Posts posted by KeithAug
Excellent work Hakan. Pity about the rework but we all suffer from it.
- Keith Black, Wintergreen, FriedClams and 1 other
4
Still catching up the post with work completed pre Christmas.
I finished the various bits of decoration.
I put on a second coat of metal paint and left it for a couple of days before overpainting with Vallejo gold paint. The under-paint turned out to be still a bit soft when I applied the gold which fortuitously produced a textured finish which I felt was better than a smooth finish.
The decoration was quite flimsy and this allowed it to be easily contoured to the hull. I held the decoration against the hull with an elastic band and a plank and then dripped CA glue into space around the decoration to permanently attach it.
A Happy New Year to you all.
- druxey, Keith Black, vossiewulf and 2 others
4
1
More story gems Phil, oh and solid work on the transom.
- Ras Ambrioso, MAGIC's Craig and Canute
3
23 hours ago, Keith Black said:
I highly doubt that.
Thank you the twins!
On 12/27/2024 at 2:11 AM, druxey said:me smile and brought back childhood memories! Merry Christmas and a happy, healthy New Year
Druxey - thank you and complements of the season to you and yours.
On 12/27/2024 at 2:21 AM, Glen McGuire said:Love the doll house.
Thank you Glen - I hope you had a wonderful Christmas.
1 hour ago, FlyingFish said:Bet her face was a picture!
Hopefully Andy. Because she is with her alternate grandparents in Lyme Regis she won't be getting it until 1st January when we go to "sit on" the Grandchildren before they return to school / nursery.
Anyway back to the main event and a start on reporting the few jobs that I managed in parallel with the dolls house build.
I tried both versions of your suggestions for cutting out the gingerbread. The reverse blade method worked but I found it a bit slow so I glued the 2 sheets of brass together with double sided tape and attached them to a third sheet of 1/16" plywood. This worked well. The cutting was somewhat quicker than the reverse blade method but still slow enough to provide an acceptable degree of control. "Somewhat quicker" is a relative term as it took me ages to work my way around all those nooks and crannies.
The length of the decoration was circa 7" and my jewellers saw only has a 3" throat so I has to make the decoration in 3 pieces. The next photo is part way through the first piece, and features the first broken blade.
And here is the first piece completed.
And then the second piece - sawing completed but still mounted on the backing plywood.
Then separated, using white spirit to dissolve the double sided tape.
I then applied a first coat of metal paint to start building the thickness.
I also started building up the prow decoration.
The scroll was turned and glued in place.
Next i turned the elongated "bead" before shaping it and attaching it to a piece of 1/32" ply.
The next photo shows it temporarily in position with a couple of extra bits of carving also in place. The 4 beads in front of the scroll are .04" ball bearings.
I have still much to do in this area to reproduce the finished article and of course much of it will be painted gold.
I'll catch up a bit more before the New Year.
- Keith Black, Paul Le Wol, vossiewulf and 21 others
15
9
On 12/5/2024 at 8:32 AM, wefalck said:
buying the m on-line can be a hit an miss, the jaws may not perfectly round
Nor are the jaws perfectly aligned, which makes them pretty useless. I have bought on line and from reputable modelling suppliers but both sources have by en large failed. I think jewellers may be a better source.
- Ryland Craze, Canute, mtaylor and 1 other
4
On 12/23/2024 at 3:41 AM, Ian_Grant said:
Turns out "MG" is a Chinese auto manufacturer, which I also never heard of. Did they buy the "MG" brand?
It happened a long time ago. The story goes - a British car manufacturers delegation went to China to do a deal but after their Chinese hosts had plied them with booze they woke up to find they had signed over the rights to the MG brand without getting anything substantial in return. MG's are quite common over here as a well specified but rather uninteresting cheap car option. They are cheap enough to sell well. Chinese cars continue to wreck the western car manufacturers!
- Canute, Keith Black and Ian_Grant
3
On 12/13/2024 at 11:56 PM, Jim Lad said:
Progress will resume once the 'Duchess' has been handed over to the museum staff.
Yes John , it will be good to see meteor taking a leap forward.
- Keith Black, Louie da fly and mtaylor
3
On 12/19/2024 at 11:23 PM, Keith Black said:
What I have done so far on the beam engine sits atop a penny assembled and painted.
