Much thanks also for all the likes at first
Hi druxey
Sometimes I'm to be to hasty but I give my best to have more patience.
I would like to taper the thickness of the wale when the black strake is fitted. I thought it's easier to get the right shape at this way.
The wale isn't ending in the rabbit. The black strake and the lower blanking will be ending in the rabbet so you can't see this (so the theory).
Edited by jaerschen
Hello druxey
While I think of it: did you taper the thickness of the wale at the bow to fit the rabbet? (I had this conversation with another model-maker today.)
Your question have make me think about my approach. It would be interested to know what other model maker are doing.
Hello druxey and Richard
Much thanks for your answers. I must confess to my shame, I didn't have added Chuck's interested build to my following list. Now it's done.
Oh, there are so many build's and information’s here on MSW. Very nice photo that is showing this detail, such photos are not often to find. I found this advice to tapper the wale in Vol 2 of the swan series too (I have only 1 +2) but could not imagine this. At the searching in other build's I found a photo from Dan of the Vulture. But It's not to see if the wale going in the rabbet or flush to the stem. At my Triton it's going flush to the stem because it's never to see if the black strake and the blanks below are fitted.
Edited by jaerschen
Hello again
The fitting of the black strake is started and the next problem is coming.
Therefore the following photo
There isn't enough space between the left haws-hole and strake. Must be the altitude of the strake reduced for fitting the boxing? I admit to be a bit douptful about this.
Oh, by the way, the wale is now tapered and also the strake a bit. In hindsight I believe it's better to do this before the ledges are fitted. Learning by doing.
Edited by jaerschen
Before you do anything drastic, measure the heights of the hawseholes from the plans and then on the model. Are these correct? Is the height of the main wale at the bow correct or is it too high? Is the height of the black strake also correct?
Jürgen,
what kind of timber do you use for the planking? The contrast to the darker swiss pear looks really great
Regards Christian
I do not understand why, but one side of the hawseholes were not similar to the other. I had wrong measured, that's absolutely certain for me because I have made one side some day's earlier than the other. Here's a pic there you can see the variety of height.
The level of the holes at the starboard side is correct. So I closed the holes at the portside and drilled new ones as the same level as of the starboard side.
post-3439-0-24895700-1418387474_thumb.jpgpost-3439-0-39138900-1418387485_thumb.jpgpost-3439-0-59181500-1418387491_thumb.jpgpost-3439-0-97166900-1418387497_thumb.jpgpost-3439-0-21637200-1418387503_thumb.jpg
Edited by jaerschen
Hello Rob, Christian and Richard
Thanks very much for your comments and also for all the likes
You are completely right Richard. Now let's going on to the next mistake :)
Edited by jaerschen
Juergen,
Well done on the fix.  It's so well done, I don't see the fix.  :)
Thanks very much Mark
I don't no why, but I have this feeling that you are a little bit dishonestly about this :D
I zoomed in the bottom photo.... looks great.  I thought the others were "in process" pics.  No dishonesty.   :)
Edited by mtaylor
very nice work juergen,
are you going to plank the entire frames, or leave an outcut for to see the lovely framework ?
Nils
Current builds
-Lightship Elbe 1
Completed
Hello, thanks very much Mick, Allan and Nils
That's good to know Mick and Allan. Now I can sleep soundly again. :)
@Nils
I would like to show a bit of everything at the outside. The Main-Wale and below of it 4 rows with shifting planks. Then the 1st futtock- and the floorhead -ribbands and the garboard strake. Above the black-strake I will also plank only a part of the frames but in any case the complete sheer strake. Both sides will be similar. So the theory.
Hello,
Here's a little update and I would like to take this opportunity to wish you all a Merry Christmas.
I started to fit the ribbands and coloured the Main-Wale black.
post-3439-0-35994000-1419412714_thumb.jpgpost-3439-0-63056600-1419412726_thumb.jpgpost-3439-0-22069600-1419412738_thumb.jpg
The ribband-nails are done in the same manner as described in the book from David Antscherl of the Swan-Class. Only the insertion tool was made of a screw and two screw-nuts.
post-3439-0-96976900-1419413145_thumb.jpgpost-3439-0-04648000-1419413149_thumb.jpgpost-3439-0-92338900-1419413198_thumb.jpg
For securing the nails I used white clue and think that it works.
The Main-Wale is coloured with black stain. Mark gave me this advice in my build of the Leopard and it works very well.
post-3439-0-91272400-1419413552_thumb.jpgpost-3439-0-51268300-1419413559_thumb.jpgpost-3439-0-46193900-1419413566_thumb.jpgpost-3439-0-79001600-1419413574_thumb.jpg
Edited by jaerschen
Hi Juergen,
Just caught up with your Triton log, you've done a marvelous job on her Sir, very precise, clean work, and your hull has lovely lines B)
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Hello,
Thank you so much for your nice comments and also for the likes. I'm very pleased about this great interest.
Here's a little update. Some strakes below the wale and the garboard strake are fitted. The progress is very slowly because It's partial a bit tricky.
Also I needed time to find a way to add the planks without leaving any trace at the frames. Therefor the build from Ed of the Extreme Clipper is a great help.
post-3439-0-71438500-1420660163_thumb.jpg post-3439-0-37542000-1420660177_thumb.jpg post-3439-0-80122700-1420660186_thumb.jpg post-3439-0-92617300-1420660194_thumb.jpg
In the TFFM-book this strakes are reffered to as thickstuff under the wales. There is a little step from the second to the third strake to see on the following photo. That's why the thickness of the strakes decreases. I will sanding down them when the fourth strake is installed.
That's the current progress.
Edited by jaerschen
