Everything posted by ChrisLBren
Looks terrific Chuck !
- 421 replies
- medway longboat
- Syren Ship Model Company
ancre Chebece 1750 by Jeronimo - FINISHED
ChrisLBren replied to Jeronimo's topic in - Build logs for subjects built 1501 - 1750
Terrific work Karl !!! -
Looks really good Toni - you have my admiration in completing such a challenging project.
- 1,449 replies
I recommend the AL Harvey along with Frank Mastinis Book Ship Modeling Simplified which references this kit. You can pick it up for under 100 dollars on EBay. While not historically accurate - it's an easy build and makes into an attractive first time model. https://m.ebay.com/itm/ARTESANIA-LATINA-1-50-Scale-Baltimore-Clipper-HARVEY-Kit-MINT-Cond-Nice/132653398889?epid=1320503011&hash=item1ee2c23b69:g:dSQAAOSw8FBbGJJV
Beautiful work Karl !!! -
Thanks for the clarification Mike. If you can build a display case as perfect as yours - applying a French Polish finish would not be above your talent ! Well done - the Danish Oil looks great.
- 968 replies
- hahn
- oliver cromwell
Damn Chuck - that looks amazing !!!!
- 1,784 replies
- winchelsea
Hey Mike, On a piece of furniture that gorgeous you may want to consider this finish - classic French Polish using thin coats of shellac. https://en.wikipedia.org/wiki/French_polish Or even a simple wax finish would work well. http://www.thefurnitureconnoisseur.com/c/furniture-wax/ I know many use sanding sealers on their models - but on furniture its not really considered a final finish its more of a sealer before applying a finish from my research.
- 968 replies
- hahn
- oliver cromwell
As a new user/sharpener I have to agree re Lie Nielsen. They cost more but are so much easier to sharpen (because they're almost perfect to begin with). I too use the Veritas Narrow guide system and waterstones. There's a big difference between the 1 inch Irvin I bought for 15.00 vs the Nielsens. If sure if you spend enough time sharpening the Irvins they will cut the same - not sure if they will keep an edge as long. This same chisel would have been 70 dollars with LN - they are also beautiful tools...
Hey Group, I broke out my Proxxon MF70 to try some joints on some scraps- 5 minutes of work and here is the result. Much tighter and SO much easier than chisels with better results. I will need to be using this tool extensively on the keel parts, stem and stern and all of their respective notches - so will be bolting it down on my work bench tomorrow AM.
Hey Mike, I did use Swiss Pear on Confederacy - the wood from this flitch of Swiss Pear is lighter which I prefer. Quality wise both batches have been nice to work with. I milled it a year ago and it hasn't darkened yet. I purchased it from these guys - great products and customer service. http://hearnehardwoods.com/
I personally dont like wipe on poly for ship models - this is a product designed for wear and tear use - which certainly is not our models. I am a big fan of tung oil/danish oil, sanding sealer, wax or shellac. All of these finishes allow wood to age naturally and patina. My old Fair American Build looks the same as the day I applied Wipe On Poly back in 2007 - which makes sense - you're applying a plastic finish. If thats the look you're going for it makes sense. I prefer the look the look of old museum models. This finish is perfect - and a model built within the past decade or so - but looks two hundred years old https://goo.gl/images/GNCFtZ
- 607 replies
- winchelsea
