Posts posted by popeye2sea
For vertical ladders, if you mount the ladder so that it is off of the bulkhead with spacers, the rungs and sides become handholds.
For inclined ladders, I have never once, in 24 years of naval service, gone down an inclined ladder backwards. That is a sure sign of a landlubber aboard ship. Vertical ladders, can only be traversed facing the ladder.
BTW, ships do not have stairs. They have ladders.
Regards,
Henry
Since the reef points seem to be at the bottom of the sail it sems to me like they would shorten sail by lowering the yard and gathering the foot of the sail up to each succeeding reef band.
This style of reefing would almost naturally morph into bonnets and drabblers laced to the foot of the sail. And then the next step was reef points at the top of the sail with the reef band lifted up and gathered at the yard. This was also accompanied with the addition of footropes.
Regards,
Henry
Officers and gentlemen were required to display a level of disinterest and decorum at all times. They had to hold themselves above the fray. Even in social situations. It was one of the ways to show your social status and worthiness to be called a gentlemen.
Officers were also on display for the crew. The sailors would be more likely to follow an officer who did not show fear in the face of danger.
Regards,
Henry
Crowsfeet in other applications are there to distribute the pull on another piece of the rigging. For example, in the 1600's or so crowsfeet were rigged on spritsail backstays, some yard braces, mizzen topping lifts, etc. Often the crowsfeet were employed where there would be excessive pull on another rope so as not to pull it out of alignment, ex. the spritsail topmast backstays pulling against the fore stays, or braces pulling against a shroud, etc.
Regards,
Henry
- Ferrus Manus, GrandpaPhil, Gregory and 1 other
3
1
Actually, the function of the these crowsfeet is to prevent the topsail from getting caught beneath the top.
Regards,
Henry
- davyboy, wefalck, Ferrus Manus and 3 others
6
Each strand of the netting material is doubled on the top rope. The top rope will be stretched between the stanchions. The side ends of the netting are simply the last leg of the doubled netting that will run vertically from top to bottom. I actually don't know how to end the mesh on the bottom rope. I will try to look it up in Ashley's book and let you know.
Regards,
Henry
- Keith Black, Marcus.K. and mtaylor
2
1
I have a pair with tips starting at 4mm and tapering down to just less than 2mm, but I modified one tip so that it tapers down to about 0.5mm in order to make really small hooks, eyebolts and rings. That one plier will suffice for any size rings that I am likely to encounter.
Regards
Most of the discussion above applies to smaller fore and aft rigs. Big square riggers act very differently.
I have read that one of the reasons for mast rake in large square rigs is to get the yards pivot points more aligned in the vertical plane. Each additional upward section of mast being stepped slightly in front of the lower section.
Regards,
Henry
If the stem sweeps up to meet the underside of the bowsprit won't you end up with a higher beak head?
Henry
The sheets pass through the side to come inboard for handling. On some ships the "block" that they pass through is no more than a closed chock or hole through the side. In this case they are specifying a rotating sheave let into the hole.
Regards,
- mtaylor and Thukydides
1
1
google parbuckle for a quick how to.
Regards,
Henry
- mtaylor, aliluke and thibaultron
3
BTW, thought you might want to know that the shaded striping effect on the shield is not a thing either. They would have been solid stripes with distinct edges. The proper blazon would be " Bendy of eight, Gules ands Or". That translates to eight diagonal stripes, alternating red and gold. The two lions rampant (describes how the lions are standing), Or (gold) in chief (the uppermost part of the shield) are actually covering the upper stripes. Think of it as a field of stripes painted on a shield with decorations (they are called charges) placed or painted on top.
Regards,
Henry
- mtaylor, Egilman, Old Collingwood and 2 others
5
On the box art the inner lining of the cape is showing the traditional heraldic depiction of "vair", which is squirrel or weasel fur. The alternating dark and light bell figures represent the darker upper fur and the lighter underbelly fur of the animal that were stitched together alternately to form the garment. That could give you some idea as to the color of the cloak lining. Vair was frequently used for the inner linings of the cloaks of the nobility.
The other heraldic fur was ermine, considered to be a regal fur used in the crowns and robes of royals.
Regards,
Henry
To properly belay a line to a pin the first turn is around the lower part of the pin and then straight up around the top part. In other words, no cross over. The next turn is to cross the line over itself around the lower part of the pin and then the last turn is to throw a half hitch over the top. You end up with 2 thicknesses of line over both the top and bottom parts of the pin. That will provide enough friction to hold any load.
As a practical matter, there would not be that large of a variation between the diameters of lines coming down to pins. Anything much bigger than an inch in diameter would probably be belayed to a kevel, knight head, or large cleat. One size of pin throughout the whole vessel would be entirely plausible and practical.
Regards,
Henry
I think the problem is that your rigging and belaying plan has led you astray. There were, more than likely, belaying pins or a fife rail for all of those lines. Those bitts are primarily for the anchor cable. There may have been belaying pins set in between the uprights of the bitts.
Regards,
Henry
Building on what Pat just said, I would start with the rearmost shroud on each side. With the greatest angle to the mast it has the most influence on the position of the mast. Then do the foremost, followed by the middle. You just have to make sure that all the shroud pairs are laying fair at the masthead. It will be hard to readjust after the rear shrouds are set up since they are on top of all the others.
Regards,
Henry
On 10/29/2024 at 8:40 AM, Glen McGuire said:
These are called mast tackle pendants. They are fitted first over the masthead because they are initially used to heave taut the shrouds when setting up the deadeye laniards. Thereafter, they are employed using heavy tackles to hoist gear and cargo aboard the ship.
Regards,
Henry
- Glen McGuire, Keith Black, Bryan Woods and 4 others
6
1
Hammock Storage
in Nautical/Naval History
If it is to be taken as a list of actions it doesn't work grammatically. Beat to Quarters, Stow'd our hammocks, ________? in the tops, fill'd our Lockers. There is a verb missing. What happened in the tops?
Regards,
Henry
