Chuck
Administrators
Everything posted by Chuck
  1. Fcastle planking is completed. I also added the mast coat as you can see in the photo. This is also the same as the earlier ones we built. The open areas of the decking reveal plenty of the gun deck. Just remember, you can add more deck planks if you prefer. You can also plank one side completely and leave the other side just showing the deck beams and knees. Its up to you. Now its onto either the belfry rail or jump over and start working on the qdeck coamings. I havent decided yet. There is also a large knee at the bow to make. Chuck
  2. Its all done for you….i have created templates with all of the individual planks drawn out. All of the scarf joints drawn and butt joints. Cut the template apart into i ndividual planks to test them on your model. Tweak them if they need it. When they fit….either rubber cement them onto a wood sheet or trace them. You really cant get any simpler. Its all done for you.
  3. This is an important picture as I plank down the center. Note that the center 3 deck planks were cut using the template as a guide. These are glued in first. Then the two bitts we made are glued into position in front of and aft of the fore mast hole. It would be very difficult to cut and add those three center planks with the bitts in position already. Once they are glued into position the two remaining strakes of deck planks on each side can be completed. In the photo you can see that I have already cut and shaped the three lengths for the next strake. I will finish up the deck planking on the fcastle tomorrow. Any questions or comments. Remember that all of the planking is tapered and curved. These planks were cut from a 3/64" thick sheet of cedar. I glued the template on it and cut the next plank I needed with a sharp #11 blade. I sanded it smooth and close to the lines and tested it and retested and retested....you guys get the idea.
  4. Just wait a few weeks and they will open up again. If not maybe other services in other countries are shipping there. Maybe send it to another kind Winnie builder in the UK who can then turn around and ship it to you from there. When they buy the next chapter they can allow your parts to piggy back to them to save on shipping.
  5. Terrific news....that is too fine a model not to finish it. And you know where you can get spare parts if needed. Chuck
  6. Coamings are completed on the fcastle with gratings. There is one that is for the stack which will have some cover boards. Note that this coaming sits against the one aft of it. So the aft edge doesnt have the corners rounded off. Rather than repeat the coaming making process I will just say ...dont forget to use your 3/64" thick right angle jig when making them. Also use that to round off the corners leaving a sharp edge corner where the planking will done around it. This is the exact same thing we did with the gun deck coamings. With these completed I can start planking the center strip down the fcastle. I will take some pictures of that process because we need to also glue the bitts onto the model we made in the previous chapter. The ones fore and aft of the foremast. More progress shortly but does this make sense....do you guys need any clarification as I there really is nothing different with these coamings than all the others....a 5/64 x 1/32" strip was inserted inside the coaming so we can sit the gratings and cover boards into them. Everything is laser cut. The gratings are made the same way as well.
  7. Another inspirational update. That rigging is fantastic. Beautiful rope making.
  8. Actually.....as some folks progress through kits I think they end up just running through new projects with less care than their first. The worst thing any new modeler can do is fixate on making things quicker. Its not a race. I wish more beginner builders would make it a priority to get comfortable slowing down even further and learning to really up their game on craftsmanship and historical accuracy. I was just looking through a build log on a very expensive Vanguard Sphynx kit for example and the builder hasnt even bothered to sand away any laser char from the parts or carefully align those parts when gluing them on the model. Slow....steady....and deliberate is the the only way to achieve a quality result. So good on you for taking the time needed. This model in question has caused me much "wincing" on each update. This is a hobby that pays more dividends the slower and more care you put into it. You dont get any prize for finishing first.
  9. Im eager to see more progress on this one…..Hows chapter seven coming along.
  10. Yes excellent work with the planking indeed. Going slow and steady will always pay off as is evident with your progress. Creating a planking plan like that is always the way to go. Wonderful progress.
  11. Just remember that some of you guys skipping ahead are missing a few details and making some oversights which will eventually be written up in the chapter. I have seen quite a few on the logs of folks who have skipped ahead and missed stuff on previous chapters. I cant blame you guys about the age thing and wanting to run through the project quickly but just be aware.....you may be backtracking a bit, or at least leaving off a few parts etc. For example. On the cat tails. There should be a small triangular piece that will help sell the illusion of the catheads being created in one piece. Most of the guys who have planked already, missed that. Among a few other things. I know you guys are eager but I cant rush through the next chapter. It will be ready soon enough. I have seen others on previous chapters really paint themselves into a corner. We are almost at the end.....nothing worse than tripping on the way to the finish line. No disrespect meant...just a friendly suggestion. Another suggestion, maybe spend the time while waiting for chapter 9 by creating a wonderful stand and or case for your model.
  12. Christian…hows it going on the Winnie? You started off like gangbusters. Any progress?
  13. Just a quick note to all MSW members.... There have been quite a few new members to the Winnie group who just signed up over the last 3 weeks and are just getting started. I know many of you might think the group is too far ahead now to join. BUT If anyone is thinking of jumping in, this might be the perfect time. You will be in good company with several members just starting to make sawdust. You can link to the HMS Winchelsea Group Project here.....Click Here This group is very active and we encourage many more to join in on the fun. This is a wonderful introduction to scratch building techniques. You can scratch build this entire project or buy some portions of it as laser cut parts. You only buy those parts that you need and if you are comfortable building them from scratch or willing to try, this is the perfect project to learn those skills. This model is 1/4" scale and plank on bulkhead in design. The completed model will be 38" long in this scale. If you have any questions about this group before joining...please reply to this topic and ask away. Click here to get access to the NRG store....click here....Its just $15 to gain access to the plans and get started. It would be fantastic to have you as part of the group!!!
  14. Hows the Cheerful coming along? I am eager to see that hull all planked up!!! Stay well
  15. If you are having trouble with the thole pins, you might want to try using a wire of the same diameter. Perhaps even a brass rod. Perhaps 1mm or ever larger.
  16. Very nicely done. That is a solid foundation for final planking.
  17. I think what you have come up with will be just fine. I would go with it. That should work. It doesnt follow the contemporary model but since it will be below deck you wont see much of it anyway. The overall results will be consistent on your model the way you intend to change it. Chuck
  18. That looks great Don. One thing I cant help but notice is how shiny your black paint is. Is that a personal preference. I might suggest a matte black if its at all possible at this stage. Maybe try it on one side and have a look. So many people catching up to me. I have to get busy!! I will ponder how to make it easier to print out that template. Chuck
  19. Hows the q galleries coming? I am patiently waiting to see how they turned out.
