Venetian Carrack or Cocha by woodrat - FINISHED - 1/64
Yes, I've finally got moving after a long period of doing nothing (life getting in the way) and cut my first pieces of wood - see here.
I'm pretty happy with the result, though it's very early days yet.
Steven
Link to comment
Share on other sites
These  show the grapnel hung from the bowsprit and the figurehead similar to that of the Gribshunden wreck.
Dick
Current build:
 Le Gros Ventre 1:48 POF   http://modelshipworld.com/index.php?/topic/564-le-gros-ventre-by-woodrat-scale-1-48-pof-1767-french-exploration-vessel/
Past builds:
Mycenaean War Galley by Woodrat - 1:48 - Shell first Plank on Frame:https://modelshipworld.com/topic/33384-mycenaean-war-galley-by-woodrat-148-shell-first-plank-on-frame
Venetian round ship 14th century by Woodrat fully framed - 1:40 scalCompleted
https://modelshipworld.com/index.php?/topic/17991-venetian-round-ship-14th-century-by-woodrat-fully-framed-140-scale
Venetian Carrack or Cocha 1/64 by woodrat   https://modelshipworld.com/index.php?/topic/4915-venetian-carrack-or-cocha-164-by-woodrat        completed
United States Frigate Essex 1:64 POF   http://modelshipworld.com/index.php?/topic/4496-usf-essex-by-woodrat-scale-1-64-fully-framed-from-takakjian-plans/ - completed
Yenikapi12 by Woodrat - 1/16 scale - a small Byzantine merchant vessel of the 9th century
https://modelshipworld.com/topic/23815-yenikapi12-by-woodrat-116-scale-a-small-byzantine-merchant-vessel-of-the-9th-century-finished/
The Incredible Hulc by Woodrat - an experimental reconstruction of a mediaeval transport
https://modelshipworld.com/topic/25641-the-elusive-hulc-by-woodrat-finished-a-speculative-reconstruction-of-a-mediaeval-merchantman-132-plank-on-frame/
Link to comment
Dick,
Just to get some things clear ... the anchor is attached to the hull with a chain - fixed length - and is dropped with a 'cable' so it can be hauled up again ...
Thanks, Carl. I am speculating here. I am far from clear about this myself. The grapnel is only an auxiliary anchor. The main anchors are much larger. The grapnel may be used for manoeuvring the ship in harbour. I doubt it was used to grapple other ships. The grapnel chain is attached to a cable which is led into the forecastle, maybe through the hawse holes ( i dont believe this now. see posts below).The windlass could also be able to assist and the grapnel cable could be wound onto the tranversal bitt. What is the exact function of the transverse bitt and how is the main anchor cable attached to it? No detailed contemporary pictures show this detail although one picture shows what may be the anchor cable wound around the bitt. This is guesswork but I would appreciate all suggestions. :huh: Dick
Edited by woodrat
Current build:
Past builds:
Link to comment
I wouldn't expect a grapnel for manouvring, sooner a cable of some sort, as the grapnel and chain would appear rather heavy to me ... It does invite some deeper scrutiny ... and these queries do make the build quite a challenge!! I've been surprised by your, and Steven's enginuity ...
Cheers
Carl
Link to comment
Nice work, Dick (as usual).
Landstro"m's book states that the grapnel was for grappling other ships in battle, but I don't know that this was based on anything other than supposition.
However, the Anthony Roll depiction of the Great Harry at the very least, shows her with not only a grapnel on a chain hanging on the bowsprit, but also double-hooked yard arms.  This was after all a time of transition from boarding and hand-to-hand fighting to longer distance combat with the big guns. So perhaps the grapnel is indeed for grappling other ships.
Steven
PS: Where did you get that lovely piece of chain?
Edited by Louie da fly
Link to comment
Thanks Carl and Steven. I have gone back and looked through my picture bank and found some good detail on the disposition of the grapnel.
All of these illustrations seem to show the chain being led into the floor of the forecastle, not the hawse holes (I will change this)
The nice chain, Steven, was a leftover from a kit that I trashed. I waste nothing.
Certainly hooks are seen on later warship carrack yard ends but are not seen on these early carracks.
I remain to be convinced that the grapnels were designed for offensive use against other ships except in extreme emergency.
I believe I now have the answer. Grapnels were a common form of anchor for dhows and other vessels of the Indian ocean and were used to assist mooring in tidal estuaries or tidal flats at low tide. They were also used to help haul the dhow out to deep water at high tide.  (Clifford Hawkins: The Dhow, an illustrated history of the dhow and its world). the dhows suspended the grapnels from the bowsprit and sometimes used chain instead of cable.I believe that this would have been the practice in the tidal lagoons such as Venice where the large anchors could not have been used (as seen in the Barbari map of Venice) :P Cheers
Dick
Current build:
Past builds:
Link to comment
You'll certainly be right, however, I cannot see a grapnel as a reliable anchor considering the grapnel's weight, and minimal flukes which must hold the boat's weight and strain of a tugging sea ... the use for 'displacement' seems to me the more obvious one, or the mooring to another ship in harbour for that matter. At least the 'abuse' of the hawse holes has been determined ...
Cheers
Carl
Carl
Link to comment
For some reason I missed seeing this thread until this morning. Fascinating research and interpretation, Woodrat! You are doing a terrific job in these rather poorly charted waters.
Link to comment
That is most kind in you, Druxey. It is very satisfying to try second-guessing the shades of long dead shipwrights.
Dick
Current build:
Past builds:
Link to comment
I have corrected the placement of the grapnel chain so it does not foul the hawse. I suppose the grapnel cable could still be led to the windlass if needed.
Dick
Current build:
Past builds:
Link to comment
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Link to comment
"Breaking News!" After a lot of fruitless searching of heraldry sites, I believe I have now identified the owner of the carrack in Trombetta's illustration. I believe the flags are those of Doge Cristoforo Moro (1390 – November 10, 1471) who was Doge from 1462 to 1471 which places him smack in the right era
This is his family crest which matches exactly the flags on the ship
post-848-0-01588800-1456495545_thumb.pngthe round things may be pomegranates
this is his portrait
Dick
Edited by woodrat
Current build:
Past builds:
Link to comment
Now that's a nice bit of research.
Link to comment
Looks like a pretty good match.  Are you goingto use these colours in your model?
Yes, sure am. Stripes seem to be blue and white. I will also include a lion of St. Mark on the quarterdeck.
Dick
Current build:
Past builds:
Link to comment
That's a really good discovery, Dick. Adds that extra special something and, I think, adds to the meaning of the model to know who it belonged to.
By the way, I notice there are two small copies of the coat of arms at the bottom of his portrait, as well.
Link to comment
here are some pics of the stern gallery. I have left some blinds down and some up (coloured blue).
Dick
Current build:
Past builds:
Link to comment
Thanks, George
Current build:
Past builds:
Link to comment
Amazing work, Dick !!
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Link to comment
Nice details on the stern cabin. I like the blue blinds
Thanks Carl and Steve. The blinds are meant to hinge up out of the way. You can also see them on the Matthew reconstruction.
Dick
Current build:
Past builds:
Link to comment
What a great looking stern.   The blinds add just the right touch.
Link to comment
Thanks chaps. I still have some deck furniture to do before I can tackle the rigging. The perennial question remains, furled or not furled. :unsure:. I am tending towards furled as it would be a good way to depict how they raised the bloody great ponderous mainyard by muscle power alone!
Dick
Current build:
Past builds:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
