davyboy
Everything posted by davyboy
  1. Hi Ed,I just want to say how much I am enjoying following this build. Absolutely wonderful workmanship. I noticed in your close-up pic the futtock shroud hooks appear to be opened out somewhat. I had this problem using copper for hooks,I found that giving the hook a bit of a squeeze with a pair of smooth jawed pliers work hardened the copper somewhat. They then had less tendency to straighten. I can't remember where or when I read this but it worked for me even on 0.5 mm copper wire. Regards, Dave
  2. Daniel,Jason, That item is called the Cap Shore. It was fitted to take the strain of the weight of the forward overhang of the Cap from the shoulders of the Mast Tenon. It was tenoned into both the Cap and the Top and was usually only fitted on 1st and 2nd rate ships. Dave
  3. Hi Ron, If you decide to order wood from Deutschland check out www.massiv-holtz-werkstatt.de also. Frank Horschig has no problem with orders in English. He has a very good selection of timber and is not expensive. I do all my ordering by email and pay by bank transfer. No connection with him,just a very satisfied customer. Dave
  4. Hi Cal, The Caldercraft Victory is 1/72 scale and they also manufacture Cannon in that scale and probably also gun carriages. I've just looked at Cornwall Model Boats website and they list Caldercraft Cannon at this scale. Dave
  5. Hi Chris, Here is what Lees writes verbatim "usually the boomkins butted against the beakhead though sometimes they butted or were bolted against knightheads on either side of the bowsprit,this latter method being used mainly after 1800". He does not mention anything as to how high they would have been mounted. Unless some other forum member can give you better info,I guess "its up to you *. Sorry I couldn't be of more help. Dave
  6. Hi Haliburton, Sorry but I don't have any pics. So far I've made the gratings,gun carriages,pump bodies and milled mast/yard sheave slots for my Cheerful build. I intend to make all my own blocks and will fit sheaves in all but the smallest. I also made my mast coat using the mill. I've really enjoyed doing this plus it saves one money. My next buy (when I can afford it) will be a lathe. I could kick myself for selling my Unimat SL back in the 80's when I stopped modelling. Regards, Dave
  7. Hi there Haliburton,you should definitely buy the MF 70 mill. I bought one earlier this year and wouldn't be without it. There are only 2 extra accessories made for this tool AFAIK,a rotary table #24264 and a machinists vice #24260 and they're not very expensive. Dave
  8. Hi Gregory, Thank you for posting that drawing. My plans were bought from Chuck back in 2015 and do not have the amendment you show which is of course a revision. I could not understand why no means of applying tension to the Topmast stay was shown on my plans. My problem is solved. Once again thank you. Kind regards, Dave
  9. Hi Gregory, Thank you for your reply. My Plan #2 (for the standing rigging) distinctly shows the topmast stay fitted to the Topmast as would be normal,no block nor tackle is shown. Yes,this plan shows the Topmast Backstays are attached to a tackle,perhaps you could be mixing the two up or you have a different plan to me. Plan #3 (for the running rigging) only shows 2 blocks on the Topmast ,these are for the Topsail yard lifts. The list on this plan also quotes only the rope size for the Topmast stay,no mention of blocks nor rope for a tackle for this stay. Kind regards, Dave
  10. Hi all, I am currently building Chucks' Cheerful and have a question about the rigging of this stay. The plans show it directly attached to the Bowsprit. It's well known that hemp rope was prone to stretching so it is my intention to run it through the centre sheave of a treble block (the other sheaves are for the Topsail braces) either to a tackle or thimbles and a lanyard. Also,the Bowsprit has 3 fid holes which tells me that it could/would be set at different lengths according to sailing requirements. I'm sure that the Bosun and Captain would not be happy with a Topmast stay flapping about in the breeze when the Bowsprit was "run in" so to speak. Just doesn't sound right to me. I've never seen a rigging plan that does not show some means of tensioning stays whether it's with hearts,deadeyes,a tackle or thimbles/lanyard. I did mention this to Chuck but he just said that's how it's shown on the original model. It's possible of course that the builder of the original model got it wrong but that's just my thought on it. Any comments will be gratefully received Dave
