I think this will be the start of a number of fairly short builds as I explore the contents of a rather large collection of Eastern European kits bought on a whim because of the uncommon subject matter. Mikro Mir, Dora Wings, IBG, Amodel and Roden are all likely to be showing up in various guises.
So first up is the Mikro Mir 1/44 scale Holland Class submarine; the Royal Navys first venture into submarines at the start of the 20th century
Not very many pieces but lso very little flash. No location holes / tabs but the pieces fir together very well and the hull and deck pieces joined together without the need for putty or excessive sanding.
At 63 feet long with a crew of 8 they must have been cosy little crafts
I have built up everything in the kit except for the PE bilge keels which will interfere with the masking
I used Mig One Shot black primer and then added some white to try to bring some variation into the dark grey top coat
So far it has been entirely enjoyable. The paint scheme will be light grey uppers and dark grey lower. I plan to display it on my usual submarine base of an acrylaic rod and a simple sea bed.
Thanks for looking in.
Alan
Another Great little build  mate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
17 hours ago, mikegr said:
i see some white spots. Is this a desired a effect? If not may need to regulate your airbrush possibly the spitting effect is created by thick paint
Thanks Mike
The air brush did spit a little; I'm not sure if its getting too hot in the garage where the painting takes place. Maybe I need to add some retarder.
Alan
I masked the hull and sprayed the light grey upper hull colour. The masking produced a nice crisp line. I added the PE bilge keels which will need to be painted and then I will add some rust and washes to bring out the detail.
I painted the seabed and that is now ready for submarine
Thanks for looking in and the likes and comments
Alan
That paint job looks very smart Alan.
Andrew
Completed (Kits):-
Really nice work Alan.
OC.
Current builds
Completed works.
Well done Alan a neat little project!  :imNotWorthy:
Andrew
Completed (Kits):-
That looks  Excellent Alan,   I love  it -  you  should  be  proud  of what  you  have done there.
OC.
Current builds
Completed works.
