Chuck
Administrators
Everything posted by Chuck
  1. Just a heads up as well. I am nearing completion of the first 12 chapter seven parts in cedar. It takes a long time. Nearly 25 laser cut boards in this chapter. It may not seem like a lot but keep in mind that the parts for this chapter are more complex. Most are laser cut on both sides which nobody else does. This nearly doubles the number of boards as far as time goes. Its like butting 50 boards per chapter. Many if not most of the parts are also boxwood. I probably should have made this two chapters in hindsight. Anyway.... I have a request. Because these take so long to laser cut....if you are not near needing these parts immediately, please refrain from buying it. I know many of you havent even started the project yet. I would ask that you let the folks who are at this stage of the project and really need the chapter seven parts to buy this first batch. I think you understand why. No sense in having them sit on a shelf for a year while we have people who actually ready to start chapter seven. Thank You in advance. When I get back from Washington DC I will start making the first cherry chapter parts. Chuck
  2. Thanks Mike....Tomorrow I have to remember to take pictures of both our Winnie models next to each other. It will be interesting to see both together now that we are so much farther along. Way back when we managed to take a picture at this stage....we have come a long way since then. It will be really fun to get the guys together after 18 months....I am looking forward to it. We have about a guys from our club coming by the shop for some lunch and they will be bringing their models that they have been working on during the lock-down!!! Good times!!!
  3. He will be cutting that split area away anyway as that beam need to be moved forward. My original slot was not in the correct position. So most of the work is done for him already. None of the deck clamps will be visible. They are all covered by the lodging knees etc. se the latest update in my prototype build log.
  4. There are two rails/fore bitts forward and aft of the foremast on the Fcastle. These are interesting fittings in that they extend from the gundeck through and up to the f'castle. So we will start chapter 8 with those. But first a little prep work. I knew when I drafted the plans for Winnie ....specifically the deck clamps...that at the extreme bow I would probably incorrectly space the notches for the deck beams. This turned out to be true. It was difficult for me to design the deck clamps as the rounded the bow so the beams of the f'castle would be properly spaced and positioned. I knew I would be adjusting them before I started making the fittings below the f'castle beams. Turns out that only forward six deck beam notches need to be altered. They need to be moved forward a bit in ever increasing distances as the get closer to the bow. This is very easy to do as you guys only have to widen your notches for those six forward deck beams. So place all the beams temporarily in their current notches and use the supplied template to see how far forward all of those six beams should be moved. The last or forward most beam has to be moved 5/32" forward and requires the most extreme shift to the notch in the deck clamp. Here is a photo of the template in position after all the forward deck beams were moved. You will be referring back to this template often as you work. With that completed lets build the bowsprit step and two rails. But remember that these are all one piece on the actual ship BUT split in half between decks on our model to simplify matters. Even though you will be building the actual rails now for the f'castle they wont be needed until a much later chapter. Its just easier to build them together so they are the same width when completed. This will help the illusion that they are all one piece later on. There is the bowsprit step made from 4 laser cut pieces.....which has a rail above it. There is a "Y" shaped element on the aft side of the foremast which also has a rail above it and was one continuous piece. Or at least they should look that way when done. So build these from the laser cut boxwood pieces. Note the square hole for the aft end of the bowsprit tenon. That was actually a mistake from my original design. The bowsprit angle was changed during construction as noted on the original draft/plans to a steeper angle. This hole was actually below deck and wouldnt be seen so I removed it and made another which you will see. Note how the rails are the same width as the parts below deck and thus its easier to build these together even though we wont be mounting the rails above the deck beams yet. But this is what it will look like and what we are shooting for if it was mounted. We are starting with the fourth deck beam from the stem. The rail is just temporarily in position to show you guys how it should look. But we are basically adding the fourth beam first..... Then positioning the bowsrit step. This has a slight angle as shown on the plans. Then I added the two manger barriers on either side of the bowsprit step. The manger barriers are basically a wooden partition on either side of the bowsprit step. They are laser cut for you. First glue the two flat boards together edgewise to form the barrier. shown on top below. Then take that barrier and position it on the model. Both ends need to be shaped to fit you bulwarks and beveled to fit against the bowsprit step. Each partition will be slightly longer so you can take your time and care to get the correct shapes. Once they fit....add the strops on each end.... 1/8" x 1/64" strips to simulate the slotted fixture these two boards would be slid into. These partitions were always being removed and repositioned to give access to the manger area. As you can see I painted mine red. This is what it looks like all done without the rails above the bowsprit. Note that I also added the hanging knees on each side of the fourth deck beam. It was just easier to add them know. When positioning the manger partitions....CAUTION.... Beware that the position along the bulwarks is important. You will need to keep it clear of where other hanging knees will fall and the scupper should you choose to show them. From this point I added the remaining deck beams....knees and lodging knees moving forward towards the stem. Just use the template and plan as a guide. Its no different then adding the knees for the qdeck. The only difference is that they are on the opposite side of the deck beams this time. Next up I will add the cat tail for the catheads. It will be much easier to add them at this point before I start adding any more fittings and deck beams!!! Any questions.??? Oh yes....I did make the riding bitts but they are just temp positioned. I still have to finish those and paint them. I should have removed them from the pictures before I took them.
  5. That is looking pretty darn good. Yes the deck clamp will be all but impossible to see.
  6. Nice looking rope. Well done! I am sure you will Have many customers.
  7. 5/32" singles..... Rope sizes are more difficult. But I figure .018 for the tackles and .050 to .054 for the breach line. Chuck
  8. As I am finalizing and cutting Chapter seven parts...here is a sneak peak of what will be chapter 8. I have just started working on these fittings under the fcastle deck beams. There are far fewer items so this chapter should go quicker. The most detailed item to make will be the Stove. The other stuff is quite straight forward.
  9. I use 15" long at Syren because that is the length of my laser cutter bed. Actually its 16" but I like to use 15" long sheets on the laser. Other than masts it is unlikely you would ever need a piece longer than that. That is if you plank with scale lengths which follows actual practice. Best to keep widths to around 4" to 5" because any sheets you mill that are wider have the tendency to cup. Narrower sheets are more resistant to this. But in the end its up to you. Chuck
  10. Download the entire sail tutorial here. Big thanks to "Tigersteve" for consolidating in a PDF for printing. This is a huge help. Sails for a Cutter Rigged Long Boat.pdf
  11. Tom and Bill came by my shop a few days ago. Tom dropped off the Longboat model with the sails all finished. What a masterful job he did on these sails. I think it adds so much to the overall presentation. Anyway....I took some photos from various angles so you guys might see them in more detail. Thanks again Tom. In addition....<Medway Longboat kits are now in stock. I believe there are only 4 left now. But I will make more soon. Chuck
  12. A couple of weeks probably. I am also headed down to Washington DC and the Smithsonian soon I will be be away for a few days. Im leaving on the 16th. I probably won't have it ready before I leave but I am gonna try. chapter 7 has a ton of parts and laser cut sheets as you can imagine. Its probably the biggest chapter so far. I started cutting parts yesterday for the first batch. Chuck
  13. Really looking nice Druxey. What a beautiful model. Will you be painting any parts or will you leave it all natural wood?
  14. Pat that looks fantastic. Well done with the bell. Metalwork like that is difficult for me and watching you put all the metal bits together on your model so well is inspiring me to give it a try at some point. Its a whole different animal for me but you make it look so easy. Chuck
  15. The larger are 1 29/64.... the shorter on the q deck are 1 11/64" Carriages too.
