Thanks for the comments guys the upper rails are a long way of but I have it in mind how to do them as Pegasus had similar rails.
Chistian I had not looked ahead to the channel positions but checked them out today in regaurd to the gun port positions and they are ok, I am nearly finished working on the main deck gun ports ( had to move the position of them full write up to follow ) And  I also checked the channels with them luck was with me and they are ok.
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
post-10-0-18225200-1368996499_thumb.jpgGun ports
Next job mark out the main gun deck gun ports, on the face of it a simple task, the top of the second plank down is marked and is the top of the gun ports, start 65mm in from the stern and mark along that line with the template supplied stern to bow. WRONG this gave me a big problem the last two gun ports at the bow line up with two frames, these would need to be cut away to open up the port, which in turn means you would have to remove the deck beam supports, (see photo) this is a very poor design fault, I moved the gun ports to just miss the frames this puts the ports in the position shown on the overhead deck plan!! I then remarked the ports going back to the stern with a 32mm space between ports not the 30mm space on the template. I can only think what a good job I noticed this before I started cutting out the ports!!!!
The ports were then all cut out small holes drilled and then cut out and trimmed square with a file, note I covered the deck with masking tape to protect it when filing out the ports, the ports without lids were then trimmed out with1x6 timber the inner bulwarks and the framed ports painted.
I did not check first but after warning from Christian I checked the channels, when fitted they will be ok and the spaces that need to clear over the gun ports will be.
AS marked out with supplied template
Ports as remarked
Cutting out the ports
Ports all cut out
Ports cut out and lined
All ports without lids done
Ray
 Completed  HMS Diana
Hiu Ray,
Could have made a template from the plans to assist in cutting the gun ports?
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Hi Mort
             I did look into using the plans but the spaces between the gun ports ranged betweem 29mm and 35mm hardly are two the same! so I just made sure the guns would be able to go through the two bow ports.I now have noted that in The Anatomy of Ships ports 1-7 & 8-14 have the same width between them and the width between 7 & 8 is wider about 35mm, to late to have this larger gap now, still I hope my log will help others from making the same mistakes as me.
Ray
 Completed  HMS Diana
Thanks Ray,
I am going to check my copy AOS Diana.
Keep up the great work,
Mort
Second Planking
I started planking from the top of the wale, this position was marked out as per the instructions measuring down from the main deck gun ports. I like to lay the second planks semi-wet to damp and fix with cyno gel; I find the cyno grabs damp timber much better than dry timber. One thing I will comment on is the quality of the planking the 1x4mm being the worst, it is nowhere as good as the planking supplied in the two Victory kits I have built, the edges are rough and splintery, and also show saw marks, four out of ten would be my best mark I could give the 1x5mm a little better, So before soaking I had to sand all the planking edges a bit of a pain. I went downwards with the 1x5mm for five rows,( the instruction say plank right down to the keel and plank upward last), I then went upwards with the 1x4mm only because I thought it was only a matter of time while working on the bottom I would break or damage the fore or quarter deck sides, this way their thickness would be doubled and be a lot less fragile. The planking as gone ok so far.
Jason
        At the end I have posted two pics with Diana along side Pegasus hope this gives you the size compassion.
Rough planking
First few planks on
Working upwards
Planked upwards to the top
Planking well under way
Diana and Pegasus
Ray
 Completed  HMS Diana
Ray,
The planking is very well done from what I can see.  Pity they can't put better wood in the kit.   I love those two last pictures. There's a real difference in ship sizes.
A very nice job Ray, I'm looking forward to seeing more of this.   :)
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Ray, planking is looking great despite your challenges with the wood.  I've read from others similar concerns over the quality of the supplied wood in CC kits, I think I just got lucky with mine, but the tanganika did need each plank to get sanded to get a decent edge.  Its a shame because otherwise they seem to be high quality.  You also seem to be moving on at a cracking pace :)
Thanks for posting the side-by-side, amazing to see the size comparison between these two frigates.
Cheers,
Jason
In the shipyard:
Thanks for the comments guys, I Just have the last couple of planks to go on and the second planking will be done, I will update once I have sanded her down.
I have made quicker progress than normal as 12 weeks ago I had a total knee replacement so have not been able to play golf or go carp fishing, so I will probably slow down a bit soon, but it has been great to do the build as it takes your mind of the painful knee  (even at 2 o’clock in the morning).