Lovely Keith, particularly when weathered.
- Keith Black, Canute and mtaylor
2
1
On 12/21/2024 at 6:32 AM, Mark Pearse said:
I painted the boot top first, in full gloss oil based enamel (Humbrol gloss white). Humbrol seem to have changed the recipe, but it went ok - but 4 coats were needed to get a really opaque layer.
Interesting Mark. I just renewed my Humbrol white so It will be interesting to see if I encounter the same problem. Hull looking very neat.
- Mark Pearse, mtaylor and Jack12477
3
On 12/6/2024 at 2:10 AM, John Ruy said:
My Wife fell and fractured her hip.
Ouch! I hope all is going well and that you enjoyed Christmas. The boat yard can always wait until spring.
- Keith Black, mtaylor, FriedClams and 2 others
5
She looks beautiful Hakan. Best wishes for the new year - nearly 3 years now. Hopefully many more to come.
- Keith Black and FriedClams
2
Yes - what Eric said. I hope your Christmas was wonderful.
- Cathead, Keith Black, mbp521 and 2 others
5
15 hours ago, BANYAN said:
I am sure your granddaughters will enjoy playing with this.
Thank you Pat, unfortunately only got one, the second turned out to be a boy. Hope you had a great Christmas.
On 12/24/2024 at 7:56 PM, Jim Lad said:you actually completed the doll's house in time for your granddaughter
Yes John but it was a bit touch and go. Not as much fun as boatbuilding.
On 12/24/2024 at 7:32 PM, Dr PR said:No pictures of Grandma and Grandpa on the wall?
Phil, I was a bit worried we might get hung in the toilet.😬
On 12/24/2024 at 6:41 PM, Keith Black said:I'm sure it will be the highlight of Eve's Christmas.
Keith - Fingers crossed! She might just reject it in favour of some tech!
9 minutes ago, Charter33 said:
Just heard that my nearly 3 year old grandson is going to have a sister next year.
Fabulous news Graham. The world best Christmas present. Congratulations.
2 hours ago, Keith Black said:Keith, Merry Christmas and Happy New Year to you and your family.
And to your family, Ole Bob and the Wonky Donkey too Keith.
- Keith Black and Charter33
2
"God bless you merry gentlemen" and ladies.
I am sorry I haven't been around for a few weeks. Dolls house building and Christmas shopping have decimated my time in the shipyard. The good news is that the dolls house (and shop) is finished sufficient to be delivered to Bean (Eve) by Santa. Bean and Ben are being entertained by their alternate grandparents this year but Santa is delivering the dolls house to her home address in time for our New Year visit. I hope Bean won't be too worried about Santa's delivery mistake.
My son has been at pains to remind me the dolls house is to be "played with". His way of telling me that finesse isn't required. I hope that I have met his criteria. I leave you all to judge.
Thank you all for following along with my build over the last twelve months, as I look back I see that progress has been somewhat slow. Fortunately I have made a bit of progress since my last post so I will post an update later this week. With a bit more time on my hands I hope to catch up with all your build logs before the turn of the year.
In the mean time I wish you all a Merry Christmas.
- Wintergreen, tkay11, Keith Black and 16 others
13
6
On 11/18/2024 at 7:29 PM, Lecrenb said:
St. Roch had steel reinforcing straps and forgings around her stern members to strengthen and support the rudder post
Great work around the rudder post - very nice detail. Ditto the bow strengthening plates.
- mtaylor and FriedClams
2
On 11/23/2024 at 11:58 PM, Louie da fly said:
Seems to be working ok, but also very time-consuming and rather hard on the fingers.
It is impressively regular, I marvel that you managed to do it with a knife. The finished awning is wonderful.
- Canute, mtaylor and Louie da fly
2
1
Beautiful work Gary. I particularly like the detail of the paint damage around the latch. Wonderful.
- Keith Black, Jack12477, FriedClams and 1 other
3
1
St Roch by Lecrenb - 1:48 scale - RCMP Schooner rigged as schooner c. 1930/35
More than one way to skin a cat. I usually follow the thin lamination method and your method had never crossed my mind but I will log it for possible future use. Thank you.
