steamschooner
Everything posted by steamschooner
  1. Well I got a few things done on my project. I know it's been awhile. Need to finish dashboard, a fuel port, a couple of penant poles and some decals.
  2. Harvey, There were a few built up my way( Willapa Bay ) and in Grays harbor as well. Will follow your build as I have a interest in steam ships.
  3. Nice looking small working craft. Weathering looks good but the white sail looks out of place(should it be weathered also?)
  4. Dan, At the top of the home page there's a tool bar and under MORE there's a community map. It will show you members near you. I am 119 miles north of you in Lebam Wa.
  5. http://www.hawk-graphics.com/pages/decals.html here is one place in Canada
  6. I know I'm a little late with these but maybe they will help.
  7. Terry, Have you tried looking on www.hathitrust.org/ {online books) search international marine engineering for the years you are interested in. I have a set that spans 1896-1906 and have seen many naphtha launches some with drawings.
  8. Eric, I take it that the grasshopper poles are going to be rigged in the ready position? You have some line on the bow pole(term ?) that would make it difficult to stow them (grasshopper poles ) on that cross brace. You would have to poke the end of the grasshopper between the line and the bow pole. Just wondering, your model looks great. Steve
  9. Eric, In Kurt's post 247 shows the Ben Campbell with the grass hoppers in the stowed position. So not all boats left them hanging. I would also think that they would not be derigged when stowed having enough line on the falls to position horizontally as seen on the Ben Campbell. not that I know anything about riverboats Steve
  10. are you sure it's the USS Perry you are building and not the USS Putty?🤪 sorry couldn't help myself. Looks like a good job so far.
  11. Ron, What type of material is the mold made of? rtv, plaster,? Heating it should help and the talcum also. I find that the low temp alloy cools very quickly. you can "cook" the alloy if you try and use to much heat. If you look in scratch build logs pg 11 is my build log of the John Cudahy. On the 7th page of that log you will see my casting efforts for my anchors. post #182 I use Cerro cast a low temp alloy and vulcanizing rubber in a two piece mold. Again depending on the size of the part to be made will be a factor in weather you can just pour the metal in or not. Using high temp metal you still run into the problem of surface tension not allowing the metal to flow in to small areas. Steve
  12. Depending on the size of the anchors the low temp alloy my not flow into the mold. You may have to use some centrifugal force to fill the mold. Has to do with surface tension of the material I believe. Steve
  13. Another great little model, Javier interesting tiller arrangement.
  14. Have you done a search on this site for the Flying Fish ? I did a quick search and there seems to be a few builders logs on this model. Steve
  15. Welcome to MSW from another PNWer. Been through Graham many times
  16. Welcome aboard, could be a porcupine 🙂
  17. Long over due progress report, Dash is made and installed minus instruments, Steering wheel now has throttle lever, exhaust port on transom, Have some cleats cut out but need some fine tuning, Cockpit coaming installed, rear compartment coaming is installed
  18. Welcome to MSW, Also a pacific northwester, Pacific County
  19. Thanks, Bruce lots of nice looking boats in that catalog. Should be able to find some info in there.
