GuntherMT
Everything posted by GuntherMT
  1. Like all your other self-made tools, this is a work of art as well as a useful tool!
  2. Merry Christmas to you and your family Rich, and a Happy New Year as well!
  3. Traditional wooden boat construction does not edge glue the planks (they don't glue the planks at all actually) and there is a built in gap at the surface of the planks that they pound caulking into to seal the planks. Basically there is a flexible 'gasket' between each plank to stop water ingress so some swelling or shrinkage shouldn't be a problem because they handle it in the design/construction.
  4. Did not see this while you were in progress, but just wanted to say nice job, that's a great looking little boat!
  5. I use nothing but PVA (wood glue) for the vast majority of my construction and for all of my planking, no reason IMO to use the super-glue type glues if you properly shape your planks before fitting. If you get super-glue type glues on a wood surface that you don't plan to paint, it can be impossible to remove the stain left which can soak deep into some types of wood.
  6. Hello Scott! As another Phoenix area resident, I welcome you to MSW.
  7. Just one guys opinion, but I much prefer the larger pictures where you said you couldn't insert comments. Not sure how it looks on your Chromebook, but the forum should handle all your photo's without any problem, which puts them in a 'pool' of images to use in your post. You type whatever you want to type, and wherever you want an image you place the cursor and then scroll down to your images and click the "+" (plus) sign on that image and the forum software inserts it into your post at that location. If you don't do that step, then all the photo's will just be at the end of your post. My method is generally to upload and insert one photo at a time while I'm typing in the post so that I get them all where I want them.
  8. The only white metal parts from my MS kit (AVS) that I used were part of the anchors, the mast hoops, the fitting where the main-mast and top-mast connect and the ships wheel. Oh, and the fitting where the bowsprit and jib-boom attach. All the other cast metal parts went in the bin, I replaced all of it because it's pretty universally garbage in my opinion.
  9. Coming along nicely and looking good. If I lived anywhere even close to a lake I would definitely want to build something like this. Would be a great way to get some exercise paddling around a lake!
  10. Looking good. Sanding tip for soft wood (I'm unsure if this is a double planked model or if that is the final planking and will be painted) - get the wood damp. Don't soak it, just run a wet cloth across it. That will cause the grain to raise, then when it's dry give it another final sanding and it will smooth out very nicely.
  11. You could also simulate both ends $10 for 25 - Simulated Nut end - https://model-motorcars.myshopify.com/collections/small-parts-hardware/products/simulated-hex-nut-brass-nickel-plated-1-2-mm-sn12n
  12. Looks like $8 for 20 nuts - https://model-motorcars.myshopify.com/collections/small-parts-hardware/products/nuts-hex-head-0-80-brass-z071b Washers $6 for 50 - https://model-motorcars.myshopify.com/collections/small-parts-hardware/products/washers-brass-1-6-mm-k023
  13. I used white vinegar to clean all my metal parts for blackening without an issue. I have acetone but only work with it when absolutely necessary as it's quite toxic and can be absorbed through the skin.
  14. Congratulations and nice work. You can proudly display that wherever you want.
  15. You don't say where you are getting your scale hardware now, so hard to say where to get it cheaper. The only place I'm aware of for things like this is https://model-motorcars.myshopify.com/collections/small-parts-hardware Alternative method would be to buy the stock and buy tiny jewelers taps and dies and make your own, no idea where to source that stuff and I'm sure it's not cheap though.
  16. Congrats on completing your first scratch build, looks good! Nice to see someone building the Star, I've never gotten to see her sail, but I've been onboard many times.
  17. Spanish translation for Bob - Good evening, on December 5th I bought you 3 books, Rigging a Sloop of the Sixth Category of War 1767-1780, Frigates of the Royal Navy HMS EURYALUS (36) 1803 A Plank on Frame Model, Volume I by Allan Yedlinsky and Wayne Kempson and the Frigates of the Royal Navy HMS EURYALUS (36) 1803 A Plank on Frame Model, Volume II by Allan Yedlinsky and Wayne Kempson. Please tell me when you send it to me, by what means of transport and the tracking code, the tracking code is very important. I look forward to hearing from you.
  18. I am pretty sure that one of the big reasons for the narrowing profile is weight, especially as high up on the hull as the knees are you want the least weight possible. In any case, thanks for the reply, I'll stop side-tracking this build log now.
  19. How would you make those complex shapes for some of the knees in an open pour? Or are you just referring to the more basic shaped ones. Even then, how do you get the narrowing profile, just have to remove all that extra material from the open side afterwards?
  20. Going to be following along with you on this one. I really love that we have been starting to see quality kits that allow people to build true POF construction from at least a couple companies. The future seems bright for the hobby!
  21. I've seen a few pictures of this on the Facebook page, but nice to see you posting it here. Seems like it's been quite some time since your last update, I hope you haven't given up on this project, or posting it here!
  22. Hi Rich. Had no idea you were doing this, looks good so far. You asked a while back about where to get wood, did you ever get an answer? If not, what size and type of wood are you looking for? If you want basswood I have a bunch of different sizes. If you are looking for more hardwoods, tell me what you are looking for and I can see if I have or can cut what you might need.
  23. I'm looking forward to seeing your workspace solution, sounds pretty interesting!
