted PVA brushed on them. Three coats were applied over the course of a day
They still need a bit of shaping. Then the stack was glued to the deck.
Belaying points were finished up and the firkin was lashed down
Foot ropes were added to the bowsprit. The gaskets are still being coated with PVA to convince them to hang a little nicer.
Now it’s time to start on the port side. Take care and hope to see you soon.
Edited by Paul Le Wol
