Sjors
THanks for teaching Bindy that word now I learn also. So if you mean it twice is it pfffffffffffs? Or Spffffffff? I had no idea that was a Dutch word. I am Multi Lingual!
Really looking forward to your next layer of planking, I cant recall will they be spiled?
Sam
Current Build Constructo Enterprise
Sam,
You are very welcome !
Twice Pffffff is........Pffffff Pffffff .....without the S  :P
Maybe stupid question but what is spiled planks ??????
We have take a look at Google translation but they have no answer for me.
I think the best way to show spiled planks is to have a look at Chuck's tutorial on planking here: http://modelshipworldforum.com/ship-model-framing-and-planking-articles.php  (Planking Tutorial - Lining Off a Hull Chuck Passaro)
It's a method of cutting planks - you start with wood that is wider than normal planks so that you can cut them with the curve especially at the bow.  This means you can't use the planks that came with the kit though, since they are already narrow strips. The plank at the top of the photo has been cut to the curved shape, not bent. Hope this helps.
Edited by Sherry
Sherry
Every goodbye is the birth of a memory...
Current Build: San Felipe
Finished Builds: Mayflower Build Log
Gallery: Mayflower
Glad you posted that for Sjors, Sherry.  That's the proper way to do it......and as you said, you need to start with planks wider than those supplied in the kit.
Since spiling is generally carried out at the bow to eliminate crowding, there is another method, also advocated by Chuck in his kits, which I use..... a kind of 'poor man's spiling'.  If my kit-supplied wood is , say, 1/8" wide, I determine the number of planks needed at each bulkhead for a particular band I'm planking.  In the center, that might be (for example) 20 planks.  As I move forward that number gradually decreases until, at the bow, it may be only 12 planks.  That tells me I need to taper, or spile, each plank gradually down so they will all fit up front.  I'm ignoring drop planks here.  So, 20 X 1/8" = 20/8 but I need only 12/8" up in the bow.  So I need to 'lose' 8/8".  To do that I taper each of the 20 planks down from 1/8" to about  3/32".  That gets me in the ballpark.  That taper runs from the tip at the bow back along the plank about 3 " (assuming I'm using 4-5" planks).  Sherry's photo shows this taper (it also shows the plank edge bent).
I had some photos of this in my Confed log but they were lost and I don't have them anymore.  However, Chuck does provide an explanation in his instructions for Confederacy which are available on the Model Expo site here:  http://www.modelexpo-online.com/images/docs/MS2262/MS2262-CONFEDERACY-Instructions%20-%20WEB.pdf.  You would need to thumb through the pages to get to the planking section.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Thanks Sherry and Augie,
I know now what Sam means......
And Sam ?, I don't have them.
The first picture that I opened at that tutorial from Chuck gives me the warning in red...Avoid this !!!!!!!!!
So I'm not at the bow yet so....lucky me  :D
I have to use drop planks........
Ok.
I go back to modelling school and see how I can do this.
To be continue !
well,  you don't have to go far........your classroom is right in front of you  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Another Dutch word which we use when we see something beautiful (like this and some other builds): geweldig
Edited by NickvN
Nick :cheers:
Model building Projects in progress:
      - Hermione la Fayette, Artesania Latina:
          - LINK TO Forum (MSW): http://modelshipworld.com/index.php/topic/2649-hermione-la-fayette-by-nickvn-artesania-latina-second-wooden-ship-built/page-1
          - LINK TO Photo album (dutch website): https://modelbrouwers.nl/albums/album/11697/
Sjors, others explained the spiling far better than I could. So I take your comment to mean Chuck recommends against spiling? And since you have narrow planks I guess you wouldnt be anyway. And now thanks to Nick I have doubled my Dutch!
Pictures soon?
Sam
Sam,
No pictures for a while.......
Or I can post pictures of my passengers........
There i no building time but working time.
