Posts posted by Seventynet
Thanks Chuck. Sorry to waste your time. I’ve located a bunch of parts that I cleverly squirled away in a place I’d never find. I think I’m good on the organization of parts.
Ian
- billocrates, Rustyj, Ryland Craze and 1 other
4
Greetings,
Could someone confirm whether the 2 top timbers for Ha are in the template shown below? I have no idea where they have disappeared but if someone could confirm that they are in fact what I have shown I can simply trace and cut new ones. It shouldn’t be too hard to interpolate the notches. You can see that I cut the top timbers out of card and they seem to fit but it is hard to know for sure. If these are not Ha top timbers can you show where they are?
Thanks in advance,
Ian
Hi Paul, I don’t know how I missed this build. What organized, precise work you are doing! I need to take lessons from you on how to do a great build log. Keep it up!
Ian
- Keith Black, Canute, FriedClams and 2 others
4
1
Very nice neat work. Well done!
Ian
- jpalmer1970 and mtaylor
2
Greetings,
Let the real work begin! I am ready to start the frames.
I realized that the keel I had made a year ago is slightly thicker than Chuck’s but I think I can get away with a little tapering at the stern when the time comes. The rest of the fittings were straightforward although I had my fair share of screwups. I decided to employ a higher build board jig so that the stern and stem posts were clasped at their tops - though I know that these extensions will get in my way later. I will interchange the lower jigs when the time comes.
Cheers,
Ian
- Ryland Craze, Paul Le Wol, dvm27 and 14 others
17
- chris watton, Freebird, yvesvidal and 2 others
5
Hi all,
Here is my slightly modified version of Chuck’s Speedwell based on Greg and David’s plan. Over a year ago I had planned on upscaling David’s drawings to the same scale as Chuck’s and proceeded to build the keel assembly. After I made some headway I got wrapped up building a CNC mill and learning how to program it. A year flew by as I watched Chuck’s genius in putting together his kit. I could not resist the temptation and decided that I would go the kit way instead, except for using the boxwood (Castello) keel I had already gotten a good start on. Although Chuck’s version of David’s drawings (scaled up) are very similar, they are not identical. However, the keel assembly is close enough (I hope 🫣). I used a router to make the rabbet. The false keel is ebony. I have used a Mylar copy glued onto my building board.
Cheers,
Ian
I just received my package and will be starting a build log next week or so.
Ian
- JeffT, Rustyj, Stuntflyer and 1 other
4
I puzzled over this for a long time as well but for the life of me I can’t remember what the solution was. I am away from home until next week and will get back to you when I have a look at my model and plans. Hopefully David will lend his guidance before that. You are doing a great job so far.
Best,
Ian
2
Stunning, beautiful work! Thanks for sharing your incredible skills.
Ian
Welcome back Eric. You are doing an outstanding job on the Cheerful. And your photography is second to none. Love it!
Ian
Beautiful, stunning model and base!
- giampieroricci, druxey and mtaylor
2
1
Paul, just a beautiful job. You should be very happy with the result. Can I ask what’s next?
Ian
- Paul Le Wol and Dave_E
1
1
Honestly Chuck with these endless innovations you are making it is hard for me to continue with my nascent build of the Speedwell. I think I may just have wait until your kits are available. Outstanding work!
Ian
- Ryland Craze, Tossedman, mtaylor and 1 other
4
Beautiful work Chuck. So innovative. I’ve started mine but not enough work to report yet.
Ian- Ryland Craze, mtaylor, FrankWouts and 3 others
6
Well I think I know you Todd! 😀 My current project which you made possible is coming to fruition, at least on the mill side. Thanks for the comment.
In
- Tossedman, billocrates and mtaylor
3
Very, very well done, Bob. Congratulations you should be very proud.
Ian
- bobandlucy and thibaultron
2
Thank you kindly tonphil.
Ian
- billocrates and mtaylor
2
Sloop Speedwell 1752 by baribeaujm (Jean-Marc) - Syren Ship Model Company - 1:32 Scale - POF Sloop
Jean-Marc,
Some really innovative solutions. Nicely done. I wonder with that mirror sandwich whether you could get a light in there too. I’m using a light table and it is helpful but as you recognized you can’t see the back side. Perhaps some kind of portable light wand would suffice.
Ian
