KeithAug
Posts posted by KeithAug
  1. 1 hour ago, Dr PR said:
    After checking to be sure the laser line was at the right height both forward and aft, I used a pencil to draw short dash marks about every half inch (12 mm) along the laser line.
    Great progress Phil and the stem looks wonderful. I too have abandoned the pencil attached to a sick method, the laser level makes it so much easier. Unlike you I have ditched the pencil altogether. I now lay the masking tape directly to the laser line. I find it works very well.
  2. On 2/1/2025 at 9:54 PM, vaddoc said:
    I ve had difficulties with lofting, difficulties printing the patterns, difficulties gluing them. My laminates that usually come dead straight are bent. My computer died and now, my disk sander started playing up and is in for repair under warranty.
    Yeh! I feel for you - and the whole world seems to be going to hell in a hand cart. Maybe we should just hibernate until 2026.
  3. Thank you for the feedback Eberhard, Andy, Tom, Rick and Gary.
    I seem to have a lot of distractions at the moment and I apologise sincerely for neglecting all your wonderful builds. This week is catch up week so be prepared.
    In so far as Cangarda is concerned it has been slow progress. In real life she has been shipped off to Turkey to be a part of some rich kids museum and occasional private transport / play thing. Good that she has found a new home but what a pity she had to travel so far from home to find it.
    The combination of other commitments, the lack of heating in the worksop together with post Christmas lethargy have all transpired to make progress rather limited. My biggest mistake has been to attempt painting the hull in deep mid winter. Each coat has been taking an age to dry.  I have tried to distract myself by doing some little jobs so what follows is a combination of those plus the never ending paintwork.
    I decided to drill the holes to take the stabilisers. I started by making out the position with the aid of the laser level.
    I decided that needed a simple jig to set the angles for the drill so I created the following. It takes its location from a slot that fits over the keel.
    DSC03118.thumb.JPG.b6ed79e66d37145cf0e3a51394ce1b33.JPGDSC03120.thumb.JPG.302fe4da563e8e9b4794c7a3149241bd.JPG
    Then more coats of wipe on poly.
    DSC03124.thumb.JPG.c07ea7e5d90cd032971437d519dc3445.JPGDSC03125.thumb.JPG.abce7312ff3b0255578c9874229209f7.JPG
    This was coat 8.
    Then came coats 9 and 10. With the workshop at 5 deg C the poly was staying tacky for 3 to 4 days.
    Coats 11 and 12 then went on.
    By coat 12 I was starting to write myself messages on the white board.
    But then I'd find a little blemish and on would go another coat.
    By coat 14 I decided that I had developed a bad case of Compulsive Painting Disorder.
    But I then drew a line and resolved to apply no more coats. I left the hull for 5 days and then knocked back the surface with some very fine wire wool.
    Best regards to you all. I will be catching up with your progress over the next week.
  4.
    Good to see we are approaching the wood cutting stage.
    On 12/27/2024 at 10:31 PM, vaddoc said:
    I intend to use 1.5 mm plywood to cut the planks. I am not sure how this will work, this boat's hull was built with steel sheets so it seems reasonable to use ply, provided it can bend both vertically and horizontally to follow the curve of the hull.
    This seems to be quite challenging but I'm sure you will pull it off.
