Hello,
last week we had here a lot of sunshine, so I was't realy often at the shipyard. But at least I managed to finished two other strakes. Only 4 left
Now it starts to look more like a ship then a raft.
Regards,
Siggi
Recent build: Gokstad ship (ca900)
Recent build: HMS Tiger (1747)
Captains Barge ca. 1760, scratch build
HMS Dragon 74 gunner 1760, scratch build
Hello and many thanks for your likes and comments
the next two strakes are ready. Now there are only two others left. The uper plank here is the rodrarhufr plank. In this plank later come the holes for the oars. She is a little thicker, 0,65mm.
And here you see also the thick fingers, who build this all 😁
Regards,
Siggi
 Very graceful lines, Siggi. A real beauty.
Current Builds: Sternwheeler from the Susquehanna River's Hard Coal Navy
Hello,
thank you for all the likes and comments. For today only a short update. I finished the collecting planks for the starbord side.
This pice, with the rudder support, was a little tricky. So I build it twice and nead now a medical plaster for my left index finger! But it is't soo bad.
And here it is installed
Regards,
Siggi
Hello, and thank you for all the likes,
and yes I'm guilty. I was't at the shipyard last week. We had here the finest spring weather, with sunshine and temperatures up to 24°C in the sun! 😊
But yesterday the weather changed, and I finished planking with the last two strakes. They are at least only 0,4 mm thick! So as next I will install the gun-wale.
I started with this project last November and planking mid January.
At the next picture you see the rocked keel. I reality the keel was in the middle 30 cm lower then at his outer ends.
Edited by Siggi52
Regards,
Siggi
You've done lovely work on the model, Siggi. When finished will you be placing her in a case?
Hello, and thank you for your comments and likes.
Today I build the middle parts of the gun wales and installed them. The fore and aft parts are more complicated. So I hope they follow over the weekend.
Regards,
Siggi
Hello,
the gun wales are ready. Also the Tingl and the two Rongs at the stem and stern. That was't an easy job, but now it's done.
These battens with slits are carved to the gun wales. For the middle part of the gun wales they where later nailed under these, between the frames. At the SB side, behind the rudder, they where omitted. They where used to fasten the shields, or the tent.
Regards,
Siggi
Such grace and beauty. Just wonderful, Siggi.
Hello,
there is not so much happend here. I draw the nails also from the inside of the hull and glued the cleats in, for those frames you may see later. They are 0,6 by 0,8 mm and 3.5 mm long
Regards,
Siggi
Hello,
and thank you for all the likes.
The two bulkheads at the bow and stern cost me a lot of nerves. You have nothing to lean on. It's all free floating. But now it's done. Here the one at the bow.
And here the one at the stern.
This one was a lot more complicated, because it has to hold also the rudder. When I dryfitted them, they fit all perfect. But when you get a little glue on them, nothing fits. 😐
So all out and try again. The lower parts you would't see later, so I'm here a little more generous with the seat.
And here the carpenters from the Tiger have a look what I'm doing so all the day
Regards,
Siggi
 Incredible work, Siggi. I hope the painter is in leg irons back on the Tiger. :)
Hello Richard,
the planks are glued together. I used white watersolvent wood glue. So I could make later easier corrections. What I had to due more often. The clinker nails are only pencil marks.
Regards,
Siggi
On 3/26/2025 at 2:42 PM, ccoyle said:
I don't think it's too much of a stretch to say that this is shaping up into one of the finest Viking longships we've seen being modeled here.
It's outstanding!
Ongoing:
Hello, and many, many thanks for your comments and likes
Last week we had here an outstanding wether with much sunshine, so I was't very often at the shipyard. But today it rained, and there was really action at the shipyard. I build and installed the first frames. First I would cut the undercut of the frames like those at the originals, but that was too dangerous for my fingers and the frame itself. So I decided to file it insted.
The form of the frames I took from my plug
Glueing them in was the next challenge. Because, the hull was a little out of shape and I must work with a little brutality and big clamps 😉
For the next frames I took a third pair of clamps and all went well.
Regards,
Siggi
