Having attempted making my first batch of rope blocks,
drilling many many MANY holes with a pin vise
I have decided I need a mini chuck for my drill press for the next time I attempt anything like this.
I just found these two products on the McMaster-Carr website
Has anyone used them?
Is there something better out there?
Alan
MMC 28055A71 drill chuck No 70 - 1_4 drill.pdf
MMC 30505A5 drill chuck No 90 - No 60 drill.pdf
Edited by AON
Alan O'Neill
I use this one from Model Expo:
http://www.modelexpo-online.com/product.asp?ITEMNO=EN409C
It takes a bit of fiddling to get those small drill bits centered in the chuck, but after that it works pretty well.
I use the Dremel Workstation as a  drill press. It's available thru MicroMark http://www.micromark.com/dremel-workstation,8556.html  Dremel has collets that take even the smallest drill bits. Mine works fine for model work.
Jack
Current buildUS Constellation
Thanks guys,
My dremel is quite old and I am not sure it would clamp properly as the new dremel's seem to have a space aged shape to them.
Also I cannot find a dremel chuck for the smaller bits... all these would work in it, or my drill press.
I like the $US2.99 price of the Model Expo attachment for the price.
I'll have to check out the shipping costs to get it to the Great White North.
The McM-C items seem like a nice pair, the larger one locking with a key and the smaller one by finger (or pliers?)
Would still like to hear more opinions if there are any
Alan
Alan O'Neill
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
An alternate option would be to purchase resharpened carbide drill bits.  These have a standard 1/8" shaft that fits the Dremel collet.  I would be surprised if there isn't someone in Canada you could purchase these from.  I use Drill Bit City here in the states.  The advantage of using a collet rather than a Jacobs chuck is stability of the bit, especially when drilling holes that need to be accurately positioned.
Toni
Member IPMS
                           Utrecht-1742
It's not a Dremel chuck you need but the interchangeable collets that go into the chuck.  I have a Dremel 395 and 3001 and both fit the Workstation. They "clamp" in via threading on the "nose" of the drill. A ring is unscrewed and the dremel is then screwed into the workstation and router/shaper station.  I have both the "old" Dremel and the new Dremel and use them both interchangeably  The collets look like these http://www.dremel.com/en-us/Accessories/Pages/SubCategories.aspx?catid=2005&catname=Chucks+%26amp%3b+Collets and are not that expensive.
Jack
Thank you Jack
That gets me down to a #67 bit
I'll have to check the model number of my dremel to see if it will work with the press
All and all my dremel does not run at a very slow speed (cannot get down below about 1000RPM) where as my big drill press will... and I've been looking for replacement rotor brushes as they are getting worn again and now no one seems to carry them locally.  I suppose I'll need to buy these online also at some time.
Toni, I've checked locally and seems there aren't any re-sharpened bit suppliers willing to reveal themselves
I suspect they would likely buy from the US and mark it up substantially
Alan O'Neill
The 90-60 chuck is probably better, and is not expensive.
But, I'll think that you'll find that the drillpress itself wobbles quite a bit, unless it  has good bearings, is aligned, and is securely mounted on a study bench.
I've got the chuck that Chuck mentioned.
It works great and it's cheap.  Used it just last night to drill 8 holes in my mast partners.  And it should chuck up in any dremel.
-EDIT- BTW, my dremel is an old cheapie, non-variable, working at 30,000 RPM
Edited by Pops
Previous build(mostly) - 18th Century Longboat
Current build - Bounty Launch
Next build - San Francisco by AL
Future build - Red Dragon
Future build - Mayflower from Model Expo
Alan,
Check the link Tom gave at ModelExpo.  They claim down to #80.
many pin vices I've seen unscrew on the back half to store the extra sizes of vice.  can just try removing the back half of your pin vice and stick it in your drill/drill press.
Current Build Log(s):
-Swift Virginia Pilot Boat 1805- Artesania Latina 1985 no sails kit.  My first wooden ship build.
Carrack - Woodkrafter Kits
Completed Build Log(s):
-Pirate Ship- Woodkrafter Kits Ship in a Bottle - First ship in a bottle kit build.
-The Secret Revealed Boat in a Bottle Kit- Authentic Models - Ship In Bottle
On the Shelf to build:
- Build a Ship in a Bottle Kit - Authentic Models
- The Chesapeake Bay Flattie - Midwest Products
- Armistad 1832 - Serial Modellbau
- San Gabriele 1497 - Serial Modellbau
- Clara May English Ketch - Artesania Latina
- Santa Maria - Scientific
- Margaretha - Tris Model
- Paranzella - Tris Model
Grimber
What a wonderful Idea!
