ccoyle
Moderators
Posts posted by ccoyle
  1. Step 24
    One of the Step 24 elements is the racks that are part of each K-gun station. The kit includes an option for building simplified racks that have printed depth charges, or one can choose to cut out the printed charges out and swap them for three-dimensional ones. The detail set includes laser-cut parts to replace some of the printed parts. I went with the most detailed option. It can be done, but it's a tedious process. Bending and gluing the rack parts together is kind of like trying to assemble a 1:1 scale spider, and of course each of the four depth charges needing to be built is a rolled cylinder with two end pieces. A finished rack includes 16 parts, and there will eventually be 8 racks (plus the stern racks, which will be even more complex). So far I have completed a grand total of - - one.
  2. There are generally two ways that designers use to join fuselage sections, either joiner strips or butt joins. Which method a kit employs should be apparent from the parts and diagrams. If joiner strips are intended, they will obviously be printed in the kit somewhere, usually right next to their fuselage sections. Sections that are butt joined will have an internal former at each end of the section. From your photos, I'm guessing this kit uses butt joins. Personally, I really dislike butt joins, as there is little to no room for error -- the two ends to be mated must match each other exactly, otherwise a fairly hideous seam will be apparent.
    Regardless of the outcome of this attempt, you have learned some things about the world of card modeling, both the skills required and the potential pitfalls, and this will make the next build easier to some degree.
    Cheers!
