dgbot
Gone, but not forgotten
Everything posted by dgbot
  1. There is also the Lumberyard for Model Shipwrights They are also in Ohio. David B
  2. Over theyears I have seen many a beginning modeler buy a Victoory or a Royal Louis and then quit because the model was either too complex or the instructions a piece of trash. Start simple and then build up your skill and knowledge. David B
  3. If you click on milled strip wood they have what you are looking for. And trust me I have dealt with and he is in Ohio. Go to the sponsors section and check them out. David B.
  4. Alzarius, The Hobby Mill is in Cincinatti OH. They have Mahogany. Jeff Phillis is a site sponsor. They have a banner on the main forum page. Take another look. David B
  5. Beautiful work Dan. You are making excellant progress. David B
  6. Alzarius, The Hobbymill is run by Jeff Philips who is a site sponsor. They are out of Cincinatti OH. They have mahogany strips as well as several other types of wood. Their banner is on the forum page. I think you went to the wrong one. David B
  7. Dan you are a genius. All that work done in a van and no power tools. You are an inspiration to me. When I moved in with my sister I had to leave all my power tools at home. David B
  8. Ive used Sherline for years and like the way they work. Plus they are versatile. David B
  9. Where do you live? In tbe states you can calll the Hobby Mill. David B
  10. Lovely work Toni, it is a shame I wil not be seeing your work up close for a while David B
  11. I like the way you did it a work of art and an inspiration. I brought the kit with me and hope to build it. But no painting or airbrushing my sister would not like it. You are good. David B
  12. The secret to mixing acrylic is the consistency of skim milk David B
  13. For anyone who gets the Smithsonion Magazine they have an excellent article about Black Beard that is very heavily researched David B
  14. I have a Badger and I have been very happy with it. Just keep a bottle of cleaner by you and you wont have any trouble. David B
  15. Years ago several club members were asked to build an aircraft carrier. They used builders foam for the plug. Very strong and durable. After the fiberglassing was done just use a little acetone and melt the foam out. David B
  16. Kurt another thing you should do is rough up the surface of the pieces you will glue up. That way the glue will get into the fibers and make for a bettet bond. I would use a good yellow glue and do layer by layer alternating the grain each time. David B
  17. For weathering you can do what is called the dry brush method but practice first. Up at Manitowoc I have seen many a weathering job with this method. But the biggest secret to success is less is more. David B
  18. I have a small bench grinder for shaping my tool bits. For basic sharpening I will use my Delta belt/disc sander. For wood turning I use my Delta and then clean up with a stone and a buffer with my Foredom. David B
  19. Canned air will work but you have to be careful og the can freezing up on you. Several years ago I was repaing a hull for a client and the chugged out a mess and I had to redo the entire hull. That is when I bought a compressor. Keep the cans in a pan of luke warm water and this will help stop it. I know people who use innertubes. Or take a tank to a gas station and fill it. Just make sure you have a good regulator with a water trap. David B
  20. Nice way to put a complex part together. Break it down into several pieces and then fitting them together. Bravo! David B
  21. A good rotary tool. Dremel or Foredom. David B
  22. The easiest way to replicate them is to cast them. Resin or pewter using RTV molds. There are several tutorals for doing this. Make up the master. then cast it. Then use the master and the casting to make a 2 cannon mold then 4. You will then be able to produce all you need. David B
  23. A basis rule of safety when handling a table saw, mill, lathe etc. Do not wear gloves or a ring. No loose sleeved shirts. These tools can be dangerous. when you do not follow the rules and common sense. David B
