Posts posted by RGL
- Dubz, cog, Ryland Craze and 11 others
- 14
- CDW, Dubz, Captain Slog and 13 others
- 16
Carl,
Maybe after you finish Musashi?
- Canute, popeye the sailor, mtaylor and 1 other
- 4
I used a black primer (first time), then gradually got lighter shades of grey. I think I'll go even lighter once it's all joined up to blend it together better.
- cog, mtaylor, popeye the sailor and 2 others
- 5
So, today I painted the tower, and have started throwing it together. I have forgotten to make up quite a few sets of ladders (no surprise really), and some gun directors. I'm still going have to order the triple 25mm's and warriors other stuff, I have used the kit supplied binoculars in the concealed areas. Three levels to go.
- Captain Slog, yvesvidal, hexnut and 13 others
- 16
I didn't, the reason being the kit ones are fine, I have put a few on where there is no details. I usually shave off the plastic ones and glue on the PE.
I've discovered that ringols are only above the hole, there is a lot of PE that provides them as circles and I think it's incorrect.
- mtaylor, Dubz, Farbror Fartyg and 13 others
- 16
I'm loving it. The handhold protection is great too, did you put CA on the inside to bond it as well?
If if I ever do this kit I'll probably go for the black hull.
Cog I think the Tamiya kit is far better engineered than the Ise.
- hexnut, Canute, Farbror Fartyg and 10 others
- 13
The Japanese ships had these huge Pagoda towers. Given they are so intricate I am going to try and construct it so it pulls apart for ease of painting and add the multitude of ladders afterwards.
Im still awaiting drill bits so I can't progress the rear of the bus.
So far, that's the first two stories of 9.
- Ryland Craze, Dan Vadas, CDW and 11 others
- 14
Next, back to the rear deck. There are 12 turntables, requiring me to buy 2 sets of Alliance model works railing sets. I've started on the railings and will probably use a hole punch to make up the last two turntables. Looks so much better than the kit "apathy", apparently aircraft could only fly off via the catapult anyway and the only way this would work is to use the traditional railing system.
The deck itself was concrete, used as a counterweight as the rear two turrets were removed. Photos and video of the Ise show the blocks of cracked concrete and the railings. About a day's work to go on this then I'll flip it and continue with the underside.
- hexnut, Canute, thibaultron and 9 others
- 12
IJN Ise 1944 by RGL - FINISHED - Fujimi - 1/350 - PLASTIC
Pagoda tower glued down, and the tack dry fitted, I will not add any more details to this until it's glued to the hull and before the ships boats are done.
You can see how huge huge this is even compared to Yamato.
