I've been reading Chuck's article on Techniques For Modeling Yard Details.  He uses 28 gauge black wire for foot ropes.
I haven't been able to find anyone who carries this wire.  I checked Model Expo.  I also checked Amazon who carries something called "Artistic Wire" but the black is glossy which probably wouldn't look to good.
Any suggestions would be greatly appreciated...thanks!
Dave
Current build:    Rattlesnake - 1780  Model Shipways
Builds:               Mare Nostrum  1:35  Artesania Latina
                          Cutty Sark  (I believe it was an AL kit)
davespindlephotography.com
Try your local hardware store.  If they don’t have it McMaster Carr has it.  They call it:  1008 Carbon Steel—Black-Oxide Finish .014 dia.   http://www.mcmaster.com/#metal-wire/=sltk0h
Current build:  SS_ Mariefred
Dave,
You can also order it from BlueJacket. They have black annealed steel wire from 22 gauge to 34 gauge including the 28-gauge you're looking for. But, all wire you get is going to be shiny unless you brush or spray on some kind of dull coat.
Clare
Clare Hess
He's a -> "HE"
I got mine from the Dick Blick art store http://www.dickblick.com/products/ook-dark-annealed-specialty-wire/ . 100ft for $1.89, which will keep me going for a while - of course I still need to learn how to make the hooks :)
Richard
Current Build: Early 19th Century US Revenue Cutter (Artesania Latina "Dallas" - messed about)
Completed Build: Yakatabune - Japanese - Woody Joe mini
Member: Nautical Research Guild & Midwest Model Shipwrights
For an alternative to wire, I used black thread and CA to stiffen it. For the stirrups I knotted the end of the thread around a headless small finishing nail. Then I hit the knot with CA. After snipping the end of the thread off this gave m a great stirrup with an eye to thread the foot ropes through. Then I took the black thread stiffened it with a small amount of CA and threaded it through. Once wrapped in place another small amount of CA and it was complete. You could use alternative glues for stiffening and attaching, but for the eye, I would stick to CA.
I copied this technique from another modeler on the web - so I can't take credit for it, but it worked well for me.
Anyway, this worked for me.
Bill
Chantilly, VA
Its not the size of the ship, but the bore of the cannon!
Current Build: Scratch Build Brig Eagle
Completed Build Log: USS Constitution - Mamoli
Completed Build Gallery: USS Constitution - Mamoli
there is a dealer on ebay who sells all the sizes of Hillman black steel wire. it will cost $4 or so including shipping..
Here is a photo of my rigged spars for the Constitution. This is the Mamoli kit 1:93 scale. These were taken on the paper I painted them on so there is a lot of back splatter but this is the only one I have of them together. These were done with the black thread method.
Bill
Chantilly, VA
Thanks, everyone for the great sources, I really appreciate it!  And Robnbill, thanks as well for the black thread method...that a good idea.  I'd like to see if diluted Titebond would work as well for the foot ropes rather than CA.
Dave
like I previously mentioned I used wire stripped from a redundant phone extension cable, it's free & you can experiment as much as you like,not only that but I am "Tight Fisted" as well ! Geoff
Edited by geoff
David,
Black thread coated with diluted PVA (egvTitebond) works very well.
  • 1 year later...
If you have a draw plate with one wire gauge at the large end, you can draw the wire to any gauge that the plate has a hole for.  It would be regular copper or brass wire since no coating will survive the process.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
