Everything posted by dafi
Thank you Gil :-) And some tinkering was done too ... First replaced the parcel strings aka side tackles by a better suited rope and reworked the pullies to get them into the right dimensions now. Preassembled outside the hull and a small thread around for not getting tangled up and in we go. For the back hooks I use fine electro pliers, they give more control than tweezers ... ... but for the front hook no other way than the tweezers for space reasons. In the end everything ended on the right place aka hook ... ... and time to pull the strings :-) And now usually come the nice coils on the deck, but like the drawing looks already a bit naughty, I wanted to look for a spiritual salvation for those sailors not to get into ideas ... Often seen too that the rope leads in a straight line from the pulley down to the coil. This made me think ... First: How can a rope be pulled straight down to the coil? The coil just lies on the deck and it is not fixed. The only way would be the rope to fall loosely from the pulley to the deck and is lead there to the coil. Second and more important: Why are the tackles not stopped/belayed? It is possible to show a unsecured tackle in dry dock like the V. in P., but on a real ship, the first wave loosens the tackle and soon one has a lot of stray guns on the deck dancing samba ... First consequences for my build, either one holds the tackle or it should be belayed :-) For the next guns to be worked on, battle stations should be already prepared, but crew occupied on the guns of the opposite side. So the tackles got secured by a half hitch (or a overhand knot with draw-loop) behind the rear blocks. And something surprising but logical: As I used the original lengths of rope, the back tackles do not need a coil or something alike, as there is almost no rope left :-) I letted the free end on the deck, even though it could have been arranged nicely otherwise. XXXDAn
How do do. you know me that well ? Quite close - all guns finally fixed on the lower deck :-) Dan
This week was week to remember, because of ... *please fill in your own guesses* XXXDAn
Nice and worthy additions :-) The groove on the masthead was meant for the Heller shrouds. XXXDAn
- 196 replies
- plastic
- soleil royal
Thank you Popeye, it turned out, that the instructions for my parts became some kind of "best-of" of the tips from this building report here :-) Here the collection: http://www.dafinismus.de/bilder/Etch_Victory_en_1_v10.pdf http://www.dafinismus.de/bilder/Etch_Victory_en_2_v10.pdf http://www.dafinismus.de/bilder/Etch_Victory_en_3_v10.pdf http://www.dafinismus.de/bilder/Etch_Victory_en_4_v10b.pdf http://www.dafinismus.de/bilder/Etch_Victory_en_5_v10.pdf http://www.dafinismus.de/bilder/Etch_Victory_en_6_v10.pdf http://www.dafinismus.de/bilder/Etch_Victory_en_7_v10.pdf http://www.dafinismus.de/bilder/Etch_Victory_en_8_v10.pdf Cheers, Daniel
Hy Popeye and Lawrence, thank you! @canoe21 I just use the template to sign the position with a pen and then remove it. Otherwise the danger of glue getting stuck under the template is too big. http://www.dafinismus.de/bilder/Etch_Victory_en_5_v10.pdf Page 13 Cheers, Daniel
- 118 replies
- jolly roger
- lindberg
I made them both for the same length, respecting some a tad shorter if fixed on the hanging knee :-) The given dimension is three times the length of the barrel, and this really is just about the right length as I could see on the model. Both have the same diameter. The positioning of the ring on the side is very clever, as it keeps the rope clear of the hind wheels. But even with both ropes I managed to find an arrangement, where both ropes can be kept clear of each other and the wheels, as looping around the back of the truck or fouling the wheels would have had very unwanted effects ... XXXDAn
Thank you Sirs! And next Dr Tentakels wild cousins went too into the trap :-) But then dafi got trapped himself ... ... to much flue - too much nice substances - and forgot on the left hand gun to lead the breeching rope through the big guidance rings on the side of the carriage ... ... where both red squares are , gun well glued, breeching ropes well fixed on the hull ... ... okokokokok, hard way, means taking the guidance ring out, opening it, putting around the breeching rope, refixing in the eyebolt and reclosing the ring ... ... everything in there, deep-deep-down inside the bowels of the Vic ... ... tight, dark, but luckily not steamy ... ... and somehow managed to fix and even the picture looks ok :-) XXXDAn
In the DIY-stores in the electrical or tools department they have the same ones as Andy showed for cheaper and possibly better quality. Here from wikipedia: For electronics work, special diagonal cutters that are ground flush to the apex of the cutting edge on one side of the jaws are often used. These flush-cutting pliers allow wires to be trimmed flush or nearly flush to a solder joint, avoiding the sharp tip left by symmetrical diagonal cutters. It is common for this type of diagonal cutter to be referred to by another name, such as "flush cutter" to distinguish it from symmetrical cutters. http://en.wikipedia.org/wiki/Diagonal_pliers I usually go to the shop with a piece of paper and try them out - good ones should even cut paper! This means not suitable for harder wires bit wonderful for sprue and etch :-) PS: I use them too for cutting off the end bits of the ropes while rigging, better than any scissors :-) Daniel Here a picture from Wikipedia:
Warning! I will be monitoring those split lines front and aft of the funnel! Be careful! ;-) Love the parts, Daniel
Apparently Boudriot mentions for the side tackles to be taken off before firing. In the british gun instructions there is no mention of that as far as I know. If one looks at Master and commander, the guns do not run back too fast, due to their own weight. If I am not mistaken, the side tackles could have be loosened a bid before firing. Another thing I realised, is that todays Victory is displayed with left hand laid breeching ropes istead of the normal right hand ropes. Another of Goodwins small mysteries ?!? After long research I found in Nares the following http://archive.org/stream/seamanship00acadgoog#page/n34/mode/2up page 25 I chose this too for my build even though it was written down some 60 years later. But this would even give further stretching to the ropes when under strain. XXXDAn
