Everything posted by ccoyle
Ah, but the trials just keep on giving! Turns out the propeller is also wrong, based on a thorough internet search for photographic references. Of course, the designer doesn't mention (well, maybe he did, but it's all in Polish) what he used for source material and where he obtained it. So, I will be making some alterations to the propeller structure as well. Happily, it is the last major assembly, so after this it should be smooth sailing.
Le Superbe by Daan - Heller - PLASTIC
ccoyle replied to Daan's topic in - Kit build logs for subjects built from 1751 - 1800
If this is the 1/150 kit, then I'd say yes, to-scale gun tackles would be ridiculously difficult to create.- 3 replies
- Le Superbe
- Heller
D The instructions include a link to the source plans upon which the kit is based. I'm not familiar with the kit contents myself, but are you certain that plans aren't included, or were they just inadvertently omitted from your kit?
Bryan, I redacted the personal information from your posts.
- 80 replies
- mayflower
- constructo
Wow. In doing more online research regarding the landing gear, I have become even more mortified about this kit's design. Not only are the gear doors not the right length, it turns out they are not the correct shape, either. On top of that, the torque bars are wrong as well -- the kit places them on the front of each strut, but pictures of the actual plane online show them on the back. 😑😑😑 Ignorance would have been bliss in this case. EDIT: Just discovered that the locator marks for the door brackets are not in the correct locations and do not match what is shown in the diagrams. Since the gear design is obviously a complete cluster-you-know-what, I'm just going to slap the main doors on and call them done.
Me too! A very credible result and a testament to what can be accomplished with a plastic kit. Congratulations!
I'm hating this model at the moment. I'm not hating the subject -- the subject is fine, and the artwork is lovely. No, what I don't like at the moment is the design of the kit and its very apparent shortcomings. As you may recall, I have been slowly working on the landing gear, which have some very tricky and delicate parts. I got those bits done -- not great results, but at least they're done. Then came the gear doors. First we have the brackets that mount the doors to the struts. There are three of them, and they're all labeled as part 62. Not 62a, 62b, and 62c -- just 62. And there is no way to easily tell from the diagrams which order they're supposed to go in from top to bottom. I made an educated guess, and I don't think I guessed correctly. Next we have the landing gear diagrams. This frontal view shows the main gear door reaching up to about 2 mm shy of the wing. Yeah, about that . . . Yep, that's closer to being a 10 mm gap. Some more surgery is in order. 😑 What's really annoying about this is that this is the third Marek Paczynski design I have attempted, and every one of them has had design issues (one proved unbuildable). Worryingly, I have a bunch more Paczynski designs in the stash. 😒 But, I will press on with this one, since it is so close to being done. Stay tuned!
Welcome aboard!
If you can get your hands on a copy of Ship Modeling Simplified by Frank Mastini, he shows a simplified planking technique using the very similar Bluenose kit from Artesania Latina. A historically correct technique is not absolutely required if you intend to paint your model. A couple of bits of general advice: Avoid using the nails, unless you intend to remove them prior to sanding. There are better techniques for the job. The Amati design uses shamefully few bulkheads. Adding some pine or basswood filler blocks between them, then sanding them down to match the hull contours, will make planking much easier. Cheers!
- 25 replies
I am making agonizingly slow progress on this model, literally a couple of parts here and there every couple of days -- really having to push through on this one. In the meantime, I pulled the trigger on purchasing two additional Halinski kits to add to my stash, a Kawanishi N1K2-J Shiden-Kai (George) and a Messerschmitt Bf-109E-7/Trop. Both kits have been sold out at Halinski's web site for ages, and I have been scouring the internet off and on for a couple of years now in search of the N1K2-J. I knew of one web site that had that kit, but their shipping charges are astronomical, so I held out while looking for a cheaper source -- never did find one. When I recently saw that the expensive shop still has a copy, I decided to order it in spite of the stiff shipping charge. I added the 109E-7 to defray some of the cost and added laser-cut frames and a canopy to complete the deal (the site didn't have those items for the Kawanishi, but Halinski still has them). Let the waiting begin . . .
Congrats! I always love a good working boat.
- 18 replies
- Pot Pie Skiff
- Wye River Models
Welcome aboard!
Beautiful -- but your finished model should really be displayed in the gallery.
Your work has paid off handsomely! Congratulations!
- 602 replies
- Flying Fish
- Model Shipways
Looking good! I look forward to seeing her in her case.
- 21 replies
- Swift
- Artesania Latina
