With the currents in most rivers and the obstructions such as sand bars towing on the rope does not provide the control needed to thread one's way through the average river obstacle course.  With the boat behind and a solid link to the barge, the towboat can set up to push through the turn as a single unit rather than trying to get a towed barge through the same space.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
19 minutes ago, Keith Black said:
Pushing or what's called towing must be more efficient as it seems to have been the preferred method of transporting barges due to the amount of historical photos.
There's only really three geometries to attach a barge to a power source: front, rear, or side.
Towing behind the power source didn't develop because early vessels were sternwheelers, so the wheel gets in the way. Even when propellors came along, same problem: tying up a load at the stern messes with the propulsion and rudders. Whereas towing on any kind of line gives you almost no control on a winding river.
Side can work, but you need a wide channel for that, and at the scale of most North American loads, you wouldn't be able to do more than a few barges. Plus it puts a lot of shear stress on however you attach the load to the side of the vessel.
Front gives you all the room in the world, keeps the load away from the propulsion and rudders, gives you a lot more control, lets the force be a direct push into the load, and lets the pilot watch the load. How many people pull a shopping cart instead of pushing it?
The fascinating difference I've seen between North American and European riverboats is that North America seemed to develop separate vessels for power and load (think towboat with barges) whereas so many European riverboats are combined, like small freighters. No idea why that difference developed. Eberhard?
Kurt
 Thank you, Kurt. i was just coming back to edit my previous post and say that is was easier getting through narrow channels by tow pushing as the two would be single wide.
Edited by Keith Black
Current Builds:  1870's Sternwheeler, Lula
Completed: 1880s Floating Steam Donkey Pile Driver
  Thank you, Eric. You posted whilst I was answering Kurt. I like your explanation much more than mine.
Same for me ... posted too early or too late.
I think there is a lot of tradition involved in Europe. You N-Americans seem to have been much less inhibited by traditions.
Push-barges didn't came into use on European rivers (mainly the Rhine) until the 1970s or so. Before it was side-wheel or propeller tugs with a tow of a maximum of four to six dumb barges. On Eastern European rivers, that were less well-regulated, wheels seem to have persisted longer, though quite a bit of research had been going on to improve screw populsion in shallow waters through putting the screws into tunnels.
One river on which sternwheels have been used for quite some time was the Rhone, but not for tugs, but for fast packets.
No idea what reasons where, why they kept for so much longer 'towing' than pushing.
4 hours ago, Keith Black said:
12 hours ago, Cathead said:
Keith, that all looks so good! I have one question: in my eye, the angle of the stairs looks a little shallow (close to 45º). So many shipboard stairs are quite a bit steeper, to save space, and my eye says that those on the original Lula are also steeper (more like 60º or more). Also, at the current angle, they look like they'd need some vertical bracing halfway along because there'd be some bounce or sag in that long horizontal run. To my eye, on-board stairs like these should straddle the line between ladders and "normal" household stairs.
So I'm curious about the thought process here. And since you said they're not attached yet, it's a good time to ask!
 Thank you, Eric. I tried matching the angle in the original Lula photo. I'll recheck and also see if I came make the stairs steeper as that would save me space but I want the stair angle to be such that someone could walk up and down them and not have to use the handrail.
 Eric, currently the stairs are at 45 degrees. Setting the stair angle to 60 degrees only gives me an additional 0.175 inches of increased space at the ladder base. When I'm able to get back to work on Lula I'll look closer at the additional saved space and see if it's worth making the change. Thank you again for bringing this to my attention.
11 hours ago, FriedClams said:
Looking really nice, Keith!  I bet that girl frothed up some water getting some of those loads moving.
 Thank you, Gary. I bet sternwheeler tugs did toss up a stream.
Not withstanding the angle debate, the stairs are very nicely made but on the photo of Lula they go up the side of the deckhouse. I have clearly misundersood something along the way.😕
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
 Thank you, Keith. The stairs are off the shelf plastic ones I bought from Cornwall Model Boats seven/eight years ago and I have used them on both the Tennessee and the pile driver. My apologies if I hadn't made that clear years ago.
 It's true that in the original photo of Lula the stairs went up the side of the engine room but if on the model I ran the stairs up the side of the ER a crew member couldn't get around them to get to the stern. And you say, "use the maintenance doors". I always look at crew having to get somewhere fast in the case of an emergency. I try to create direct paths to all parts of the ship as much as possible, Thats the reason why the stairs were moved the the fore ER wall.
Ah! I now understand, you are building the debugged version.🙂
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
You are being too kind to the crew Keith - a good flogging to drive them up steeper ladders/stairs should be the order of the day ;)
Seriously though, Lula is coming along nicely, great work.
cheers
Pat
Edited by BANYAN
 Thank you, Keith. Trying to. :)
 Thank you, Pat. I'm a pretty easy captain, I like a happy crew.
 Thank you for your comments and likes.
 Everything seen in the photos below is attached. Lula is 90 feet from bucket edge to knee face.
 I added cleats, fairleads, and bollards. In the original Lula photo the only deck fitting seen is a white painted cleat so I painted all the deck fittings white. I scraped up the wales and knee faces, no photo of the knee faces this time round.
