KeithAug
Posts posted by KeithAug
  1. On 2/16/2025 at 1:45 PM, Veszett Roka said:
    If my vote counts, i'd go for full unpainted wooden hull.
    All votes will be counted Veszett.
    On 2/16/2025 at 4:04 PM, yvesvidal said:
    I think it needs an extra coat of clear
    I think you may be on to something there Yves.
    Not wanting to jump to a snap decision on paint finish I diverted to another controversial area. I refer to the stabilisers. Clearly they were not a feature of the 1901 build and were presumably included in the 2007 rebuild to make her more comfortable for the more delicate sailors of the 21st Century.
    I personally think Cangarda looks quite odd with the stabilisers fitted but unfortunately I can't bring myself to omit them (departing markedly from her rebuilt form).
    Courtesy of Rick I have some rather good shots of the stabilisers and these plus a bit of educated scaling allowed me to do a reasonably good job of getting their size and shape correct. As with the rudder, I am making them from a brass core clad with mahogany. The next shot shows the dimensions and the already cut brass plates (1/16" thick). The 2 plates are held together with double sided tape at this stage.
    The plates were then cut to shape and a 1/8" slot was milled out for the shank.
    The 2 plates were then separated and the shanks were cut from 1/8" brass rod.
    The shank needed to be soldered central to the plate, so for soldering stage the plate was supported on 2 off 1/32 twist bits (as per the next photo).
    The solder was then cleaned up.
    Mahogany planks were then glued to the brass - note the slot in the mahogany to take the shank.
    Once the mahogany was secure I used my patent bulldog clip method to control sanding of the aft end taper.
    The front end needed a slightly different approach because of the trapezoidal shape. In this instance I temporarily attached a sacrificial strip with double sided tape.
    The two stabilisers were thus completed.
    I now plan to move on to sorting out the hull paint scheme.
  2. 16 hours ago, Greg Davis said:
    but the bends need to be done without so much damage to the wire.
    Greg
    If the copper is hard soften it by heating (to red) and then quenching - this should make it very easy to bend, then it should be possible just to bend it by hand around a piece of metal rod of appropriate diameter.
  3. On 2/14/2025 at 6:32 AM, JacquesCousteau said:
    Unfortunately, it looks a bit odd to only have it in the middle of the hold, and it's pretty visible how it just ends when it reaches the bulkhead, spoiling the illusion of a cargo load.
    What sort of cargo would she typically carry? It would be nice to try and show it.
  4. 3 hours ago, Dr PR said:
    Guinness World Records for applying the most coats of finish
    54 minutes ago, Keith Black said:
    I think he owns stock in the company.
    32 minutes ago, Jim Lad said:
    Someone confiscate his tin of poly!
    25 minutes ago, Keith Black said:
    Mrs Keith probably wouldn't appreciate us doing that
    Shock horror - the tin is nearly empty. I spent happy hour on the web a few days ago looking for a replacement. The question is 75ml, 1000ml  or 2500ml. What do you recommend noting the trend to phase out oil based paints?
    Thank you Vossiewulf.
  5. On 1/20/2025 at 4:52 PM, Keith Black said:
    I was in recovery when yesterday I slipped on the icy back steps taking out the trash.
    Oh dear, you do need to take care. We young things bounce quite well but at your age it pays to be super safe. 🙂
    I have enjoyed catching up, you have been such a busy boy. All looking rather magnificent.
  6. Thank you Pat, Rick, John, Keith, Druxey, Veszett and Ian - and of course the rest of you have liked my work.
    On 2/10/2025 at 3:17 PM, Ian_Grant said:
    Modern water-based finishes definitely take more coats to "build" than the old stinky stuff.
    Yes Ian - I still use the old stinky stuff but still managed 14 coats - however see below!😬
    On 2/10/2025 at 1:33 PM, Rick310 said:
    what was the thickness of the brass you used for the trail boards?
    Rick - very thin to ease cutting - about 0.010"
    I set about making the anodes of which Canada has 14.
    I wanted to give them a bit of shape so I decided to try pressing them. I started by making a press tool from mild steel. This was partially milled and finished by hand filing.
    I used the machine vice as a press.
    With a bit of cleaning up the first one turned out acceptable.
    The pressed metal was quite soft - it is actually an old decoration that used to be a Christmas decoration. I think it might actually be a zinc alloy which seems quite appropriate.
    Here are all 14.
    All were drilled with 2 holes to take the mounting bolts. The slotted piece of wood is a crude locating jig to make drilling quicker.
    The keel was drilled through to take the anodes (symmetrical on either side)
    Then glued and screwed in place.
    The anodes are spaced equidistant along the keel - so again I made a simple jig  to assist drilling of the holes.
    I then used my previously made jig to drill the stabiliser holes. I always put off drilling holes in the hull - I think it is fear. You can see the jig has been modified to give better angular control of the drill. The Jig was taped securely to the hull and the holes were drilled with my heavy duty hand drill.
    All was well.
    Fortunately no damage to the paintwork ---------- but then ! succumbed and 2 more coats of Poly went on. Compulsive or what!!!!!!
    Ant then another go with the super fine wire wool.
    Somehow the final 2 coats seemed to help. The sheen was quite subdued and the finish was reasonably uniform which pleased me.
    The next job is making the stabilisers and thereafter masking up for the spray paint job.
    That's all for now so back to catching up with all your builds.
