Everything posted by Tigersteve
It’s been a day so why not undo some of this work. Uggh! I haven’t been pleased with the handles for these doors so I decided to add some black paint with a toothpick. This did not improve the appearance so after some fidgeting I had to remove some parts. While I was at it I removed a wonky part of the main deck. The tools used for deconstruction were the exacto knife to open the groove and steel ruler to pry the pieces carefully. Patience is key. I’m considering redoing the gratings but I would need to purchase more gratings and I’ve spent enough $ on the wood for this project already. I think they will be fine under the ships boat. This is still up in the air. What do you guys think? Steve
Congrats on the finished model. Very nice work. Steve
- 756 replies
- galleon
- golden hind
You’ll want to install the cap rail after you sand the frames because you’ll need the space inside the boat to work on and install the cap rail. Chuck’s instructions are pretty solid. Careful when sanding the frames. There’s a lot of it to do. It took me several sessions for this step. Steve
- 24 replies
- 18th Century Longboat
- Model Shipways
Upper deck planking is complete with the exception of a final sanding and second coat of Poly. Planks were staggered as per the shift pattern in the instructions. I tried to capture the color of the wood as best I could in the photos. I think the Cherry is a nice fit for this project. I need to make some tweaks to the bulkheads before they are glued in place. Steve
Hi Ghost029, You need to taper the planks and properly shape and bend them before gluing to the hull. Prior to that you need to line off the hull. There are many resources on planking on this forum. You should check them out before you proceed. Don’t feel bad or be afraid to remove things and do things over. No one gets things perfect on the first attempt. Steve
- 24 replies
- Model Shipways
Nice work on this kit! Steve
- 25 replies
- Model Shipways
A great kit but it is an advanced kit as you have seen from many previous build logs. Check out this log for reference. One of my favorites and it will help you a great deal. Steve
- 24 replies
- Model Shipways
Gratings for the upper deck were completed using 3/16” cherry grating strips from Model Expo. The coamings were created first using a jig I created from previous projects. The quality of the grating strips were good. It was a tedious and frustrating process. The center gratings are slightly askew. This being my second assembly of this portion, I opted to not redo them. They will be obscured by the ships boat anyway. Steve
Another superb and inspiring build! Steve
- 607 replies
- winchelsea
- Syren Ship Model Company
Quick update on the completed door handles. After drilling the holes deeper I was able to place the eyebolts through before bending and using marker to blacken them. The paint I have wouldn’t adhere. I am not completely happy with this result but it is tidy enough for this scale and I believe it will blend in when other details are added. The main hatches and upper deck planking is next. Steve
Nice work! Look forward to your updates. Steve
- 60 replies
- Confederacy
- Model Shipways
Thank you so much for the kind words! It was a fun project. Steve
- 70 replies
- Lowell Grand Banks Dory
- Finished
Looks great! Good luck on the boats! Steve
- 126 replies
- Finished
- confederacy
