Slowhand
Posts posted by Slowhand
  1. Think it passed Dockyard QC. Need to buy in some brown rope for the ratlines from Cornwall Models as the beige hemp supplied would look very odd IMO. Also some parrels needed as no where near enough in the kit. Best get them in before Brex**** could be a problem for the non scratch builders. PS why are those funny blocks used to hold the anchors called cat heads.
  2. On 1/2/2019 at 1:33 PM, mispeltyoof said:
    A simple needle threader has changed my life after spending a couple of hours attempting to thread a deadeye with aged eyes and fingers.1f642.png:) The threader can be inserted through the tiniest hole ,thread passed through the wire and simply pulled back through. Perfect every time....brilliant
  3. It’s been a long time since my last post, afraid became a bit apathetic about the model as it bears so little resemblance to what the original San Martin must have looked like. On another ship forum website found images of painted glass image of the SM and a lithograph of a major Spanish Galleon of similar period. Concentrated on my traditional wood carving with gouges. Anyway update of progress, shaped all the spars using 18v drill as a mini lathe. Used chuck to hold wood  and a piece of sandpaper to taper the spars as powered up the drill.  Attached chain plates to new boards and put in place ready for staining before gluing.
  4. Update on the deck fittings I have done and the windows added. Decided not to use Romanov upgrades as windows had not been cut out. Camera highlightened some of the bittens need more sanding to fit into the racks properly. Waiting from timber  from Cornwall Models to plank the rear balcony.
  5. After a large glass of wine tried some tree nailing lightly drilling holes into planks and marking with a pencil an absolute disaster. Ripped existing planking on part of the quarter deck using flexicut detail knife and relaying planks, including a couple of others on port side. Phew, got away with it. Ship's cat now hides the only remaining evidence of trenailing attempts. A rather large cat about the height of a polar bear according to the scaling of this kit. Assembled ladders, but not glued in position. I mean they're identical to those on the Corel Half Moon which is 1/50 scale. This build is 1/90 scale so they can't both be correct. Getting a bit fed up with Occre so many parts are not right including the massive cannons for the main deck and all the metal parts. Bought some canons from my usual supplier, 30mm long wooden carriages.
  6. Just about ready to apply a finish to my mahogany planked hull. Current candidates teak oil, tung oil or wipe on matte poly urethane varnish. Wipe on poly not commonly available in U.K. Shops, although can get a tin on Amazon. Bit loathe to spend £14 to use as a test coat. Do you think a poly urethane varnish diluted with white spirits would give a good approximation for the real stuff. Should say the strakes have lightened quite a bit since the photo. As an ex chemist not too bothered about the odours although the dockyard failed a recent safety inspection by the Rear Admiral.
  7. Got the strakes on without too much white glue smearing the planking. Had to stain them as supplied in greyish walnut and hull planks were mahogany didn't look right. Beginning to realise why people scratch build. Having said that walnut is a pig to work with so hard. Flexible beech for the bulwark tops instead of supplied walnut, bends really easily. Discovered another SM build log on a Russian forum,
  8. Hi Newbee. That planking method looks familiar. I had a similar dilemma with the Occre San Martin. Didn't fancy using the  timber supplied with the kit for the second layer (.5 x 5mm). It looked far too fragile to survive without chipping the possibly 2 years or so doing the masts and rigging etc once the hull was turned over. I bought some Mahogany timber online (1 x 4 mm) and decided I might as well plank the way of Dirk De Bakker and Booker described below rather than the wrap up way used on many AL and Occre kits.
    http://modelshipworldforum.com/ship-model-framing-and-planking-articles.php
    It was far easier than expected. The planking above the wales needed virtually no tapering and for the planking below I divided the hull into zones and measured the width of the zone at the centre and two or three other points toward the bow and winged it towards stern as measurements showed very tapering was needed. Was pleased with the results, and used 4 drop planks per side, just about the best hull I have done, not up to the standards of the best on this website of course. My build log is below
    http://modelshipworld.com/index.php?/topic/12239-san-martin-by-slowhand-occre-scale-190/#comment-473423
    Good luck, thought it was a shame you abandoned your second attempt at the 50 gun ship it looked as if it was going well.
  9. Just about finished 2nd planking layer waiting for a bit more wood supply from the South West. Replaced the 0.5 x 5mm Sapelli supplied with kit with 1 x 4mm Mahogany. Reckon the thin layer would have taken a bashing in the couple of years I expect to need to do the rest of the build and used the guide provided on NRG by Dirk de Bakker and Greg Brooker, split the hull into bands to help tapering, drop planks at the bow to stop crowding only using new blades to cut the timber. Glad I didn't follow the instructions which came with the kit, where you sweep the wood up to the wales.