 I plumbed water lines and ran the steam pipes to the engine room.
 What a tricky bit of nonsense that was, 24 GA brass wire deforms so easily. It's 1.20 inches from the foremost steam pipes to the engine room fore wall591BD24D-2267-4BA4-AA46-F4027CB15DFB.thumb.jpeg.d6687d93eb1f17f1f9b39f9febb20229.jpeg
 The water lines are visible in the next two photos
 I was going to run the exhaust pipes forward but after thinking about it, having the exhaust forward might cause visual complications for the pilot. It makes more sense to run the exhaust out the top corners of the engine room aft wall which I'll add at some later point in the build.
 Thank you to everyone for your support and being part of the journey.
   Keith
What is the plan for the fore deck Keith. It looks like a great space for stack of piles.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
 Directly fore of the boiler is the coal bin and fore of the coal bin is a derrick crane. Pilings were barged to the site, at some point I'll need to add a pile barge to the fleet.
10 minutes ago, wefalck said:
So no condenser fitted? Or a boiler feedwater pre-heater?
Do the steam-pipes get some insulation? I could imagine, that in winter one would get a lot of loss of pressure and condensation.
 Eberhard, condenser system requirements are much too costly for a gyppo operation like Lula and no preheater either. The white painted wire represents insulation.
1 hour ago, Rick310 said:
Really coming along nicely Keith
Really enjoy following your build!!
 Thank you, Rick.
Your supply boat is looking great Keith.  I'm playing catch-up so trying to type fast and get caught up.
The water and steam piping turned out very nice, Keith. Tricky indeed and fiddly as well, especially in 1:120.
I mostly use phosphor bronze wire now instead of brass because it’s harder and resists kinking and slumping. Tichy Train sells the stuff in 8” and 3’ lengths - .008” up to .04”.  Just an FYI.
Gary
Completed Scratch Builds
 Thank you, Mark. It's great to have  you back.
 Thank you, Gary. And thank you for the heads up regarding the bronze wire from Tichy Train.
  Thank you to everyone for your comments and likes.
 A quick update.
 There are no more deck element paper cutouts, all items are now in place and glued down with the exception of the derrick crane mast which is just loosely placed. The crane requires a lot of work before being permanently installed. I also added the steel floor with bumpers between coal bin and the furnace. 3B7B8928-DB35-4392-99F7-952C42AAC80F.thumb.jpeg.d5a6168e33dbddbc27df52456646392c.jpeg
 Little Lula has lost most of her resemblance to a car ferry. In the below phot you can see where I stuffed up the knee faces.
 Thank you folks for for you support and following Lula's journey.
   Keith
Awesome work my friend.     :cheers:
"Start so you can Finish!"
In progress:
Astrolabe 1812 - Mantua 1:50; Golden Hind - 1578-Air Fix.
In queue:
Pegasus - Amati 1:64
Completed:
The Dutchess of Kingston - 1:64 Vanguard Models 🙂
Santa Maria - 1:64, La Pinta - 1:64, La Nina - 1:64, Hannah Ship in a Bottle - 1:300, The Mayflower - 1:64, Viking Ship Drakkar -1:50 all by Amati. King of the Mississippi - Artesania Latina - 1:80  Queen Anne's Revenge - Piece Cool - 1:300  The Sea of Galilee Boat - Scott Miller - 1:20
 Thank you, Bob. It was great seeing you grandson and his first fish, wish you'd gotten a picture of your other grandson holding his first fish.
Hmmm! - stuffed up - a good engineering term - as in "I stuffed up the stuffing box and that stuffed up the ship, which sank.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
 Oh man, I gotta laugh at myself. I'm sorry, please insert scuffed......danged old people.:)
On 3/11/2025 at 9:05 PM, TBlack said:
Yah, but we're classy!
 Thank you, Tom. You are but me, not so much.
On 3/12/2025 at 3:23 PM, clearway said:
That makes more sense Keith- my mum god rest her soul called them 'senior moments'!
 My senior moments are starting to flock like starling.
 Thank you everybody for the kind and helpful comments and the likes.
 I combined the following two diagrams of derrick cranes to make Lula's crane. I feel I'm on sound footing.
 It's been so long since I stropped blocks and did any rigging that I had to send my fingers out to be retrained. :)
 I have 12 inch single and double blocks but not a 12 inch triple that's used on the topping lift attached to the mast. I could have used a double and a single but after mulling it over I went with the 18 inch blocks and have triples in that size. The 18's look a little large but for this application I'd much rather be too large than too small.
 I've got the topping lift line, boom tackle lines, preventer guy, and hook tag line rigged. All four blocks are made for the guy pendents but ran out of time getting them rigged tonight.
 None of the lines are secured though the boom is at its correct angle not making contact with the pile driver.
 Please don't expect to see neatly coiled lines, Lula's lines are going to be a bit messy but safe. i still need to run chain stays for the mast. There are ten cleats forward of the coal bin.
 Thank you for your support and for being part of the journey.
   Keith
