hof00
Everything posted by hof00
  1. Thank you, kindly Sir. My first Ship with "Guns." 🙂 (I think that I can do better with my 1/200 Trumpeter BM, in a year or two perhaps? (Endeavor first now that I have the bench space....)) Cheers.... HOF.
  2. Hi All, A few final pictures of the Bismarck on its' "Table" and finally enclosed by its' Acrylic case. I can now call this project complete. (I now have some bench space to carry on with the Endeavor!! 🙂) Cheers.... HOF.
  3. Looking really good!! I had issues with the Stern Bulwark also and ended up using the "Shattered" kit ply piece as a template for two 1/32 ply laminations, I'll be interested seeing the lighting kit . Cheers.... HOF
  4. Hi John, I bought the "Partworks" version. As you are aware, it is Amati, I am of the opinion that this was a "Pre-Prod" thing. There are 140 issues to the build and the instructions will have you bouncing backwards and forwards, all good fun!! 🙂 I think that you'll be pretty much set if you have all the parts/magazines. Only one plan came with the 140 issues, a 1:1 Plan and sheer view of the model/ship. I used this for Reference only as placement of sub-assemblies/rigging/etc. is covered quite well in the magazines. Unsure if this helps. Cheers....HOF.
  5. Very Nice!! Looking forward to your build!! My BM was a "Partwork" thingy, I guess a pre-prod of the real kit but same contents with the "Amati" badge on stuff and the option to go RC.. (Currently awaiting a 1400mm long acrylic case for mine..... Takes up allot of workbench real estate. 🙂) Cheers.... HOF.
  6. Very nice!! It sounds like you are building this for a very good cause indeed!! 😞 Cheers....HOF.
  7. Very nice build!! I'll be very interested to see how you get on with you Bismarck build when you get to it. 🙂) Cheers.... HOF.
  8. Looking really good!! I'll be following along. Did you have a template for drilling the "Grab Rails" (Ladders) on the sides of the Hull? Cheers.... HOF.
  9. Hi OC, Personally, I'm just following along. I enjoy the detail and the "Wots next" installment. Your project is awesome as, I am sure, will be the finished result!! Cheers and Regards, Harry.
  10. I am tending to agree! 🙂
  11. Hi All, Still slow.... Esp. when subject post selected has photos. Text content, no problem. Other sites seem fine. (Maybe something with comms from the Antipodes?) Ping varies 124 - 137ms No packet loss. Cheers....HOF.
  12. Hi Keith, I have had the same issues over the past couple of days also. Cheers....HOF.
  13. Hi Chap, My experience with A/L kits, Decking is usually 0.5mm thick. Have you thought about dropping A/L a line to express your displeasure? (Maybe you could request replacement Planking?) Cheers.... HOF.
  14. Nice Save!! (That Decking must be very thin, 0.25mm?) Cheers....HOF.
  15. Hi All, Thank you all very much for your detailed responses, very much appreciated. I now have some very good "Food for thought." Cheers.... HOF.
  16. Hi All, I have been watching a series build of the 1/200 Bismarck on You Tube, (The Model Shed), and the Chap who performs the build advises Surgical Tweezers. I guess a couple of questions: What do you all use for PE Do Tamiya Tweezers cut it Where do I obtain "Surgical" grade Tweezers at a reasonable cost Cheers....HOF.
  17. Very good. Is there a LED lighting kit for the "Upgraded" version also? (I did my own Lighting kit.... 😑) Cheers.... HOF.
  18. Very nice!! The "Upgraded" version does lend itself to what looks like a straightforward Radio installation if that's the way you go. I saw a build log some time ago with a conversion of the "Old" kit to R/C. (I don't believe it was ever completed.) Cheers....HOF.
  19. Hi Chap, I found the Reefing Gear the most confusing. I must admit that I used a bit of Modeling "License" to create something reasonably acceptable. Also, if you are going to use the kit Sails, my Mainsail was too short, (Luff?), for the length of the Boom given on the plans. Cheers.... HOF.
  20. Hi Chap, Looking very "Sharp." (Pardon the pun.... 🙂) Pedestals look the part. Agree, the Stand provided is not worth the time or effort. If I had it over, I'd turn a couple of wooden pedestals. (Which I now do for my builds.) I went with 6.0mm, (From memory), Brass Rod, looks o.k. IMO Spray Putty is an excellent solution for that really smooth surface!! I had heaps of "Fun" painting my Hull, I used Vallejo Acrylics, no problem, I then thought I'd be clever and try to get that "Mirror" finish and sprayed with automotive lacquer, looked really good until after 24 - 48 hours afterward when it all started to Craze. I had to sand everything back and start again.... and again as I had not managed to get rid of some of the lacquer the first time around. My error, I had not tested the Paint/Lacquer combination properly. In the end, I just left the paint with a satin finish. I am sure that you wouldn't make the same dumb mistake as I, a learning for myself, character building? 🙂 Cheers....HOF.
  21. Hi Chap, You are making some awesome progress!! Looking really good. Cheers....HOF.
  22. Nice work!! Looking forward to the Yards and the running stuff.... 🙂 Cheers.... HOF.
