MikeR
Posts posted by MikeR
Keith
Your work is amazing. When I cut .250 copper or brass I use a Dewalt variable speed scroll saw . I use either #1/0 or #2/0 blades at a mid range speed. I cut through a thin layer of cutting oil on the brass or copper which keeps the blade cool and lubricates it during the cutting . When I take my time and cut slow, I break very few blades.
MikeR
- FriedClams, Retired guy, KeithAug and 3 others
- 6
Rob
I still have to add on the fancy carved corner knees for the roof. I never tried carving before so that is what the holdup is. I did have a scalloped molding that went under the roof line, but I did not liked the way it looked so I removed it. I am still plan on trying a different design.
I have been working on the iron work for the lower yard, topsail yard and the top gallant yard. These were silver soldered , then placed in an acid bath to clean them. I used liver of sulfur to blacken them.
Mike R
Mike
I use a digital caliper. Measure the width of the strip, say .250 divide it in half and set the caliper to .125 and lock it in place. Then scribe the line, to be super accurate scribe from both sides. You could also use the caliper to just center punch the piece and drill a hole. I use this method to find the center of 1/16 brass strips.
Mike R
George
Thanks for the information. I will give it a try tomorrow.
Mike
It has been nearly a year since I stopped working on the Flying Fish, well 10 1/2 months. Today I installed the Fore topmast shrouds and back stays. The inner and out stay is terminated under the fore deck. To any Flying Fish builders, how did you accomplish this? Any help would be appreciated.
Mike R
- mtaylor, AnobiumPunctatum, thibaultron and 5 others
- 6
- 2
Hi Rick
I purchased a 4 oz.bottle of Liver of Sulphur Extended Life Gel from "The Contenti Company". I mix 1/4 teaspoon of liver of sulfur with 3 oz of hot water. After I clean the copper with acetone I dip the piece in the solution or use a paint brush. It does not rub off very easily. It works great on copper and not well on brass.
Mike R
- mtaylor, allanyed, thibaultron and 2 others
- 5
- thibaultron, albert, KARAVOKIRIS and 5 others
- 7
- 1
- Canute, GrandpaPhil, AnobiumPunctatum and 5 others
- 7
- 1
- GrandpaPhil, mtbediz, CiscoH and 8 others
- 11
Nick
What are you using to cut them out? If you are using a scroll saw you can stack two layers of wood, I use double sided tape to join the layers and rubber cement the pattern to them. Cut it out and you will have two identical pieces.
Mike R
- mtaylor and Keith Black
- 2
- GrandpaPhil, Thukydides, Canute and 10 others
- 11
- 2
- scrubbyj427, Thukydides, CiscoH and 8 others
- 9
- 2
- Siggi52, albert, GrandpaPhil and 9 others
- 12
Thukydides
The R.A. Library is the Royal Artillery Library. The information I used was from "The History of English Sea Ordnance" by Adrian B. Caruana and on page 185 it states that between 1782 and 1783 the design changed from trunnions to a carronade loop also called "joint" Which did away with the quoin and handspike for elevation the alternative was using a screw for elevation.
Druxey
That is the same book I used for information. The carronade that I made was a 24-pdr cast by Carron in 1779 Length 32 inches.
- Ondras71, CiscoH, Thukydides and 9 others
- 12
Here is my attempt to make a made up foremast, I glued up two 1" dogwood boards and turned the 1 1/2" mast. I then cut a 3/4" piece off the mast. To this I used rubber cement to glue a pattern of the mast pieces i wanted to cut out. On my scroll saw I used a 2/0 blade (.0087 X .0236) to cut the pieces of the made mast. With this size blade I can cut sharp 90 deg. angles. I then cut these pieces to different lengths and glued them up and attached it to the mast. The top copper band hides the seam. I also added the mast bands, front fish, and rope woolding.
Mike R
Carronades by Adrian B. Caruana "The History of English Sea Ordnance"
The main reason for carronades mounted on the outboard principle is doubtless that throughout the American War and for most of the Revolutionary War the normal emplacement for carronades was on the forecastle, gangways or quarterdeck, where they were mounted en barbette in ports with no lids.
Anonymous drawings probably dating from the 1790's of a joint carronade mounted on the outboard principle, with all its fittings (R.A. Library)
I will be using cherry, dogwood, ebony, and ipe. For the carronade I will turn it from 1" brass stock on my wood lathe, but first I turned one out of wood for practice.
- Ondras71, scrubbyj427, CiscoH and 10 others
- 13
Flying Fish by MikeR - 1:64 (3/16" to 1 Foot) - from Model Shipways plans
Rick, I run into that problem too. I have dropped many items and found a few while looking for them on my hands and knees. I probably spent more time looking than the time spent making the item. I made and installed a new top mast crosstree, I replaced the cut away rigging, installed the chains for the Bowsprit and ran the rest of the running rigging. I am working on the braces and have completed the braces for the skysail yards, the royal yards, and the topgallant yards.
Mike R