  11. Carronades at least initially were not as I have read somewhere classified in the R.N. ratings "system" as guns. Only Cannon were counted. Dave
  12. Hi RussR, Just a thought,but why not buy a couple of feet of 4mm x 4mm walnut from your local model shop and cut off the lengths you require,I'm sure you will be able to find a use for the remainder. Dave
  13. Hi Steve, after 1743 a Royal Navy 3pdr cannon had a length of 4'6" according to Lavery in his Arming and Fitting of English Ships of War book. Can't help with your other questions but I suspect Carronades would have been more likely. Regards, Dave
  14. Hi Mark P, Thank you for that info,much obliged. It means I don't have to blacken the brass set I've made for my current build. Kind regards, Dave
  15. What metal were pintles and gudgeons manufactured from in English 17th and 18th century warships. Bronze or Iron ? Lavery does not mention which in his Arming and Fitting of English Ships of War. I would assume Bronze as Iron and Saltwater don't mix too well Thanks, Dave
  16. Hi Christos, That is called a knight. It was used for raising or lowering the lower fore,main and mizzen lateen yards in conjunction with a rams head block. The tie started near the yard centre went over a groove or sometimes a sheave in the cap down through a hole in the rams head block then back up through the sheave or over the groove on the other side of the cap and down to the yard on that side. This should be shown on your rigging plans of which I assume is of a French ship. That is how they did it. Can't see from your pic but I'm pretty sure there will be one abaft your main and mizzen masts also. Hope this helps. Dave
  17. Hi Michael, That is almost certainly a Chinese knock off of the Proxxon KT 70. Looks almost identical even down to the colour,doubtful if it's anywhere near the same quality. Dave
  18. Hi, I can't say for certain but I believe that with the introduction of the long driver boom the stern ensign staff was not fitted when the ship was at sea,only in port. As was I believe the jackstaff on the bowsprit. The photo's show apart from the sloop a loose footed gaff sail on all the others,some still having a Lateen yard fitted. No problem with a stern ensign staff then. I suspect by looking at the angle of the pic that the sloops' driver boom was short enough to pass inside the ensign staff. Of course,it would be easy to transfer the gaff ensign halliard to the opposite side if or when required. Unfortunately I'm not at home just now so can't check in my Books. Dave
  19. Mike. Middling means if 50ft of brail rope is req'd on one side you use a 100ft rope fold it in two and sieze it to the cringle at the fold. Yes there is a block on each side of the yard and both sides would be hauled on simultaneously. Methinks the eyelets are a kit invention,nothing about eyelets for brails in any of the books I have. Boltropes and cringles are much stronger than sail canvas. Dave
  20. Hi Jeremy, If you're looking for wood you could try the following German wood suppliers :- www.massiv-holz-werkstatt.de www.arkowood.de I've bought wood from the top one,excellent range,quality wood and service. A bit closer than the U.S. to Cape Town. No connection to that business BTW. Regards, Dave P.S. forgot to mention both supply strips and planks
  21. Hello KAT, Ulises Victoria a Mexican member lives in Monterey. Perhaps if you contact him by PM he could help you with information on suitable wood available in Mexico. He has a build log of the Royal Louis on page 7 of the Kit Build section of the forum. Kind regards, Dave
  22. Hi Christian and Sjors, The purpose of the Crowsfeet was to prevent the foot of the Topsail chafing on the rim of the top. Dave
  23. Hi Folded Frog, Jackstays would not have been in use on the HMS Agamemnon 1781. They were not introduced on English warships until post 1810 according to Lees' Masting and Rigging of English Ships of War. You'll have to bend the sails to the yards. Dave
  24. Pete, I agree with both John and JCF's posts. Additionally to Lees,R.C. Anderson in both his books also gives a Parrel as having 2 rows of trucks. What is shown in your photo looks like a bit of modellers "inaccurate fancy work"to me. BTW,the HMS Royal William was a 1692 rebuild of the HMS Prince of 1670. There were only 2 ships given this name,the second being launched in 1833. Regards, Dave
  25. Hi Terry,I'm pretty sure there is not a model kit of this ship. She was a Leda class 38 gun Frigate launched in Bombay in 1817. I would imagine her plans are available from the N.M.M / Royal Museum Greenwich. I guess you were watching "Flog it" on BBC 2 earlier today Dave