And beside that.....the weather goes to 20 C , so sitting outside is also an option  :D  :D  :D  :D  :D
Very nice planking, dear Sjors. You made a great job.
Take care and a lot of fun during the work.
Best regards
Doris
Doris
Current build:
HMS Royal Katherine 1664 from card
Thanks Doris and Robbyn,
@ Doris,
The weather is good and I'm at work.... :(
Sitting behind glass in the sunshine....
But it is better then rain !
@ Robbyn,
You have a lot of faith on me !
Maybe to much ?
I will see if I can handle those drop planks otherwise no drop planks !
It's the first layer and all of it will be covered at a second layer and copper plates .
well heck Sjors, if you are going to cover it all in copper, then really who cares if you spile, drop plank, or just cover it in wood filler. no one will see any of that anyway. So unless you are wanting the practice, don't sweat it! For me the Syren will be the same way. When I upgraded to boxwood, I did not spend the money on boxwood for the lower hull that will be covered with copper, seemed like a waste of money to me. I plan to use the kit supplied basswood for that part, and do not intend to worry about splices and drop planks in that area at all. I just want a nice smooth finish, so the copper plates all sit nice and pretty.
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Now, now ..... you never know.  If the planking comes out looking like a fine piece of furniture you might want to leave it natural!  Put in the time so you leave all your options open.
Augie
Previous Builds :
Robbyn,
You are woman at my heart !!!!!!! :D  :D  :D  :D
I went upstairs to take a look and what do you think ????????
I still have to plank !!!!! :P
And I have made a few planks younger, is that counting ????
I was talking yesterday evening with Mobbsie and I show him what I have done and you know what he was telling me ??????
Don't show it to MSW otherwise you went kick of that forum ! Pffffffffff ( Dutch word )
Just kidding.....I have use some filler at some points and .....like a baby skin so soft....( I can't remember how that feels but I like the way how I wrote that down ! ) :D
@ Augie,
Take my word for it.......It's gonna be an other layer of planks and after that there will be copper tiles !
I just want to make myself angry when it is not going as I want to !
Anja always told me that I have to do everything once at a life time so.....coppering is the answer  :D  :D  :D
Sjors, don't get bullied out of coppering :) Although it definitely has its own challenges, you will get a beautiful result I'm sure.  Its all personal taste of course, but definitely not an 'easy way out'....
Cheers,
Jason
In the shipyard:
Copper has it's own charm.  Of course, you're going to do individual tiles so we'll get ready to listen to you for weeks ----- like we did with the ratlines !!
Augie
Previous Builds :
Frank,
I'think it should Be the other way around......Mobbsie has to pay  me when I let him do the copper plates.
He just loves it !!!!!!!!!
Edited by Sjors
what.......and not take advantage of teaching us other Dutch words...........other that pffffffffff!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Yep, time for an update !
Hull is closed with the first planking  :D  :D  :D  :D  :D
Filled and sanded.
You see two colours of filler and that's correct !
First I used wood filler and after that balsa filler.
Don't ask me why but it works just great !
Now she feels like a baby skin.
Still don't know how it feels and no, I don't want a baby to check it out ! :P
To prove everything a lot of pictures !
Also the last two pictures is to show you the size.......
Now it is time to clean up the workroom and go back to the Fonz.
Making shrouds and the last ratlines for a while.
nice job on the hull Sjors.......the second planking should go smoothly for you!  :)   nice to see the Half Moon........she's looking very nice as well ;)   is the log going to continue of late?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye,
Witch log do you mean ?
This one or that for the Half Moon.....
This one is on hold for a while and the Half moon....I don't know.
Anja is very busy with work and late at home every night...
That's quite a comparison.... really shows just how big the Aggie is...... nice job on the hull Sjors looks real good!!
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Thanks everyone !
@ Tom,
Welcome on board !
Before you get boring, this build will be on hold for a while because I have another build going on.
She is screaming of a bit of attention  :D  :D  :D
So it's rigging time again for the San Ildefonso.
