Indeed, a great looking SPAD. Nice job on the rigging and the faded paintjob.
Cheers Rob
                             Duchess of Kingston - paused
                             USS Arizona 1/350 Eduard
1 hour ago, CDW said:
most challenging
Almost everything that modellers expect.
- Bad mould : lots of scraps around the edges
- 3D printed-like kit design : no gimmicks for easier assembly.
    No positive and negative tips for two surfaces. This isn't the comventional LEGO like assembly, but rather stacking plastic blocks without any guide.
    After stacking all the parts, I found the skin of the hull is twisted and there are many gaps around the skin parts. It happened frequently when I did hull planking.  :)
    Parts are divided unnecessarily. Determining painting color may be difficult.
- The worst water slice decal : Not clear color. The material tears easily. When I pasted the bird on the side hull, it split into 6 parts. 😞 I gathered each part carefully.
There are several great build logs in largescalemodeler.com.
Also, please read the manual carefully. Read the paper backwards from end, so that you can imagine a clear position of the tiny parts.
I'll try the SPAD XIII again with the Trumpeter (Merit) 1/24 scale kit.
Edited by modeller_masa
Yes, a not very well done limited production. I think Popeye had issues with some of the Roden kits he's built.
Ken
Started: MS Bounty Longboat,
