Ian_Grant
Posts posted by Ian_Grant
  1. Bill,
    Yes your gunport linings are looking good. Tedious but the results are worth it. Like you plan, I only lined the lower two gun decks.
    Though the instructions say to paint the lower and middle gun decks, in reality nobody will ever see them unless they poke an optical fiber through a gunport. If you do paint them you end up scraping paint off to cement the gun trucks to the deck. I left them as is. One can barely see the gun carriages through the ports, much less the decks. If you do want to paint them I suggest gluing the guns in first.
    When you get to the main deck, I think (? it's been a while) the latest analysis of remaining paint layers carried out by the restorers showed the main deck bulwarks were yellow ochre. Had you heard about the other colour changes they determined from this analysis? The bee lines are no longer yellow ochre on the real ship but a new colour which has some pink in it.You can read up on this at hms-victory.com
    ps I still recommend you get a copy of Longridge's "Anatomy of Nelson's Ships" and forget the Heller instructions as regards rigging.
  2. Hi Bill,
    As Hubac says, Heller provides fine molded lines for the ochre stripes and they do not follow the wales. But I seem to recall some inaccuracies in their locations where they meet the quarter galleries and even I think between the two sides.  Best check photos of the actual ship.
    Are you going to frame the gunports inside with some evergreen strips? This replicates the actual hull thickness and adds "heft" to the visual appearance.
    I didn't see anyone answer your query about Dafi's brass etch.....yes definitely you want to blacken them. I haven't had much luck with blackener in the past (I've since learned one must pickle them first to remove oxide coating) so I painted them.
    I've been out of touch with your build, but now you have a new follower.  😃
  3. Hello, I am a rank newbie as far as 3D CAD goes, in fact I have only ever used TinkerCAD.
    I wanted to build a small CAD file of an assembly made with structural and linear motion components from ServoCity, just to examine overall dimensions. They provide zipped "STEP" files for all their parts.
    However, when I download these zipped STEP files, right-click and select "EXTRACT" the resulting file is designated as an Adobe file (doesn't sound right to me) which TinkerCAD can't "see" as a valid item to import.
    So my questions are
    1)  Do I need to download some other app to extract zipped STEP files, as opposed to whatever windows does?
    2)  Is TinkerCAD even capable of importing mechanical part files like these? I'm hoping not to have to learn Fusion360 or equally complex tools.
    Thanks,
    Ian
  4. I disagree with Louie; I thought Parkinson's "letter from Hornblower" was a great addition to the Hornblower genre, demonstrating his ruthlessness when necessary. And the revelation about Mr. Wellard - Wow!
    I agree the recent TV series was less than great. The wholesale departure from the books to ridiculous plots was irksome. I'd rather watch the old Gregory Peck movie, any time.
  5. Bill,  nice to hear from you. How is your Potosi build going?
    After poking around, I see it's actually  www.hismodel.com whereas the site you quoted is completely different.  Those sails do look nice, but at $300CDN I will rig bare poles as planned 🤪
    My balls are seemingly not as big as Victor estimates as I have decided there is no way I am rigging 300 blocks on this model. I plan to use wood blocks for the tackle on lower yard lifts and topsail sheets, and for the braces on the lower yards leading to the winches, but for most of the rest I will just tie a knot and slide a seed bead over it to represent a block. I have some very small seed beads which are smaller than Syren's 2mm blocks, from a bead store in the neighbourhood.
    I just received, finally, my brass and copper eyes order so I am once again equipped to continue with Preussen. However, while waiting I started building a chess table for a nice chess set I bought years ago in Germany. I want to finish it first. Also, I want to build a rudimentary galley cross section with oars so I can test out my oar-driving setup and write the required Arduino code, before deciding whether to build an actual RC galley. All this to say it may be a while before I get back to Preussen. Unless we get a week of 40C humidex; that'll drive me indoors!
    For interest, if any, here are a couple of shots of the chess table in progress. There will be two drawers, one above the other, opening opposite ways to hold the chess men.
    The top:  Cherry and maple with inlaid banding from Lee Valley. That's a 12" rule on it.
    The carcass with drawer slides:
  6. On 4/30/2021 at 4:26 PM, Ulises Victoria said:
    I like to leave some loose ropes in my ships. It is my feeling that it breaks rigidity and makes the ship feel more... I don't know... I just like it! :)
    I fully agree with you. No need for course sheets and tacks to be hauled taut when furled. I did the same on my Victory.
