Posts posted by Landlocked123
Dave,
I made all the same upgrades to my Dremel 580. But I also got the no slip belt and geared pulley wheels from Bill. Get a set if he has any left. I've yet to have the saw bog down with these in place even sawing though 3/4" Cherry (though I am cognizant of the saw's limitations). One more thing I did was to add a strip of thin aluminum to fence from before the rear of the blade forward. It serves two purposes. Since the fence upgrade is made of stock slightly rounded on the corners, I've had problems with very thin stock trying to slip between the fence and the table. The aluminum strip is flush with the table. Also since it stops before the rear edge of the blade, it tends to minimize chances of kick back.
Best,
John
Hi Jim,
You're Orrery is beautiful. Do you know if anyone will be selling it as a kit? Thanks.
Best,
John
- popeye the sailor, Canute, mtaylor and 1 other
- 4
Hi Gaetan,
I've been following your build from the earliest posts. The combination of your build and photographs can only be described as model ship building porn!
Best,
John
- mtaylor and CaptainSteve
- 2
Hi Cindy,
I agree with those who say buy what you when you need it and buy the best quality you can afford. Buying cheap tools usually means you end up buying them twice.
Though not a tool, my strongest recommendation is that you start a MSW biuld log, you will overwhelmed with sound advice, great suggestions about technique, and an amazing number of friends.
Best,
John
Hi Elia,
I am going to try the Woodland Dry Transfer letters on my schooner. It is the Smuggler and I'm trying to figure out how to layout the letters. Do I figure the length of the name and Gloucester together and and center the letters below the monkey rail or do I center between Smuggler ~ Gloucester? I hope this makes sense. Thanks for your help.
Best,
John
Hi Sal,
As I told you on Saturday there was never a DOUBT in my mind that you would win. I've only said this a few other times, to guys like Dan Vadas, that you inspire me to be a better modeler. That this was only your 2nd build still blows my mind. That we are members of the same club and that I can freely access your thoughts and help is invaluable.
You have truly created something beautiful and with a great build log is fantantastic. You should be very proud.
Best,
Steve
One more piece of advise, absolutely start a build log on MSW. You will access more expert help and friendship than you thought possible.
Best,
John
- Canute, WackoWolf, Seventynet and 5 others
- 8
Hi Peter,
I came up with a technique which worked really well for me. I was squaring up the end of a 3/8" dowel. I had some 3/4" scrap pine which I cut into 3/4" cubes and drilled 3/8" holes through the center. I then slid the jig down the dowel exposing the length I want to square and tacked it in place with a tiny drop of PVA, Using the jig as a guide, I then made 4 small cuts with a saw around the circumference parallel to the surface of the cube being careful that all the cuts were equal in length and depth, creating the basis for the squared section, After that I simply clamped the cube in a vise and filed away. The upper surface of the cube provided a great reference for keeping everything square as I rotated it in the vise.
When done a few drops of isopropyl alcohol a the jig slid right off.
I didn't take pictures of the process but you can see the results below.
Best,
John
- src, Geoff Matson, mtaylor and 1 other
- 4
About a week or ten days I saw a thread about various techniques for measuring the diameter of rope used for rigging. I meant to respond at the time but was unable. When I went to respond, I couldn't find the thread. I wanted to point out that Chuck Passaro has a great rope measuring tool available on the Syren website (go to the rope section and there's a link to the chart)
I downloaded it and added a spreadsheet converting measurement into scale inches for most of the common scales (see below).
If anyone like to have it, PM me your email address (I promise to ensure that it stays confidential) and I'll send over the Word file.
Best,
John
Glenn,
The level of both your metal work and wood work is exemplary!!!!!!!! You have truly elevated yourself to level that only a handful of the craftsmen on MSW have risen to (you all know who they are!).
It's work such as yours which pushes all of us to strive harder. After all, "a man's reach should exceed his grasp".
Thank you.
Best,
John
Hi Mike,
I suppose it would be possible to use a fine sanding drum in a Dremel to square off the rounded edge on the outside. But I'm good with getting them as the look in the pictures. But I do take an extra step. I line up the place where I want to bend square to the jaws, I then bent with my fingers, but then, while holding the pliers tightly I put the tips down on the bench and use a very small hammer to tighten the bend. I don't know if this makes sense so I will try to post a picture in the next few days.
Best,
John
There is nothing left to say but AMAZING!!!!!!
Best,
John
- RichardG, CaptainSteve and mtaylor
- 3
Hi Per,
I believe the product you are showing is something very similar to Chair-loc. It's been around for a long time. Chair-loc not a glue at all. It is used to repair chairs where the a spindle has become loose in its socket. It actually works by causing the spindle to swell and lock into into the socket. It's not used by professional restorers because the joint can't be undone if for some reason you need to. Another reason is that if the joint becomes loose again, it won't work a second time as well as ruining a possible good glue joint.
Best,
John
Hi Mike,
It's not really a score as much as a scratch to mark the location and angle of the bends. I use a Starrett pocket scriber, but an X-acto knife would work as well as.
Best,
John
- thibaultron and Canute
- 2
Joel, Mark, et al,
Scroll down in this forum and you will see a thread called re-hardening brass. The basic answer is: one can't.
I'm having a bit of a hard time imagining when you would need to do it. Under almost all circumstances where I'm worried about strength, I'm sure to silver solder my bands, eye-bolts, or whatever. There's a small learning curve but I now find it easier than soft soldering.
Best,
John
Joel,
Here's the pic.s and links
http://www.micromark.com/parallel-jaw-plier-flat-nose-with-straight-jaws,11523.html
Queen Anne Style Royal Barge by Chuck - FINISHED - Syren Ship Model Company - 1:24
Jaxboat & Druxey,
I guess given the scales most of us work at, what the hell, it's only a short step to the molecular level!
Best,
John