Nice thinking outside of the box.
I'll have to give it a try... tonight... to early in the am at the moment and I'd hate to wake the Master and Commander at this un-Godly hour
Alan
Alan O'Neill
Thank you Jack
If you look on eBay you will find several sets of resharpened carbide bits for sale.  Price tends to be about $12 for 10 bits.  I bought a set recently and they are pretty good.  Here is a set of 50 on eBay http://www.ebay.com/itm/50-Micro-Carbide-Drill-Bits-CNC-Dremel-Jewelry-/151515931888?pt=Model_Kit_US&hash=item23470da4f0
Edited by grsjax
My advice and comments are always worth what you paid for them.
Just a word of caution re carbide bits.  They are excellent and I often use them BUT - they are very brittle compared to the usual HSS bits and require a good drilling technique to use them.  If you hand hold your Dremel (or equivalent) they need a sort or stabbing action to make sure there is no sideways twist.
John
dremel drill press and the older dremel's
I have an older one that works fine with the workstation, also the router kit works fine.
they attach to the threaded collar  on the dremel not to the body so unless they change that then it works.
Holding at Rigging stage :
MS Bluenose 1:64, rigging and finish work
Building Hull :
MS Fair American 1:48
In the yard:  18th Century Longboat, Model Shipways Kit
Done: AL Bounty Jolly Boat
I have (what I consider) some $$ invested in a XYZ vice and a drill press combo.
Not what some might consider major dollars but enough for me.
I will try the "chuck" transfer from the pin vise to the drill press tonight
If this does not "do it' for me I think I will just purchase the items from McMaster-Carr and be done with it.
(If I order with our next shop order at work I save on the shipping into Canada)
I will let you all know how it turns out
Anything is better then doing it by eye and hand which is what I've just gone through
( you get older [eyes] and less steady [hands] )
Don't get me wrong, I love my dremel but the drill press is sitting there staring at me saying "yo, I'm here, use me!!"
Edited by AON
Alan O'Neill
Well I gave it a try and it did not work
The Insert from the pin vice has three jaws
The chuck on my drill press has three jaws but obviously larger
The drill press jaw spacing does not allow the pin vice jaws to clamp or collapse, they bind up, so the drill bit does not clamp in place to allow it to be used.
I tried spinning it a bit to see if it was just a misalignment thing, but it was not to be.
I will need to purchase something and think I will get the two from McMaster-Carr to cover my bases
This will be after the holidays as after today I am off for two weeks...hurray!!   :10_1_10:
Alan O'Neill
Hi, didn't mean to just use the vice, but the whole front half of the pin vice.  my mistake in typing.
but if you got a cheapy china made one you may not want to do that.  mine I think is made of alluminum, but I have 2 so I did it with one just for use in a drill, and my other for using by hand.
Edited by Grimber
I had in fact tried that quite some time ago but discovered the assembly was not symmetrical, the bit wobbled.
That is why in my mind I thought you meant just the insert.
My pin vice is the one in the PDF below.
I also borrowed a different style from work to try and it too was not symmetrical.
I'm guessing you've got a good one!
PIN VISE.pdf
Alan O'Neill
actually it was a cheap one from hong kong off ebay.  little patience I got it for $2.00
http://www.ebay.com/itm/New-21pc-Micro-Drill-Bit-Set-Index-61-80-w-Swivel-Head-Pin-Vise-US-SHIPPER-/201039587229?pt=LH_DefaultDomain_0&hash=item2ecee4a79d
made of aluminum and the swivel head keeps binding up as it is only held in place by very badly twisted ring,  but i found it works great in a drill as long as you leave the 2nd vice in the handle shaft to keep the chuck from crushing handle.
but I have been looking at just getting a small electric motor ( like used in RC vehicles) and put on the mini pin vice chuck
Mini Small 2.3MM Electric Motor Shaft Clamp Fixture Chuck for 0.7MM-3.2MM Drill
or getting one of those already made and just make a drill press type mount it
http://www.ebay.com/itm/Small-PCB-Motor-Electric-Drill-Circuit-Board-Press-Drilling-0-5-2-5mm-21PCS-12V-/151295626753?pt=LH_DefaultDomain_0&hash=item2339ec0e01
The issue is not necessarily the concentricity of the pin chuck or collets, but the concentricity of the chuck on the power equipment you are using. If the latter is off, the pin chuck or collet in the machine, however accurate, won't be any good. It's the weakest link effect.
