Posts posted by aydingocer
- Old Collingwood, druxey, mtaylor and 8 others
11
- Canute, lmagna, Old Collingwood and 9 others
12
On 1/22/2022 at 12:15 PM, wefalck said:
I quite admire the designers of such kits. Doing a one-off and tweaking things to fit is one thing, but here you have to get it completely right so that the customers do not complain about poor fit etc.
Indeed. Though as paying customers we reserve the right to be nagging every now and then, the overall work they do especially on high quality level kits are quite impressive.
- Canute, mtaylor, popeye2sea and 6 others
9
Figures 321-324: Installing the foldable wall seats, prepared earlier. You glue two pieces of wooden strips at the back in order to support them.
You can leave as many open or closed (folded up) as you like. I chose to leave one of them open, just to show. Otherwise I bet they had always been folded up while not in use.
- mtaylor, popeye the sailor, Egilman and 6 others
9
BUILD DAY 31 / 2 hrs / (TOTAL: 83 hrs)
Figure 315: Blue plates and pinstripes are in place.
Similar work as that of the corridor side carriage and no surprises hence I don't have many photos nor much to tell.
Pinstripe trims on an ice cream stick.
I have less than 10cm left of the 0.5mm stripes after the work. It was getting scary towards the end. Amati could have put one more line of cut on the sheet (which would not cost them anything). But anyways I survived.
Waiting for the Micro Sol decal setters from the mail before I apply the decals.
Figures 308-311: The toilet windows have to have some degree of opacity. After all it is a toilet, right? In order to achieve this, the instructions recommend to spray matt varnish on them. I tried it on a scrap piece but the result was awful. Instead I rubbed them a few times with fine grade sandpaper. Turned out not too bad.
- ccoyle, Egilman, popeye2sea and 9 others
12
BUILD DAY 30 / 3 hrs / (TOTAL: 81 hrs)
Continuing with the compartment side of the carriage. The work is pretty much the same as the other side. This has more windows.
Figure 301: Nickel parts. They are also curved out of box. Now that I know they won't be visible, I use some force and hammer to flatten them enough.
Figure 302: Here they are flat.
- Jack12477, ccoyle, Keith Black and 7 others
10
17 hours ago, yvesvidal said:
For the decals "Compagnie Internationale....", you may want to use Micro-Sol if you can procure that chemical:
It works beautifully to stick the decals next to the surface and to get rid of the micro air bubbles underneath.
Yves
I think I found it on Amazon,
Does it help to brush it on my already applied decals, or is only good for future decal work?
- Canute, lmagna, thibaultron and 4 others
7
Yves
Thanks for the tip! Will definitely check it!
- wefalck, popeye2sea, Jack12477 and 10 others
13
BUILD DAY 29 / 2 hrs / (TOTAL: 78 hrs)
Logo, route nameplate, wagon number plate.
Figure 296: These are the smallest parts in this kit. They are the hooks for hanging the route nameplate. After removing them from their brass sheet you'll need to trim and file them so that they stay on the wagon smoothly.
Figures 297-298: In the two pictures below.
Left: Just removed from its sheet.
Right: trimmed and filed, ready to use. -
27 minutes ago, yvesvidal said:
WOW!! It is coming along rather nicely. The blue color is spot on. Will you spray a coat of satin clear to lock everything?
Yves
Thanks! I don't know, maybe not. I applied the paint on a scrap piece and waited one day to dry. After that it felt good enough, no peeling etc when I rubbed it. It may just stay like this.
Orient Express Sleeping Car 1929 by aydingocer - FINISHED - Amati - Scale 1:32
in Non-ship/categorised builds
Figure 339: Gluing the inner and outer walls to each other, very very carefully. Glue is applied on the wooden strips which I glued around the windows and long edges on one side. They will provide the necessary gap to slide the window sheets through.
