Trussben
Everything posted by Trussben
  1. The colors will get muted with time Rusty as you know, she looks great.
  2. Looks great Chuck, makes sense to only use an as such simple scarph joint instead of full chocks for a much easier frame construction, will make the angled cant frames much easier as you won’t need angled chocks either.
  3. Thanks Everybody for the comments and likes. I will give that a go and see what it lt looks like David.
  4. I finished blending in the Rudderhead framing to the stern and then started mocking up the upper counter and stern light layout - still needs tweaking.
  5. Framing around the rudderhead underway, you can see the 3 pieces roughly shaped and trial fitted here, the hole for the rudders shape will be finished after they are installed. Druxey - no CNC parts to be found here! All hand made.
  6. My other thought would be to laminate two or three thinner pieces and make a form to bend them around, at least that's what I will try if using these proves too fragile.
  7. It’s just another Tool David! Here is the very difficult to make by hand Taffrail capping piece, 1.5” thick by 8” deep, very very delicate pieces!
  8. Started design work on the Taffrail, playing around with the CNC to see what details I can easily incorporate, here you can see two prototypes using the TFFM dimensions for thickness”s and the shape from my Pegasus draft.
  9. Try some fine black thread and a dab of white glue, that’s what I mostly used.
  10. Great to see you start the new model Chuck, I’m sure it will be a fantastic project and I look forward to building another of your designs.
  11. Yep - nice to see somebody else lining off.
  12. Thanks Rusty!! I’m a long way behind you other guys but I usually get a little more modeling time during the winter.
  13. Headworks on both side now completed, just need to make the gunport lids to finish Chapter5.
