Posts posted by Ronald-V
Little update...i'm just 6 planks and a garboard strake away of finishing the first layer of planking. Going not so very fast, but enjoying the process.
Halfway planking the hull I realized I wasn't happy with the shape of the bow and stern. I sanded them a bit to conservative and this resulted in not a real nice flow in the planking. So made the decision to brake away the planking at the places where I thought it didn't look right. So this was a bit of extra planking fun
, I learned some extra bending techniques along the way, so it was helpful also. I also realized that with lining off the hull using tape that I didn't took enough time to really check the run of the tape (because the tape didn't stick well). This resulted in a bit of a waviness pattern across the hull. Therefore I did the process of lining off again, but this time with wooden battens. For me this works better because of the stiffness of the planks...you won't have to check every bulkhead if the plank waves up or down the hull. So that was also a valuable lesson for me.
So first broke the planks away for reworking the bow and stern:
After that I used wooden battens for lining off the hull:
And now almost closed! 🎊
Lovely project to watch developing! 👍🙂
- mtaylor and cajunrandy214
2
That is an impressive result! Congratulations with finishing this build
, also great thorough review!
1 hour ago, KurtH said:
Thanks! I put them in today and found that they fit so tightly that once they are in position, they are not going anywhere. That spacer on top was a bit of a challenge for me. It would not fit into the notches in the tops of the stern timber pieces so I had to file it to make it thinner. I got it done though. It will be pictured in my next post. Meanwhile, on to the installation of the gun deck.
I experienced the same with the spacer...needed some really carefull sanding here and there 👍
Welcome! And love your first build, it looks great
- BrochBoating, Keith Black, AJohnson and 1 other
4
I can't even remember if I l glued them straight on, or painted them after...but they can be fitted in just one way isn't? If I remember correct, they sit very tight in there slots
so I think I dropped a bit of glue in there and secured it right away....but after dry-fitting everything first. Also the spacer on top.
Great review James!
- markjay, Canute, Ryland Craze and 1 other
4
Love that you make choices you like!
1 hour ago, chris watton said:
Don't usually see that much of a gap.
I would just cut a 'shim' of pear and glue it to the stern post, to bring it in a little more.
You mean...sort of widen the lasered pattern that goes on top the stern post? Or kind of a ramp where the second layer can lay on top of. (sorry for the bad English
1 hour ago, Blue Ensign said:I had a look back on my log and looking at the photos I took there doesn't seem to be that much difference at that stage.
If you look at the manual p33 you can see the first planking finishes around the same point, and even shorter lower down. (deliberately)
Remember this has to be fined down sufficiently to allow the second planking to fit the stern post.
Carry on Mugje, you're doing a fine job.
B.E.
Yeah I saw it too in more build logs that it isn't really that much different, but in almost no build logs it wasn't really visible how the second layer ends there you would almost think that there would be space underneath the pear plank that connects to the rudder post pattern.
I will look further into it
Okay people...not an update but some questions...still working on the first layer of planking (lot's of experimenting
I have a hard time picturing if the corner and angle of the sternpiece is right. And couldn't find a clear example in the other logs that could help me visualize it. Maybe a bit difficult to explain, let's see if I can make it clear.
I temporary placed the rudder post with his pattern so I can see where the second layer of planking would end. And when you look at my pictures...there is quite a gap between first layer of planking and the rudder post pattern. Much larger then the 0.8 mm thickness of the pear planking 😄. So if I would lay the second layer of pear on top of the first, there would remain quite a gap to cover. I thought...i'm going to adress it now, maybe there needs some changes in the stern piece and now it's not all covered in planks.
Maybe there is to much roundness in the stern filler piece?
Also...do you guys think the part with the yellow circle in the picture below is faired enough? And not to round? I thought...maybe it needs to be a bit straighter to get a smoother transition to the MDF keel.
Congratulations on your succes Chris! Working on your Sphinx now...your succes doesn't suprise me when I see the quality of it in comparison with the more traditional manufacturers, but take care in managing you and your wife's energy
- chris watton, Canute, thibaultron and 2 others
5
That looks amazing! I really do like the change in colors of those beams...the white and the red on the sides
- mtaylor and Blue Ensign
1
1
13 minutes ago, Gregory said:
Have you considered using veneer to make planks.
Stores like Rockler have a good selection of maple..
Thanks Gregory, but I think I will go for the boxwood. How more I look to the combination with the pear the whole ship gets a nice warm tone in my opinion. So I think I will settle for that
28 minutes ago, Wahka_est said:
Hi,
I dont have any maple sadly.
I think very light swiss pear might so something that you are looking for.
Boxwood is yes yellowish.
For white deck there is also option to use American Holly.
Br
Vahur
Yeah the pear would be for the outer hull of the Sphinx. I will look into the Holly and see how that looks for the deck otherwhise I will go for Boxwood. I Will send you a e-mail one of these days with what I would need.
Thanks for answering already
I think I need some of that lighter pear stuff...but my laptop hasn't got the right screen colors, so i'm going to compare it on a friend his computer.
So you don't have maple in stock? I need some deck planking for my Sphinx...now I saw that Blue Ensign used Boxwood for the deck planks...maybe that's a option for me to if you don't have the maple.
I think Boxwood and Maple are "yellow-ing" a bit the same over time, so maybe it doesn't even matter that much.
Bristol 1775 - from Warship to Prison Hulk
in Nautical/Naval History
Even without VR it was interesting
...I did read that Chris wanted to design this one, if he does...that would be an epic kit 😮
