Chuck Seiler
Posts posted by Chuck Seiler
  1. I erroneously mentioned painting the keelson.  I was thinking false keel.  Keelson would not be painted.
    If you are going to stain or natural finish, I would keep the keel wood the same as stem.  I still recommend cherry for frames.  Alaskan Yellow Cedar for hull planking would work out very well.  I have used it for planking and it looks really nice with either a Wipe on Poly or Tung Oil finish.  (be careful of the splinters) 😜
  2. Brian,
        I am very jealous of your weather.  100 degrees for over a week here in Santee.  It is a little cooler where you used to live.
        Part of the answer to your question depends on whether you will paint the keel/keelson or not.  If the area in question will be painted, I don't see where it makes a difference if it is the same wood as the exposed part.  If unpainted, it should be the same wood (IMO).
        However, I do think you ar making a mistake by using AYC for the keel and frames.  In my opinion, too soft.  I would recommend cherry for the frames and (if painted) the keel.  Modeler's Sawmill has good cherry.
  3. Steve,
        Greetings from Santee. :cheers:   For more face to face interaction, I will refer you to the San Diego Ship Modelers Guild.  We are an NRG charter club whose info can be found on the main NRG site.  We meet on the ferry BERKELEY (Maritime Museum of San Diego) the second Tuesday of each month (today).  If interested, please IM me.
        I regularly direct SDSMG members to MSW.  I rarely get the chance to send folks in the other direction.
  4. 42 minutes ago, Mark m said:
    What, if anything, should I have done about the fraying ends?  Real rope frays, but this looks excessive.
    The frayed end in PIC 1 of post #8 doesn't look too bad.  Remember, this is a crappy @$$ed fishing boat, not a naval launch.  I'm not sure how much time they are going to spend whipping the ends of lines.  "Tie the knot and let's get back out on the water."
  5. Doug,
        Greetings and welcome to MSW. :piratebo5:  Where do you hail from?
        I have seen your BOUNTY build log.  Keep up the good work.
        I agree with Steven (Louie da Fly) about paddle steamers.  Having built the Missouri River boat FAR WEST, paddle steamers are good looking, can present as much of a challenge as a tall ship...without the pesky rigging.  There are several good kits out there.  ...besides, at a mere 61 you have plenty of time to crank out a several good models.
  6.     Isopropyl alcohol is the way to go.  Some use 90ish% whereas I prefer the 70ish %.  I soak the joint by applying the alcohol with a Q tip or cottonball, depending on how much area that needs to be removed.  Once well soaked and allowed to soften, I use an exacto blade (attached to the handle, of course) to gently separate the plank from the frames.  Resoak and let soften as needed.  Slow, gentle deconstruction takes time and patience, but is well worth the effort.
  7. 1 hour ago, Dion Dunn said:
    Unless anyone has some 'secrets to ordering from a Polish website when you live in the US", then I'm not sure what else to do.
         Since I don't know what your problems are, I can only add a suggestion which may or may not be relevant.
        I used to have all sorts of problems ordering/paying for items using PAYPAL.  :default_wallbash:  By changing browsers from FIREFOX to Microsoft EDGE (for those transaction) I no longer have problems. :36: Could that be the problem with GPM third party?
  8. RM,
        Your plan sounds spot on.  I am not familiar with the "Shipwright Series" (until I just looked at it) but I am familiar with Dave A,'s other work.  You can't go wrong with him being your instructor/mentor.
        Both appear to be a great intro into the basics of various building procedures and techniques.  The planking is simple, but complex enough to show you how to form the planks so they flow correctly and fit properly.  Take note of his suggestions on type of glue and the use of alcohol to un-glue mistakes.  (He says to use 95ish% but I use 72%.  The higher grade alcohol turns my fingertips to prunes.)  ...and if all else fails, basswood is pretty readily available so you can remake the part.  Keep a copy of the template for each plank (he sez from experience). :default_wallbash:
        Good luck!  I will be looking forward to following your build log.
  9.     Don't get me wrong, LONGBOAT is a great kit, just not a "basic" kit as it appears.  It may one where you buy now, set the kit aside for later and use the tools.  ALSO, Model Expo has sale all the time, so there is a good chance it will be on sale later down the road,  (SPOILER ALERT:  If you get on Model Expo's mailing list, you are guaranteed email for life. 😁 )
        If you search "first kit" or "recommended first ship model" you will find a couple great threads.
