Everything posted by clearway
Happy New Year to you too- If doing mine again i would use a swivel yard crane style truss on the fore and main lower yards which i intend to use on my Erebus build. Keith
- 62 replies
- Arctic Exploration
- OcCre
Looks great so far keith- happy new year to you and yours and what a nice tidy work bench- mine literally looks like a load of B17s and Lancasters have carpet bombed it 😁 Keith
- 732 replies
- Lula
- sternwheeler
Coming along nicely, watch out because some of the measurements for wood strips on my occre Terror were way off. On Erebus i was lucky enough to have enough narrower veneer to make the planking more to scale- i didn't like how wide planking on my Terror looked. for my ships i use Evo-Stick fast grab wood glue but not sure how available it is outside of U.K.?
- 72 replies
- Erebus
Hope you had a nice christmas day and a happy new year to you both Keith- you know my stance on steam engines 🤩 Keith
- 732 replies
- Lula
- sternwheeler
coming along nicely Keith- the barrel on the donkey pile doesn't look like it shouldn't be there if that makes sense! Keith
- 732 replies
- Lula
- sternwheeler
Keith S and myself just reduced the 8mm dowelling to get the 7mm for the foremast- i used sandpaper around a wooden block and sanded lengthways while turning it ( was a lot of sanding but got there)! After asking Keith S for the mast dimensions from the admiralty plans it was found dimensions for a 10th class frigate were closest- when i matched up the other mast sections using Lees masting and Rigging Occre had got them pretty bang on so you can use the kits dimensions for the top masts/ topgallant masts- if memory serves me right Daniel D said he found references to the yards being the same length on the fore and main to help with interchanging if damaged- while i finished my HMS Terror i am still waiting for the other keith to restart his build log- our banter and build logs helped keep me sane in the dark days of Covid lockdown. Keith
- 72 replies
- Erebus
you are welcome Guy. If you ever have any questions about other alterations will help as best as i can. Keith
- 72 replies
- Erebus
where as occre have the bowsprit going over the top of the bulwarks with the new location it goes through the bulwarks more or less at deck level Keith
- 72 replies
- Erebus
if you look through my Erebus log there are pics of the modified bowsprit - just move the holes foreward , the angle is about the same. as regards the mast sizes - foremast is 7mm and mainmast 8mm- you should check out mine and Keith s HMS Terror build logs for more info as well, but at the end of the day it is your build and you are the shipwright in charge, just altering the mast diameters and adding the deckhouses makes a huge difference. Keith
- 72 replies
- Erebus
option 2 is the best option- looks better with the fuller frames doesn't she- also don't forget the holes for the mast holes on the main and fore will need widened if using right diameter dowelling and alterations to the slot for the bowsprit if moving to correct position as in my build log. Keith
- 72 replies
- Erebus
best way is to hold a planking strip across a few frames when trimming down to find any high spots- it was me who said you could reduce frames 6 & 7 as an alternative to save building new frames but a very rounded hull would result. Keith
- 72 replies
- Erebus
Yey another Erebus build at last- there are planking tutorials on MSW, just remember the planks taper fore and aft- how occre, amai and artesenia show in their kits is wrong! Keith
- 72 replies
- Erebus
it will look great when finished Keith- you weren't sure when starting the pile driver and she turned out great. Keith
- 732 replies
- Lula
- sternwheeler
ahhh the joys- nice to see you really getting your teeth into the alterations- i am in a similar situation with my Erebus build- i used Caldercraft brass ships wheels while Keith s and i think Daniel D used syren wooden kits for their Terrors- i also used the caldercraft wheels for Erebus. keith
- 62 replies
- OcCre
i strongly advise buying Matthew betts HMS Terror book as it has full drawings for the hull which will be o.k. as occre have just tweaked their Terror kit- i did mention at the start of the blog you can reduce the fullest frames to run better with the rest of the frames but a rounder hull will result- i just googled hms erebus lines plan and clicked on images option and scrolled through the results to build the new frames. Keith
takes me back to the quandries between keith s and myself when trying to fathom HMS Terror out!- nice to see building commence Keith Keith
- 732 replies
- Lula
- sternwheeler
Though not as drastic as having no fridge, sounds like our sofa and armchair scenario a few months ago- i gave them the measurements for the 12 foot long 33inch wide hallway and even taking the front door and the hallway door off they couldn't get it in! had to pay a little extra to get reclining armchairs that could have the backs removed so they would fit- but had to wait while they got re-upholstered to match the sofa- three months later we finally had our new sofa and chairs! keith
- 732 replies
- Lula
- sternwheeler
Rum fer yan mare Keith (can translate from Cumbrian if need be 😜)- slipped under my radar this one - another unusual/ interesting prototype. Keith
- 732 replies
- Lula
- sternwheeler