Pegasus & Diana what a difference in size between Pegasus the littlest frigate (sloop) & Diana the largest frigate.
Ray
 Completed  HMS Diana
Hi Juergen
                  Both Pegasus and Diana are 1:64 scale and show the differance in size between the largest frigate and the smallest all be it Pegasus is a sloop but is fully rigged.
I really like your HMS Leopard and have ordered the book, I would love to build a 50 gun 4th rate, my main concern would be the ornate carving I do not think I could do in justice, if  I did try the build I would have to do the carvings first.
Ray
 Completed  HMS Diana
The second planking is completed sanded, filled, and sanded again and lastly finished off with wire wool, I have also lined the gun ports with lids, all the gun ports have been painted. One thing I did do was to add a 1mm strip to the bottom of the keel as to my eyes the distance between the planking and the keel bottom looked to narrow.
Bow planking
Stern post and stealers
second planking completed
First sanding
Filler aplied
Lined gun ports
Extra wood added to allow easier lining of bow gun port
After final sanding
Ray
 Completed  HMS Diana
The main wale
                       The main wale planking was done next; again the timber needed dressing before it could be used, as the edges were very rough. After all the planks were fixed I taped over the top thinner plank so as to protect it, and to maintain the difference when rubbing down the rest of the wale. The wale was rubbed down and filled and top plank uncovered and the whole wale painted black.
The whole of the hull including the wale was given a coat of 50/50 satin water based varnish and water, I use this as a sealer, I find both paint and the copper tiles adhere to it very well (I did a test strip to make sure).
First plank on
Ready to fill and paint
Narrow top wale plank
Wale in progress and lined gun ports
Masked up and painted
Wale completed and 50% water-varnish sealer on
Ray
 Completed  HMS Diana
Enjoying learning from your efforts, Diana is on our wish list.
Thanks
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
Sharp looking wales, Ray.
Firstly thanks for the comments guys
I will now depart from the build instructions and copper plate the hull and build up the transom and stern gallery. Before I start the plating I have added the batten to where the copper plating will finish, I used 1mm square plastic and painted it black. I will do the copper plating next, as it requires the hull to be upside down or on its side most of the time whilst the plating is being added, so I my opinion now is the best time to do it, plus I want to get it out of the way, I will do a bit of tiling and a bit of transom building, my reasoning is doing both at the same time will break up the copper plating.
Batten on and painted
Ray
 Completed  HMS Diana
Ray, you're way more experience than me, but I definitely agree with your approach.  I don't know why CC put the coppering so far into the build instructions, it just seems to make it that much harder to manage and like you I liked to have the freedom to work on the hull without worrying about breaking anything delicate.  I love the way she is looking already, the planking, wood tone and the black look very nice indeed!
Cheers,
Jason
In the shipyard:
Copper plating the hull.
                                  Firstly I decided to go with the copper plates supplied with the kit although I much preferred the look of the ones used on Pegasus, the cost would have been over £100 to update them too much for me.  I started from the edge of the keel and fixed a row of tiles left over from Pegasus on the edge, I then came down 3 Rows before running a gore line, I did it by eye and feel and looking back at Pegasus to get the same sort of effect, as there does not seem to be a definitive way of doing this. One advantage I have found with these plates are they fix very well, maybe it is the dimples on the fixing side holding the cyno better than a plain flat surface, they also cut well and dress down fairly easily with a file or sanding wheel, when you need to make up the triangular stealers.
First few tiles on
Gore line marked out
Gore line tiled
About a quarter done
First side nearly done
Ray
 Completed  HMS Diana
Excellent coppering, Ray.  Just curious on why you picked where you did for the gore line?  I've never coppered and this is a curiousity to me.
Hi Ray,
I have just about finished construction of the Amati Bounty and am now seriously thinking about what to do next.
A late 18C frigate is looking good and I have been thinking about the mamoli Surprise with a bit of scratch improvement but your Diana build is a real inspiration. Tempting.
Another factor is the size of the finished model. The Diana is pretty big, maybe too big.
Decisions, decisions!
Cheers,
David.
Previous Builds:  Port Jackson Schooner  Modellers Shipyard 1:50
                          HMS Bounty  Amati 1:60
                                  HMS Surprise Timber Scratch Build 1:75
Current Build:    HMS Bellona Timber Scratch Build 1:75
