Everything posted by dgbot
Before my cancer I was thinking about building one of his smaller craft. But that is on hold until I can get back to Chicago. David B
- 296 replies
- herreshoff
- buzzards bay
May god be with you Nenad. Flooding can be very bad news. Please be careful. David B
- 4,152 replies
- cutty sark
- tehnodidakta
Keep it up. Your strip look better than they did before. David B
- 1,756 replies
- constitution
- constructo
I have some I'd his books back in Chicago. I like his designs. David B
- 296 replies
- herreshoff
- buzzards bay
Pete I just found your build and find interesting. I rarely see models like this and am looking forward to see you build it. I will be taking notes. David B
- 296 replies
- herreshoff
- buzzards bay
My advice would be to decrease the dimension a little so it looks closer to scale then lash it in. David B
- 803 replies
- colonial cutter
- modellers shipyard
I think you are doing a splendid job. Heller kits can be rough at times but they make into fine models. David B
- 110 replies
- heller
- le superbe
What glue to use?
dgbot replied to rshousha's topic in Painting, finishing and weathering products and techniques
Depending on the structure I use both white and yellow. For the structure such as bulkheads, lifts, frames,planking, etc I use yellow. For everything else I use white. It is easier to diltue if needed and can be removed with isopropal alcohol as yellow can. ] David B- 18 replies
- CA glue
- cyanoacrylate
- (and 5 more)
You have done wonders with your deck keep it up. David B
- 4,152 replies
- cutty sark
- tehnodidakta
As always Dan I learn something knew every time you post. David B
- 241 replies
- queen annes revenge
- pirate
You are making a work of art. She is looking great. I wish I had my camera and could be there up close. David B
- 1,449 replies
Nice windlass are you going to give it a color or leave it natural? David B
- 420 replies
You are getting there Ollie Now you just have to do the rats. Just take your time and it will be over before you know it. David B
- 803 replies
- colonial cutter
Patience is the key here plus using a suitable wood you are doing just fine. David B
- 1,756 replies
- constitution
- constructo
You can make your own grating with the right blade. I did not get a good look at your corners. Did you mitt or cross lap then? Your corners would have been cross or ship lapped as this would provide the greatest amount a strength. David B
- 264 replies
- rattlesnake
- model shipways
Harriet McGregor by Boccherini
dgbot replied to Boccherini's topic in - Build logs for subjects built 1851 - 1900
Nice work. Soldering two different metals together is not easy. David B -
Nice cannon and cleat looks just fine. David B
- 803 replies
- colonial cutter
Your support beams are not lined up. This is an easy fix. As for the As try making a male female mold? After wetting the wood put it in and apply pressure a little at a time. Keep it up. David B
- 1,756 replies
- constitution
- constructo
I just finished your log. I have learned a lot and like the way your model is going. David B
- 2,214 replies
Bring your model to Manitowoc. It is magnificent. David B
- 25 replies
- anchor hoy
- miniature
A job well done Cap't. Now go to the nearest port grab a wholesome wench and a keg of good Jamaican rum and have a rest. David B
- 625 replies
- bounty launch
- model shipways
