Everything posted by Baker
The stem (problem) So now I know why the water lines from MRNS were not correct. The rason was "a wrong" start with the stem. So this problem will be solved first. The stem on this drawing is enlarged. The difference is clearly visible. The new piece Oops... Adjusting the front bulkheads and repositioning. (Mister Bosch is a very handy little thing for this). And my assistant is also there (on the right between 11 and 12) All bulkheads are bolted to the buildslip. And the water lines from MRNS are pretty accurate now. Thanks for following
Part of the bulkheads are adjusted and ready. An opening is made in the middle. Start aligning and attaching the bulkheads to the buildslip. The buildslip is first leveled flat Aligning the bulkheads with the laser Making sure that the screws remain accessible The rear part is ready The plywood keel has been sawn through (a mistake was made at the front). The final keel will be installed at a later stage. Supervisor Felix has full confidence in this project 😼
GTX Boxer and 2 MAN trucks by Baker - FINISHED - Revell - 1/72
Baker replied to Baker's topic in Non-ship/categorised builds
Some links https://www.academia.edu/3245770/The_Development_and_Design_of_Bronze_Ordnance_Sixteenth_through_Nineteenth_Centuries https://www.academia.edu/20120786/The_Arming_of_Late_16th_century_Merchantmen._A_Masters_Thesis_from_the_Maritime_Archaeology_Programme_University_of_Southern_Denmark https://core.ac.uk/download/pdf/4268442.pdf And If you have Peter Kirsch's book Galleon. It also contains a lot of information
Good to be aboard. Greetings from Alberta, Canada.
Baker replied to Al Litchfield's topic in New member Introductions
seems like a challenging model to restore -
The only grating from the 17th century that "remains" is probably that of the Swedish (Dutch built) Vasa. I think you see in the photo a combination of what @allanyed represents. 16th and early 17th century grating is varied. What it looked like later in the Victory era, no idea. And if you want to play it safe, hathes and no grating 😉
Welcome back I did the trick with the pva glue too. With diluted PVA glue and smeared both sides of the sail
- 740 replies
- Tudor
- restoration
(and 4 more)
First a non Ship related item. Recently my photos are reduced with this tool. The first time you use it is a bit of searching, but after a few times of practice this goes pretty smoothly The length / width ratio can be found in the MR book by Haynes (thanks to Chapman 👍). There is a waterline drawing in MRNS. It also shows the positions of the sections on the keel. This drawing is enlarged and hopefully these water lines will fit Bulkheads whose position corresponds to the sections in the MRNS book are adjusted. The MRNS book sections (black) are in place. The intention is to use the water lines to bring the remaining bulkheads into a better shape The difference in bulkhead 11 and section 10 is here good to see Very early at this stage, designing flags Thanks following and the advice
thanks, I've already had the idea of buying an airbrush. This gives better results. But when I started this hobby in the 80's an airbrush was quite a big investment for me. plus that all my military models are built on the kitchen table is also a minus. I can't see myself spraying paint in the same room where we cook and eat. In addition, I'm phasing out my military models (I have a dozen more to build, and that's it) So no need for an airbrush anymore.
