Everything posted by Burroak
Cutter Cheerful 1806 by rafine - FINISHED
Burroak replied to rafine's topic in - Build logs for subjects built 1801 - 1850
Bob I was searching online and found a company called Turner Toys www.turnertoys.com that sells the Polly scale paints.- 525 replies
- cheerful
- Syren Ship Model Company
Tom she's really looking nice. What reference did you use to keep the steps level? They look perfect. Greg H.
- 1,350 replies
- constitution
- model shipways
Dave that's a great idea also. Mark and Captain Steve had great ideas also. I'm going to try all of them and see which ideas work best for me. I actually think they will all work for me. You guys are awesome! I feel a little rush creeping in on my build so I've got to slow down some. It's just excitement of seeing the Conny start to show signs of life. Greg H.
I am working on the USS Constitution by MS and I have planked the inside of the bulkheads. I left a little hangover around the gun ports and I want to get a nice smooth cut out. The gun ports are already formed. The files I am using unfortunately have teeth on the edges and it's hard to get a clean job in the corners without making a notch. What can I do about this? Is there a video or a build log which shows how to make these cuts. Thanks Greg H.
I can tell from my woodworking that cherry is a nice wood, but keep in mind that cherry darkens with light. It will be lighter while you work with it but let it set for a few days and it will darken. That's why on furniture made from cherry, if you set something on it there will be a shadow that has formed where the object set. Greg H.
I have an issue with my USS Constitution cannons. They sit a little high in the gun ports. Only about 1 1/2 mm to 2 mm but it's noticeable. The options I have thought of are to 1) place a small 1 1/2 mm piece of wood under the but of the barrel 2) make the notch deeper that the wheel axles sit in 3) cut notches in the axle where it mounts to the carriage 4) make a flat spot on the wheels. 5) make a different carriage all together. If you have tried any of these or have a better remedy I sure would like to hear from you Thanks Greg H.
John your Charles Morgan turned out absolutely fantastic. You have a great imagination for your display. Well Done. Greg H.
- 2,250 replies
- model shipways
- Charles W Morgan
One of the main decisions for me in buying my scroll saw (Excalibur 16") was what projects i am working on now and in the future. I also do full size woodworking so I needed a larger saw. I do fret work cutting so I wanted a saw that would cut more straight up and down. Some model have a sort of lunge cut where either the top or the bottom is actually cut further in. I paid close to 600.00 dollars for mine. If you will only be making miniature projects then it would be overkill. I've looked at the Proxxon scroll saw and it looks like it would make a nice straight up and down cut. I'm sure there are others. I once had a Delta scroll saw but it had a bad lunge cut, which is not good for fret sawing. Lots of options out there. Main decision is knowing what you want it to be able to do. Greg H.
Sjors your ship is magnificent. Great job as usual Greg H.
- 1,616 replies
- caldercraft
- agamemnon
Mark when you pointed out the problem with your ship, it took a moment to even notice it. When I look at someone's build I'm not looking for the errors in it. All I see is the beauty of the work and how much time was spent on it. You know where every nick and ding is on your ship because you are building it, but I assure when it's complete everyone will be looking at how beautiful it is and not at any possible problem. I guess since you are a master ship builder, the idea is to build the perfect ship. All I can say it looks perfect to me. I'm just trying to complete my first ship and hope it looks decent. Greg H.
