Canute
Everything posted by Canute
  1. Here in the US, we call them T nuts. A good, sturdy mount you've made, Chris. Nice job, so far.
  2. Doug and crew, put some fine sandpaper on the underside if your steel ruler to keep it from shifting. I work some in styrene and had a bit of a time keeping cuts straight before I wised up.
  3. Nice, Frank. I'll slide into the second row and follow your excellent work.
  4. Bug, very nicely done. You have paid honor to a fine gentleman. Thank you for all your work.
  5. As long as you're not gluing parts to yerself, mate. Acetone is not good for your longevity.
  6. DR, I'd like to follow along, too. And good luck chasing down some torpedoes. They're as scarce as hen's teeth. I do like the Flak 38 version. The Prinz Eugen site has a section on these "boots": http://www.prinzeugen.com/SBOATIND.htm
  7. Carl, nice job with all that fiddly work. The turret/gun houses look good.
  8. Tru-color is acetone based. Wide range of colors aimed at model RRers. Supposed to airbrush nicely.
  9. Ron, is the exhaust vent going to be permanently installed in a wall? If it will, put some screen in the vent to keep squirrels and other critters out of your building. Don't ask how I know this...
  10. Great looking gear, Michael. I'd love a set.
  11. Len, looking good and dirty there. An idea for LED lights inside. Look for yellow-glo LEDs, looks like kerosene lights when lit. May have to go to a train shop that stocks Miniatronics products. For tar paper, cut the strips in 3 or so foot widths. That was a typical size for that stuff. Could also paint some weathered black/charcoal gray paint and lay strips of tissue on the paint. Although, it may look like old canvas with the grain of the tissue. Experiment.
  12. What the heck is it, Carl? Your pictures of your progress look very good.
  13. Good luck with the repairs, Chris. A wood Yamato to go along with Greg and Carl's opuses.
  14. A good hobby shop selling decal sheets most likely stocks the stuff. If you've built planes, trains or plastic ships and applied decals, it's in that area. I've filled an opening of about 3/8 inch square. Much bigger and I'd use clear plastics or maybe microscope cover glass.
  15. If the window panes are small, MicroScale Krystal Kleer. It's a liquid you run around the inside of your window. Put some on a toothpick, slide the pick around the window edges, slowly remove the toothpick and the liquid should fill the space. Practice before you do it on Chaperon.
  16. I've seen Ed's work and can tell you his use of this wood is outstanding. His miniature furniture is second to none.
  17. I've used this on wooden model RR structures and it hasn't affected the wood. I do recommend that you test the stains on a scrap of the same wood you want to stain. You can also use India inks in denatured alcohol (found in pharmacies or chemist shops) for stains.
  18. The Pan Pastels aren't oils. You can wipe them off if the color doesn't get pushed into the wood too deeply. I remember two sets of chalks, one in greys, the other in browns. We scraped or sanded the sticks get quantities of pastel powder to work with. We should start a new topic for this and not highjack Len's log.
  19. Len, take a look at Pan Pastels. Here is one site, aimed at modelers versus the fine arts folks: http://modelingcolors.com/ They stock 2 weathering kits for rust & earth and for greys, grime & soot. I think the armor folks discovered them, but many different areas use them now. The site has a how-to video and basic use instructions. Hunt around on the web for best prices. I am just a satisfied user of this product; no financial interest in this company.
  20. Len, coal pile looks good. After it's installed, dribble a few stray lumps in front of the pile. Your firemen aren't neat.
