j21896
Everything posted by j21896
  1. Capping Rail A very brief update: after a few weeks of indecisiveness coupled with a small case of “builder’s block”, I finally began to fabricate the capping rail. I taped in a short piece of dowel as a placeholder for the bowsprit, and after scrolling out the approximate shapes of the rail sections from cherry sheet , I've started test fitting and sanding them to about 90% of their final shape and dimensions. With them temporarily taped in place, I can work on fit between the sections. Using hooked scarphs for the joinery. In addition to holding things in place with tape, I’ve drilled a few holes where some of the treenails will eventually go, and temporarily inserted short pieces of copper wire to ensure proper alignment, and consistent positioning after removal for shaping and replacement. The deck furniture waits patiently in the foreground (atop some sections of old test planking) to be returned to their homes. Now back to cutting scarph joints! Cheers, Robert
  2. Wow Bob, I really like the views of the full hull! As previously mentioned, this is a great advertisement for the kit! Robert
  3. Very nicely done Bob! Congrats on completing a fine model. Cheers, Robert
  4. Hi Mark, I was a silent follower on the old MSW. Your Bellona is beautiful! I too really like the black chocks to match your black hatch coamings. Cheers, Robert
  5. Hi B.E. Gorgeous work! Those sails are amazing! And your sea looks so real! Congrats, Robert
  6. Yikes! And a huge sigh of relief for you Augie. Robert
  7. Say it ain't so Hakan! I'm not ready to let go of this build Of course, if you post lots of really good photos in the completed ship Gallery, that would probably help my withdrawl Cheers and Congrats, Robert
  8. Nice work Patrick! The rigging looks great. And she certainly is a tall old gal isn't she! What size case will you need to put her on display? Robert
  9. Very nicely done! What plans did you use for your build? BTW, I spent a winter up in Thurso, Scotland back in the 70's. Not many daylight hours way up there in winter! Cheers, Robert
  10. Hi Rusty, This is a beautiful build! Could you tell me what type of wire you used for the hatch cover ring bolts? Is it black wire, painted, blackened? Also, what is the inside diameter of the rings? I've seen documentation for the size of ring bolts used on gun carriages, but never for hatch covers. Thanks, Robert
  11. Hi Ron, That is just beautiful planking! I can't believe this is a "dining room table build"! Everything about it says "full woodworker's workshop"! By the way, that is also one beautiful shipyard "supervisor" casting a watchful eye over your build! Cheers, Robert
  12. Thanks Jay! That's a much more effective modification than simply making a shim to fit under the plastic insert. Kills a couple of birds with one stone -- provides a uniformly flush table, and zero tolerance opening! Cheers, Robert
  13. Excellent! Thanks Jay. Robert
  14. I recently got the very affordable Ryobi scroll saw, but have only used it a couple of times so far. One annoyance is that the plastic insert around the blade does not sit flush to the table. I made a plastic shim ring to eliminate that. However, it sounds like Jay may have a better solution that also solves other issues with it. Jay -- could you expand on your modifications to the saw? Thanks, Robert
  15. Hi Elia, Very clean and precise work! Looking good. And by the way, in looking back through your whole log, worthy of mention is your Smuggler build. She's a real beauty! Cheers, Robert
  16. You must be doing a good hiding job Hakan, because she does look good. Just curious, what thickness of planks did not work? And what thickness did you finally go with? Cheers, Robert
  17. Clean Man! Real clean! Oh yuh, she's going to display well Cheers, Robert
  18. Very nice Patrick! Keep those pictures coming. You're really nearing the finish line there. Also some fine looking reading material! Cheers, Robert
  19. Thanks Jay, I'll check that out. Robert
  20. I imagine they never could have dreamed how captivating their work would be for so many people -- and for so long! Just amazing stuff.
  21. Interesting. Thanks Greg!
  22. Recent postings of Rogers Ship Model Collection photos got me wondering if much is known about the builders who created those masterpiece model ships -- two hundred and more years ago – as well as those in the NMM and other museums throughout the world. Their creations remarkably live on today, but what history of the builders themselves has been left behind? Did they keep any type of “build logs” or records of their work processes? What were their workshops like, etc.? The craftsmanship is astounding; I can’t imagine how they did it! No modern conveniences, power tools, etc. How long could it have taken them to build their models? Cheers, Robert
