Posts posted by Ronald-V
22 hours ago, glbarlow said:
Seems ready for second planking to me, well done!
Thanks Glenn and everyone else for the likes! And everyone that has visited my buildlog this year, giving likes and comments/tips how to improve. Hope to see you next year again. I wish everybody a healthy and fun new year ❤️
- AJohnson, Mr Whippy, chris watton and 3 others
- 6
3 hours ago, chris watton said:
You do not have to fully rig it, you can leave off all sail related rig and just add yard rig, the ties, lifts and braces, and leave it at that. That also means a lot less blocks to tie to the lower yards.
Thanks for the suggestion Chris! I'll take it one step at the time...and see where I end
Good luck with your Sphinx journey! It's such a lovely kit...I also toyed with the idea of building it without rigging etc. due to space saving. But I also lack the experience to rig a three masted frigate...so i'm going to rig it just for the experience I think...but I have some time to decide it so nothing is set in stone at this point.
Well a disc sander with adjustable table (like the proxxon one) made my modellers life a lot more enjoyable. It makes it so much more easy.
And a Dremel ofcourse...those two are my essentials...for now
- Ryland Craze, kuya, Bob Cleek and 2 others
- 5
Last update this year I suppose
The hull is now sanded smooth and the little cracks/deeper lying planks etc. are filled. Ready for the next step I guess.
I will test fit the prow/keel and sternpost patterns to see if it fits right, and maybe there are spots that need a little extra sanding (places around the tabs that are connected to the prow and keel). Also need to test fit the lower counter ofcourse. I think I also need to check if the upper hull side patterns are flush with the gunports inside. I haven't done that yet, but also didn't see it mentioned in the manual. Would be a good moment for that.
And be aware....when you are at the part of glueing it in place....don't put glue on the deck, but only at the false deck below. Because the PVA will moisture the wood causing it to swell a bit. This resulted in that the deck didn't fit anymore because I couldn't get it fast enough onto the false deck, and as a consequence...the deck became fixated in this swelled up size due to the glue that dryed. So I messed this up a bit Totally my own fault due to the inexperience working with thin sheets of wood. So maybe I can warn others to not make these mistakes
- Mr Whippy, DonSangria, Clark and 2 others
- 5
That a beautiful result so far!
- mtaylor, Knocklouder, JeffT and 1 other
- 4
Looking forward to see your progress on this one.
- KennyH78 and Ryland Craze
- 2
Yes Sphinx is a good alternative, but not sure how experienced you are. I'm building it now and it's a real joy. Your criteria of decent instructions and materials are met with this kit. I can't judge how difficult it is because i'm not that far into the build yet, and i'm considering myself a experienced beginner. But knowing the designer and prototype builder are here on the forum, that gave me enough confidence for trying to tackle this kit
Finally closed! Took a bit longer then expected because I was quite sick last week with a flu and fever, but feeling good now so I could do the last planks.
I used some 1mm pear that I had lying around, because I had run out of the lime wood. Not because Chris didn't supply enough, but because I redid such large areas.
This gave me the change to get a bit familiar with pear wood and how it behaves, so maybe that gives me a bit of an advantage for the final layer.
I couldn't get the first layer exactly as I wanted, without mistakes and knowing exactly what I did, but I have learned a lot!
So hoping that I learned enough to get a decent second layer that I could be happy about and leave it unpainted. Otherwise there is always the option to paint
it white if it's not too great
Now first some sanding and filling here and there to get a nice smooth base for the second layer.
- dunnock, ccoyle, Blue Ensign and 19 others
- 22
Congratulations! That´s a real beauty!
Welkom! And nice model you have there
- Keith Black and mtaylor
- 2
Welcome
- Deyson Morken, Keith Black, mtaylor and 1 other
- 4
26 minutes ago, Thukydides said:
Looking good. A minor point, the butts of the planks should be perpendicular to the keel (they are attached to the frames on a real ship). So they will not always be at right angles. A relatively minor point that I also didn’t realize until part way through my second planking.
Oh wow...never thought about that either
- Thukydides and Mr Whippy
- 2
Sounds not like a small production with those names...congratulations Chuck!
HMS Indefatigable by ECK - FINISHED - Vanguard Models - 1:64
Great result! And like Blue Ensign said...impressive construction speed!
