Everything posted by clearway
is now a bad time to mention a european manufacturer makes a laser kit wooden deck for her😇- however excellent weathering technique with the deck. Keith
nows the time to decide if you want to show the steps leading down from the upper gun deck to the middle gun deck- you will have to squeeze a piece of deck in where the steps are😉 Keith
HMS Terror by Major - OcCre
clearway replied to Major's topic in - Kit build logs for subjects built from 1801 - 1850
weird i got wooden deadeyes with mine!? and even though wrong the ships wheels were bronzed- maybe due to manufacturing restrictions over last few months- i got some replacement boats from quaycraft via cornwall model boats. Keith -
good thing about using card is easier to make a load of frames fairly easy thus making for a stronger hull Keith
work progresses with the yards- i have seen a few people asking how you attach the yards to the masts- easy use the rigging designed for the task- if you glue or nail the yard in place it could cause severe damage if accidentally caught and trust me i have been playing knock the yard arms with this one😵. first shot shows one of the tyes rigged from the masthead through the block on the yard then through block attached to masthead before heading down to the kevel- process repeated in reverse as well to other side. shot of foremast- next job will be to rig the parralls then yard will be hoisted to final position. take care all Keith
got to look out for each other when it comes to irate beasties m8y
- 337 replies
- finished
- mountfleet models
work on the 2nd planking starts- decided to emulate the run of planks under the iron plating as per original- will make planking rest of hull with walnut easier. used the veneer strip originally intended for 2nd planking and got to say it is very splitty and i wouldn't like to use it for entire hull- kudos to you guys who persevered with it! marking out position of timbers on bow planking underway needed help from dressmakers pins to hold some bits till glue dried take care all Keith
looks great kevin- bet the mrs will give you a crack round the lughole if she sees that shot of her bent over😇😁- mine would 🤪 Keith
- 337 replies
- finished
- mountfleet models
welcome to the terror club- with a little research you can iron out occres shortcuts/ mistakes😉 Keith -
cornwall model boats Keith- it is a caldercraft fitting so might be available else where- not cheap though because of the size i suppose- around £16 uk stirling per metre 😵 but it certainly looks the biz😁. Keith
thanks Jeff - i have the longridge book too but them guys can assume you know the basic details and don't go into too much detail as to actual belaying- i decided to just run it through the Kevel in the end but a block and tackle then into the kevel would have meant lighter work for the crew = suppose most of the weight is taken by the slings and jeers though. Keith
