Ras, I am so envious of your skill. I have all the tools, (lathe, milling machine, soldering unit, etc.) but lack your skill. I'm 67 so I have time to improve.  I think the brass and all the detailed work truly makes for a great focal point and just looks fantastic.  Your model is a great inspiration to the many of us that lack the skill but can dream. Keep up the incredible work.
Thanks to all for the likes.
To Keith: I have the same thoughts often but never build anything twice. I take the mistakes as lessons for the future.
To Daniel: I joined this forum in 2019. At that time I operated with a +/-1.0mm tolerance. But by watching other people's work I was inspired to try harder and try to control my shaky fingers. I remember and advise from my shooting coach: "aim large = miss large; aim small = miss small". Since then, I have reduced my to tolerance to close to 0.5 mm. I still have to do a lot better to match guys like Valeriy and Wefalk.
Ras
Current builds:
USS SAN PABLO-1920-1/64 scale-River Gunboat
Previous builds:
Stern Paddle Wheeler ZULU-1916-1/48 scale
Freccia Celeste-1927 350cc racing motorcycle-1:9 scale- Protar kit
Boeing B17F- 1/72 scale- Hasegawa kit
HMS Mimi-scale 1/24-Fast Motor Launch
Amapá 1907-1/64 scale-Brazilian Customs Cruiser
Scottish Motor Fifie. 1/32 scale. Amati kit
Patricia. Steam powered R/C launch. 1/12 scale. Krick Kit
African Queen. Steam powered  R/C launch. 1/24 scale. Billings kit
Emma C. Berry. Sailing fishing smack. 1/32 scale. Model Shipways kit.
This is what Zulu will look when all parts are put together.
After this photo, the paddles were painted and the engine mechanics and the steam piping was completed . First , the eccectrics.
Then the pitmans and the fitting of the cross tree in the engine cylinders.
An overhead look at the piping fore and aft.
Currently working on installing the buckets (aka paddles) in the wheels. Thanks for the likes and comments.
Ras
Current builds:
Previous builds:
Nice progress Raz. The steam pipes must have kept the cabin warm.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
4 minutes ago, wefalck said:
wasn't the boat operating in a tropical climate?
I was trying a bit of irony.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Have to say that there was another build (I think Peerless) where the insulating of steam pipes was discussed. In Zulu the steam pies are supposed to be 3" (at scale would be 1/16"), the insulation would be 1-1/2"(at scale 1/32") with a total of 3/32" outside diameter. The tubing used is just that: 3/32". Therefore, consider the pipes are insulated and painted brass. 😏
Ras
Current builds:
Previous builds:
4 hours ago, wefalck said:
winding cotton thread around the wire and soaking it in varnish:
That works well Eberhard. I will bank it for later.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Maybe I am getting lazy in my old age. I agree with Wefalk on his system. I have used before.
The African Queen
And Krick's Patricia
IMG_6737.thumb.jpeg.608cc3a895d1e96dcf5bdfb112e1bc3d.jpegI have these model on the finished models gallery. They were done many years ago.
Ras
Current builds:
Previous builds:
Thanks Valeriy: you and Wefalk are my models.
Ras
Current builds:
Previous builds:
The construction of the paddles continues. I knew there was some use for those mini-cloth pins.
The finished product.
I am amazed I have not heard from any of my followers about the fact that the paddle wheel cranks could not complete a revolution. (See post # 94). While  building the hull I used two solid wood pieces to make the sponsons. I didn't realize that the cranks will actually rotate below deck. So I just painted a hole in the deck since this is a static model. Hope you don't mind. More forethought in the next build.
So here is the final setup of the propulsion gear.
To be continued.
Ras
Current builds:
Previous builds:
The main construction is done and now it is time to make the accessories. Some have been built while I waited for paint to dry or glue to set. This week I fixed the railings on the boiler deck and started the dingy. I was going to use the mold I made for Amapá but I had a few Billings ship boats at different scales and checked them out with the plans.
 This whaler hull was just about right.
The stern was cut and a transom made from styrene was added:
The original Billings was modified to match the scale size of the dingy:
An here it is with its ancestor whaler:
Trim and painting will follow. Next the davits.
Ras
Current builds:
Previous builds:
Good progress Ras. I like your repurposing.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
  • 2 months later...
After several weeks with poor progress, today I achieved about 98.5% completion. Missing items are, the mast (stack) position light (that is now drying its clear lenses of gorilla glue) and its rigging. I could not make the decal for the white lettered  "ZULU" for the ships name so I and wound up getting the letters from Amazon. Also necessary will be a check out of the handrails that have been damaged by the fact that I built the railing before completion of other tasks in the corresponding decks. I also used an extremely thin (0.25 mm) brass wire. Should have used thin thread. Also, I skipped the galley stack.
But, I could not wait to show you the "Almost Finished" Zulu.
Expect to complete it early next week and I will prepare an album for the gallery. I thank all you followers for you likes and your valuable comments.
Ras
Current builds:
Previous builds:
Ras, she looks great!
Current Builds:  1870's Sternwheeler, Lula
Completed: 1880s Floating Steam Donkey Pile Driver
Well, here it is. Zulu is now completed. It has taken me one year and four month to complete which is nothing compared with Wefalk and Valeriy builts. This scratch built model of an Indian river boat is now FINISHED.
I again thank all of you for the likes and comments. I learned quite a lot on this built and expect to do better in my next project: the fictional US Navy river gunboat San Pablo during the Boer revolution in China's as presented in the 1966 movie The Sand Pebbles,  starring Steve McQueen.
Ras
Ras
Current builds:
Previous builds:
Ras, congratulations, she's a beauty.
